Pocket GPS World :: View topic - Getting Garmin Nuvi 40 Voice Alerts to work?
Goto page Previous  1, 2, 3, 4, 5, 6  Next
PostPosted: Mon Sep 28, 2015 3:22 pm    Post subject: Reply with quote
Kremmen wrote:
That area would be fine as it's read/write but I think a new folder in there is favourite.
That's what I said. Very Happy
PostPosted: Mon Sep 28, 2015 4:38 pm    Post subject: Reply with quote
That's what happens when I speed read Embarassed
Satnav:
Car Average MPG :
Oscargrouch
PostPosted: Mon Sep 28, 2015 7:16 pm    Post subject: Reply with quote
Anyway, calm down you two...
Laughing I took the Garmin for a local full test run today and I have the latest Speed Cams and......Voices to boot....Thank you all, I look forward to the sticky.
For the record, I had Speed Cam and voice narratives in one folder on drive (D).
SOX was in drive D before unzipping, when unzipped it went into Programme files/POILoder (same file as Sox.exe is in). I think what I didn't expect to see was 32 items in the Garmin Personal POI file on the Garmin Device instead of the 98 items which I think were uploaded. Perhaps it only shows the last 32 items uploaded. Where exactly do they reside, it was so much easier with my TT One series; just paste the whole Speed Cam file into maps, and then link the voice file to a particular speed cam from the set. Again, thanks, hope I have not started a row.... Rolling Eyes
PostPosted: Mon Sep 28, 2015 7:26 pm    Post subject: Reply with quote
What you should end up with is a single .gpi file after POIloader has done its business.
In your d:\ drive should be the many filesets like
Gatso50.csv
Gatso50.wav
You will have lots of these triple filesets for each camera type Gatso, Mobile, Specs and Redlight covering all the speed ranges but as I said the whole lot should be on the device as a single .gpi file.
Most Garmins have a GPS simulator mode so you don't need to go out to test the cameras work as expected.
Satnav:
Car Average MPG :
dales
PostPosted: Mon Sep 28, 2015 8:36 pm    Post subject: Reply with quote
The Garmin will only list the cameras that you have loaded. The associated .bmp's and .wav's are not listed, although they are amongst the item count of items you have loaded.
POILoader forms all this data into a .gpi file, which resides in the Garmin's internal memory (or on the SD card, as in my case).
Dales.
PostPosted: Mon Sep 28, 2015 8:37 pm    Post subject: Reply with quote
Rest assured. You haven't. Just a bit of friendly banter. Very Happy
@Kremmen. Where's his 32 files coming from in his Garmin Personal POI coming from? Where should the single .gpx file be and what should it be called. (Lack of Garmin experience shining through and mine is in the car and I can't be assed to go and get it to find out) Confused
Oscargrouch
PostPosted: Mon Sep 28, 2015 9:51 pm    Post subject: Reply with quote
Gatso50.csv
Gatso50.wav
Sorry, I don't understand any of that. Where and how can I view the .gpi fie on the device?.. Rolling Eyes
PostPosted: Tue Sep 29, 2015 4:39 am    Post subject: Reply with quote
I must admit I'm getting confused with the files layout being reported.
Satnav:
Car Average MPG :
PostPosted: Tue Sep 29, 2015 8:27 am    Post subject: Reply with quote
The procedure is HERE as linked to by Cremmen earlier. There are a couple of bits in his write up that refer to a special program that he has written. These ar the screendumps with the big green areas.
Once saved the zip will need to be extracted. Using my program I now only need to extract the camera files because I already have a set of BMP and WAV files in place in the working directory:
You need to unzip the PGPSW files using a different program if you are not using Kremmen's program.
The file list produced in your working directory should resemble those in the green area of Kremmen's screendump. Then follow the instructions for POILoader. The location of the .GPI file is wherever you put it from POILoader. In Kremmen's example he has put it onto his Garmin and his last screendump shows the Explorer view of his Garmin with the PGPSW.GPI file located in {devicename}\InternalStorage\POI (where {devicename} is the name of YOUR device.
PostPosted: Tue Sep 29, 2015 9:13 am    Post subject: Reply with quote
Good point, the vast majority of the procedure is covered including a link to SOX and how to use POILoader.
Satnav:
Car Average MPG :
Oscargrouch
PostPosted: Sat Oct 03, 2015 10:00 pm    Post subject: Reply with quote
Many thanks Kremmen for all the work that both you & your colleague WalkerX must have put in to the CSV Converter. I have just updated my SatNav to the Nuvi 2589LM; well pleased. Did not use your Converter but will do for next update. Got away with using SOX in POILoader. All Cams & .WAV files working. Thanks also to M8TJT for his valuable input. Would never have worked it out without all of your help... Very Happy
PostPosted: Sun Oct 04, 2015 5:17 am    Post subject: Reply with quote
Glad you got it sorted. That latest converter program is still in beta so let me know any issues. There are so many combinations now I've not tested them all.
This weeks task is to try and merge parts of "Redlight camera" and "variable speed" to try and achieve "RedSpeed" in the new wav file set.
Satnav:
Car Average MPG :
Oscargrouch
PostPosted: Mon Oct 05, 2015 10:45 pm    Post subject: Reply with quote
Used your Garmin Converter yesterday, it works fine; I did not alter your distance settings, POI Loader accepted the files okay. Tell me, when I download this weeks updates, I take it that all I need to download is the Cams and the .BMP files as the voices are already installed? And, last question: I have inserted a 16 Gb micro card into the Satnav, does the Garmin automatically use it if it runs out of its own memory? Thanks in advance.... Question
PostPosted: Tue Oct 06, 2015 4:33 am    Post subject: Reply with quote
If you are happy with the voices and icons on your Garmin then in the program dropdown just extract the camera files (top of the three options)
FYI I have updated the icons and sound files in the latest zip package. There is also an updated .htm helpfile that includes the new RedSpeed separator.
The new icons (44x44) include a new RedSpeed icon and the new voices include new RedSpeed warnings.
If you are already running the version with the RedSpeed option then just unzip the latest package and copy the new bmp and/or wav files to your 'working directory'. No need to reinstall.
Satnav:
Car Average MPG :
PostPosted: Tue Oct 06, 2015 6:30 am    Post subject: Reply with quote
No, to use the sd card you, or a program like Express or Basecamp, needs to install data onto it.
Page 2 of 6
22.051 (01 May 24)
