Pocket GPS World :: View topic - new windows 8.1 does not recognise sat nav
eddieo
PostPosted: Tue Sep 23, 2014 5:54 pm    Post subject: new windows 8.1 does not recognise sat nav Reply with quote
Hi chaps. just bought a cheap windows 8.1 laptop for travel. installed base camp but I cant populate the map as it wont recognise the GPS unit when i plug it in...have tried different leads..help? Very Happy
PostPosted: Tue Sep 23, 2014 6:46 pm    Post subject: Reply with quote
What won't recognise it? Your PC or Basecamp or both?
eddieo
PostPosted: Tue Sep 23, 2014 7:53 pm    Post subject: Reply with quote
Both I guess. when I plug it in its not recognised by either..hope its not a windows 8.1 issue Sad
alan_sh
PostPosted: Tue Sep 23, 2014 8:09 pm    Post subject: Reply with quote
I have Windows 8.1 and Basecamp and it recognises all my Garmin Satnsvs (Zumo 550, Zumo 660 and Nuvi 2599)
Alan
PostPosted: Tue Sep 23, 2014 8:43 pm    Post subject: Reply with quote
If your PC isn't recognising your nuvi try the steps here (the ones at the beginning)
http://support.garmin.com/support/searchSupport/case.faces?caseId=%7Be908ee90-c6c1-11e1-dcef-000000000000%7D
I understand USB3 can cause issues, so if you have a choice use a USB2 port.
eddieo
PostPosted: Tue Sep 23, 2014 9:29 pm    Post subject: Reply with quote
no usb 3.
right..have tried the above link and no good. but what is happening is the satnav is freezing, as when i plug it out from laptop its inoperable so have to hold button for ages tlll it shuts down, try it again multiple times no joy...still not recognised by laptop either
PostPosted: Tue Sep 23, 2014 10:10 pm    Post subject: Reply with quote
What satnav do you have?
eddieo
PostPosted: Wed Sep 24, 2014 10:19 am    Post subject: Reply with quote
not a clue what is happening but i installed Express, restarted computer a few times and seems to be working..time will tell! Smile
PostPosted: Wed Sep 24, 2014 10:47 am    Post subject: Reply with quote
Maybe when you reinstalled Express and restarted your PC you effectively did what's suggested in this Garmin FAQ
http://support.garmin.com/support/searchSupport/simpleCase.htm?caseId={8a5f1480-ddf1-11e2-7dd9-000000000000}&kbName=garmin
eddieo
PostPosted: Wed Sep 24, 2014 11:43 am    Post subject: Reply with quote
"Use a USB Data Transfer cable only, avoid USB charging cables"
not sure what the differnce is to be honest. but at least its working.. well at least the last time i looked it was!
i cant get on with basecamp it drives me bonkers. I can download maps onto laptop via express, but will I need a version of mapsource on laptop to start with?? but new laptop has no cd drive:( any ideas
PostPosted: Wed Sep 24, 2014 11:53 am    Post subject: Reply with quote
MapSource is no longer supported. Basecamp takes a bit of getting used to but once you have it's far more powerful than MapSource. However MapSource is still available as a download (no need for any drive) should you wish, be aware though that you need to jump through a few hoops to get a newer nuvi to work with MapSource
http://www8.garmin.com/support/download_details.jsp?id=209
As for cables, not all USB cables are the same. Data cables have extra wire(s), and they often fool the Nuvi into thinking it's connected to a computer when it may not be. That's why Garmin recommend using their own cables and state that other USB cables may or may not work.
eddieo
PostPosted: Wed Sep 24, 2014 3:30 pm    Post subject: Reply with quote
Thanks!
I have mapsourse on my PC and it works OK, it recognises the new maps when I upgrade them from time to time. just have to remember when downloading to choose both device and PC. Thanks for the link will try it ..then install maps to new laptop only and see how it goes! Smile
I appreciate what you say re basecamp, but not computer literate and have been using mapsourse since 2000'ish
eddieo
PostPosted: Wed Sep 24, 2014 6:58 pm    Post subject: Reply with quote
just noticed your link for american mapsource......
PostPosted: Wed Sep 24, 2014 8:21 pm    Post subject: Reply with quote
Well it's Mapsource ..... Garmin only does one version.
Whatever .... If it does what you want no need to change.
eddieo
PostPosted: Wed Sep 24, 2014 10:02 pm    Post subject: Reply with quote
Oh..OK will try it!
22.051 (01 May 24)
