| Author |
Brian Regular Visitor
Joined: Nov 12, 2003 Posts: 94 Location: Lancashire, England, Great Britain
Posted: Thu Jan 10, 2008 6:58 pm Post subject: SatMap + .gpx files |
| Quote: | | quote from SatMap's website .. |
Can it or can't it? .. Anyone done it? _________________ Aprilia Tuono, Zumo 550
Ipaq 2210/Fortuna/TomTom Nav6
& Road Angel 7000 + Memory Map |
| Back to top |
Joined: Jan 14, 2005 Posts: 19636 Location: Blackpool , Lancs
Posted: Thu Jan 10, 2008 7:34 pm Post subject: |
| When the Sat Sync software is made available this should be possible, currently you cannot do this, but as you don't have an active 10 is this an issue for you? - Mike |
| Back to top |
robs1972 Frequent Visitor
Posted: Thu Jan 10, 2008 7:38 pm Post subject: |
Where have you been for the last 2 months!!??
No it doesn't....not yet any way.
If you paste a GPX file from your PC on to the SD card it won't be recognised on the Route Menu of the A10 and if you copy a route you created on the A10 off the SD card on to your PC it's not a GPX file.....so I don't know what's going on. _________________ I like mapping, I like mapping, I like mapping and I like to map! |
| Back to top |
Posted: Thu Jan 10, 2008 7:50 pm Post subject: |
| mikealder wrote: | | When the Sat Sync software is made available this should be possible, currently you cannot do this, but as you don't have an active 10 is this an issue for you? - Mike |
It doesn't exactly say on the webite that the gpx thing is part of the SatSync solution, its a consideration (for me) if I ever do decide to buy one!!!
Likewise I haven't seen it mentioned that when SatSync is available that it automatically means that some sort of web-based route-planning software is going to appear at the same time.
| Quote: | | Where have you been for the last 2 months!!?? |
Eh!! I must say I'm more interested in the Memory Map forum having bought a Road Angel/Mem Map combo but I have a dabble over here in the SatMap department to try and keep my ear to the ground, you know with the two gps's being of similar types. _________________ Aprilia Tuono, Zumo 550
| Back to top |
Posted: Thu Jan 10, 2008 8:01 pm Post subject: |
| Brian wrote: | It doesn't exactly say on the website that the gpx thing is part of the SatSync solution, its a consideration (for me) if I ever do decide to buy one!!!
Likewise I haven't seen it mentioned that when SatSync is available that it automatically means that some sort of web-based route-planning software is going to appear at the same time. | Very true, but until the software is launched all we can do is wait, speculation as to what it might or might not do is pointless to be honest.
| Brian wrote: | | having bought a Road Angel/Mem Map combo but I have a dabble over here in the SatMap department to try and keep my ear to the ground, you know with the two gps's being of similar types. | Having used both device types I have to say the old phrase "about as similar as Chalk and Cheese" springs to mind, the mapping data is very good on either device, but you would expect that when provided from OS - Mike |
| Back to top |
Posted: Thu Jan 10, 2008 8:40 pm Post subject: |
| Quote: | | about as similar as Chalk and Cheese |
Each to their own I suppose, had I not read so much criticism on this forum from people who actually own them .. 'can't get a fix', 'poor battery life', 'batteries drain unless I take them out', 'no PC software', 'water behind the screen cover', 'flickering screen' etc etc I might have bought one. But coming across the RA and already having the Memory Maps I soon realised it can do everything the SatMap can do (except Track up display) and much more. I have MM on both the RA and on a pda, theres little difference except the convenience of less wires, better battery life and no bluetooth to worry about. _________________ Aprilia Tuono, Zumo 550
| Back to top |
Jay1967 Regular Visitor
Posted: Fri Jan 11, 2008 1:55 am Post subject: |
Food for thought... I've been an owner of PPC's for a few years now and have quite a collection excellent FREE programs, being a very open source platform.. So im wondering as the A10 is CE im assuming it too could be as 'open-sourced' and maybe someone will beat SatMap at their own game by producing their own SatSync? If so this would boost SatMaps profile hugely giving the user a free choice. It's done well to sell Windows PPC!
If I find anything, ill post it here... _________________ Visit my Walking Blog: http://jswalks.blogspot.com/
Visit my Tech Blog: http://jtech2010.blogspot.com/
TT GO920, Honda in-Car system, Garmin Oregon 550T + (OSGB 1:50k S.Eng), Garmin 60CSx, TT BT, QSTARZ QBT1000 Data Logger, MemoryMap v5 - Uk 1:50kOSG |
| Back to top |
figgis Occasional Visitor
Posted: Sat Feb 09, 2008 12:33 pm Post subject: Satsync |
| I have been emailed the Sat sync software from Satmap however when I tried to move a gpx file to the Satmap it responed with "file does not appear to be a gpx file" so it may be you will have to find a particular version for it to work. |
| Back to top |
Posted: Sat Feb 09, 2008 12:37 pm Post subject: Re: Satsync |
| figgis wrote: | | I have been emailed the Sat sync software from Satmap however when I tried to move a gpx file to the Satmap it responed with "file does not appear to be a gpx file" so it may be you will have to find a particular version for it to work. |
gpx files differ hugely in that they can contain many different types of info. Read through the posts here, there’s been quite a bit said about it. _________________ Visit my Walking Blog: http://jswalks.blogspot.com/
| Back to top |
lxm Occasional Visitor
Posted: Fri Feb 22, 2008 10:20 pm Post subject: .gpx files |
Using Satsync to MOVE (or COPY) .gpx files onto Satmap won't work. You need to "IMPORT" them, which converts them to .map files which appear as routes in the Satmap route menu.
Apparently this only works with Memory Map .gpx files, but using GPSU you can convert non-compliant files (of almost any kind including .mmo) to plain .gpx which can then be converted by Satsync to readable .map file. Hurrah.  |
| Back to top |
lucevans Regular Visitor
Joined: Mar 21, 2007 Posts: 249 Location: Cambridgeshire, UK
Posted: Fri Feb 22, 2008 10:40 pm Post subject: Re: .gpx files |
| lxm wrote: | Using Satsync to MOVE (or COPY) .gpx files onto Satmap won't work. You need to "IMPORT" them, which converts them to .map files which appear as routes in the Satmap route menu.
The latest version of SatSync beta also works with at least some other gpx files - I bought the SMC Munros gpx dataset (whic was not created with Memory Map) and the import function in SatSync works just fine. _________________ Active 10 back from it's tune-up and good as new! |
| Back to top |
sjdwheeler Occasional Visitor
Joined: Mar 18, 2008 Posts: 9 Location: Chipping Norton, Oxon
Posted: Tue Mar 18, 2008 12:14 pm Post subject: GPX to MAP on Active 10 |
I'm a SatMap novice but have just managed to import a GPX file to my Active 10 using SatSync. I'm a Mac-User so don't have Memory Map etc. so used www.gpsvisualizer.com/draw (free) at home and transfered to the Active 10 on my work PC using SatSync (free).
I plotted a route, saved as a GPX and imported to device, which converts to .map. This free plotter doesn't seem to record altitude but otherwise it's a simple way to plot a road route.
More Mac compatibility in the GPS world please! But mission complete regardless. |
| Back to top |
Dragsterman Occasional Visitor
Posted: Tue Mar 18, 2008 6:05 pm Post subject: |
I agree there should be more Mac compatibility in the GPS world. Luckily I have a PC as well as a Mac.
About the gpx files, when I spoke to Richard at Satmap he said that gpx files which contain extra info like images etc. won't work properly. Using Notepad on the PC you can look at a gpx file and remove things like that. It seems like a long-winded way about making sure a gpx file will convert properly but worth making a note of when problems arise. |
| Back to top |
craig_w Occasional Visitor
Posted: Tue Mar 18, 2008 6:50 pm Post subject: |
Hey,
I've just been trying to export my Satmap route data to my PC. For some reason Memory Map doesn't like it how it is (2004 version) so I've had to use another piece of software (ITNconv) to convert it into a version that memory map does like!
Unfortunately this removes the time stamp data, so speeds and times are lost. Any idea how I import the data to memory map without losing any information? |
| Back to top |
| Back to top |
