Newsletter
Luxury 4 bedroom villa for rent in the Disney Orlando Florida area.
Pocket GPS World :: View topic - SatMap + .gpx files
SatMap + .gpx files
Brian
PostPosted: Thu Jan 10, 2008 6:58 pm    Post subject: SatMap + .gpx files Reply with quote
quote from SatMap's website ..
Can it or can't it? .. Anyone done it?
Aprilia Tuono, Zumo 550
Ipaq 2210/Fortuna/TomTom Nav6
& Road Angel 7000 + Memory Map
PostPosted: Thu Jan 10, 2008 7:34 pm    Post subject: Reply with quote
When the Sat Sync software is made available this should be possible, currently you cannot do this, but as you don't have an active 10 is this an issue for you? - Mike
robs1972
PostPosted: Thu Jan 10, 2008 7:38 pm    Post subject: Reply with quote
Where have you been for the last 2 months!!?? Laughing
No it doesn't....not yet any way.
If you paste a GPX file from your PC on to the SD card it won't be recognised on the Route Menu of the A10 and if you copy a route you created on the A10 off the SD card on to your PC it's not a GPX file.....so I don't know what's going on.
I like mapping, I like mapping, I like mapping and I like to map!
Brian
PostPosted: Thu Jan 10, 2008 7:50 pm    Post subject: Reply with quote
It doesn't exactly say on the webite that the gpx thing is part of the SatSync solution, its a consideration (for me) if I ever do decide to buy one!!!
Likewise I haven't seen it mentioned that when SatSync is available that it automatically means that some sort of web-based route-planning software is going to appear at the same time.
Eh!! I must say I'm more interested in the Memory Map forum having bought a Road Angel/Mem Map combo but I have a dabble over here in the SatMap department to try and keep my ear to the ground, you know with the two gps's being of similar types.
PostPosted: Thu Jan 10, 2008 8:01 pm    Post subject: Reply with quote
Brian wrote:
It doesn't exactly say on the website that the gpx thing is part of the SatSync solution, its a consideration (for me) if I ever do decide to buy one!!!
Very true, but until the software is launched all we can do is wait, speculation as to what it might or might not do is pointless to be honest.
Having used both device types I have to say the old phrase "about as similar as Chalk and Cheese" springs to mind, the mapping data is very good on either device, but you would expect that when provided from OS - Mike
Brian
PostPosted: Thu Jan 10, 2008 8:40 pm    Post subject: Reply with quote
Each to their own I suppose, had I not read so much criticism on this forum from people who actually own them .. 'can't get a fix', 'poor battery life', 'batteries drain unless I take them out', 'no PC software', 'water behind the screen cover', 'flickering screen' etc etc I might have bought one. But coming across the RA and already having the Memory Maps I soon realised it can do everything the SatMap can do (except Track up display) and much more. I have MM on both the RA and on a pda, theres little difference except the convenience of less wires, better battery life and no bluetooth to worry about.
Jay1967
PostPosted: Fri Jan 11, 2008 1:55 am    Post subject: Reply with quote
Food for thought... I've been an owner of PPC's for a few years now and have quite a collection excellent FREE programs, being a very open source platform.. So im wondering as the A10 is CE im assuming it too could be as 'open-sourced' and maybe someone will beat SatMap at their own game by producing their own SatSync? If so this would boost SatMaps profile hugely giving the user a free choice. It's done well to sell Windows PPC!
If I find anything, ill post it here...
Visit my Walking Blog: http://jswalks.blogspot.com/
Visit my Tech Blog: http://jtech2010.blogspot.com/
TT GO920, Honda in-Car system, Garmin Oregon 550T + (OSGB 1:50k S.Eng), Garmin 60CSx, TT BT, QSTARZ QBT1000 Data Logger, MemoryMap v5 - Uk 1:50kOSG
figgis
PostPosted: Sat Feb 09, 2008 12:33 pm    Post subject: Satsync Reply with quote
I have been emailed the Sat sync software from Satmap however when I tried to move a gpx file to the Satmap it responed with "file does not appear to be a gpx file" so it may be you will have to find a particular version for it to work.
Jay1967
PostPosted: Sat Feb 09, 2008 12:37 pm    Post subject: Re: Satsync Reply with quote
gpx files differ hugely in that they can contain many different types of info. Read through the posts here, there’s been quite a bit said about it.
lxm
PostPosted: Fri Feb 22, 2008 10:20 pm    Post subject: .gpx files Reply with quote
Using Satsync to MOVE (or COPY) .gpx files onto Satmap won't work. You need to "IMPORT" them, which converts them to .map files which appear as routes in the Satmap route menu.
Apparently this only works with Memory Map .gpx files, but using GPSU you can convert non-compliant files (of almost any kind including .mmo) to plain .gpx which can then be converted by Satsync to readable .map file. Hurrah. Very Happy
lucevans
PostPosted: Fri Feb 22, 2008 10:40 pm    Post subject: Re: .gpx files Reply with quote
The latest version of SatSync beta also works with at least some other gpx files - I bought the SMC Munros gpx dataset (whic was not created with Memory Map) and the import function in SatSync works just fine.
Active 10 back from it's tune-up and good as new!
sjdwheeler
PostPosted: Tue Mar 18, 2008 12:14 pm    Post subject: GPX to MAP on Active 10 Reply with quote
I'm a SatMap novice but have just managed to import a GPX file to my Active 10 using SatSync. I'm a Mac-User so don't have Memory Map etc. so used www.gpsvisualizer.com/draw (free) at home and transfered to the Active 10 on my work PC using SatSync (free).
I plotted a route, saved as a GPX and imported to device, which converts to .map. This free plotter doesn't seem to record altitude but otherwise it's a simple way to plot a road route.
More Mac compatibility in the GPS world please! But mission complete regardless.
Dragsterman
PostPosted: Tue Mar 18, 2008 6:05 pm    Post subject: Reply with quote
I agree there should be more Mac compatibility in the GPS world. Luckily I have a PC as well as a Mac.
About the gpx files, when I spoke to Richard at Satmap he said that gpx files which contain extra info like images etc. won't work properly. Using Notepad on the PC you can look at a gpx file and remove things like that. It seems like a long-winded way about making sure a gpx file will convert properly but worth making a note of when problems arise.
craig_w
PostPosted: Tue Mar 18, 2008 6:50 pm    Post subject: Reply with quote
Hey,
I've just been trying to export my Satmap route data to my PC. For some reason Memory Map doesn't like it how it is (2004 version) so I've had to use another piece of software (ITNconv) to convert it into a version that memory map does like!
Unfortunately this removes the time stamp data, so speeds and times are lost. Any idea how I import the data to memory map without losing any information?
11.054 (22 May 13)
