Pocket GPS World :: View topic - GPS mapping and routing software running on Windows Mobile 5
cp2005
PostPosted: Mon Nov 14, 2005 12:34 am    Post subject: GPS mapping and routing software running on Windows Mobile 5 Reply with quote
I am considering buying a pda to run a gps and mapping software, I was considering the TomTom Navigator version 5 until I noticed that it doesnt run on windows mobile 5.
Two questions does anyone know when and if TomTom intend to bring out a version of Navigator 5 that runs on windows mobile 5?
Or can someone recommend a mapping/routing software that runs on windows mobile 5.
lbendlin
PostPosted: Mon Nov 14, 2005 3:20 am    Post subject: Reply with quote
TTN does run on WM5, and a new version with full support will be out mid november (ish)
Most other software does run as well, or will shortly. Anything in particular that you want to have tested?
Lutz
TomTom/TeleAtlas NAVTEQ
joeninety
PostPosted: Mon Nov 14, 2005 4:58 pm    Post subject: Reply with quote
how do you get TT5 running on a WM5 device?
i dont have one yet, have put off buying one since people said it wouldnt work.
cp2005
PostPosted: Mon Nov 14, 2005 8:26 pm    Post subject: Reply with quote
Hey thanks for the info, sorry I was mis informed! but I checked the TomTom web site and according to them it stated that Navigator 5 did not work with Windows mobile 5. That said I couldnt find a date on the comment so it may be out of date, you would think they would be stating that it does work no?
PostPosted: Mon Nov 14, 2005 11:57 pm    Post subject: Reply with quote
It works - but the installer doesn't (Active Sync 4,0), this is easy to overcome by getting the CAB files (four of them - TTN, WZD, PIMAddin and GPS) on to the SD card and running each one to install the application - this is covered elsewhere on the forum in more detail - i.e. how to obtain the CAB files if required - hope this helps Mike
joeninety
PostPosted: Tue Nov 15, 2005 11:37 am    Post subject: Reply with quote
thanks for the info mikealder. i might consider upgrading to a WM5 device if its stable with TT5 Smile
Gmonkey
PostPosted: Wed Nov 16, 2005 8:29 pm    Post subject: Reply with quote
good to know, I'll let my friend at my old job that uses that know
cp2005
PostPosted: Wed Nov 23, 2005 6:44 pm    Post subject: `how to obtain CAB files Reply with quote
Dear All
Ok so now I am just about to place the order for a Dell 51v running mobile 5, and Tom Tom Navigator 5, earlier Mike very kindly suggested a way to load Navigator 5 onto Windows Mobile 5. Sorry for being stupid but could someone give me the exact instrunctions on how to do this please?
thanks inadvance
Craig
PostPosted: Thu Nov 24, 2005 12:29 am    Post subject: Reply with quote
Hope this link is of some use, I used it and worked fine - http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=27097&highlight=cab+files
Mike
22.051 (01 May 24)
