cp2005 Occasional Visitor
Posted: Mon Nov 14, 2005 12:34 am Post subject: GPS mapping and routing software running on Windows Mobile 5 |
I am considering buying a pda to run a gps and mapping software, I was considering the TomTom Navigator version 5 until I noticed that it doesnt run on windows mobile 5.
Two questions does anyone know when and if TomTom intend to bring out a version of Navigator 5 that runs on windows mobile 5?
Or can someone recommend a mapping/routing software that runs on windows mobile 5. |
lbendlin Pocket GPS Staff
Posted: Mon Nov 14, 2005 3:20 am Post subject: |
TTN does run on WM5, and a new version with full support will be out mid november (ish)
Most other software does run as well, or will shortly. Anything in particular that you want to have tested? _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
joeninety Regular Visitor
Posted: Mon Nov 14, 2005 4:58 pm Post subject: |
how do you get TT5 running on a WM5 device?
i dont have one yet, have put off buying one since people said it wouldnt work. |
Posted: Mon Nov 14, 2005 8:26 pm Post subject: |
Hey thanks for the info, sorry I was mis informed! but I checked the TomTom web site and according to them it stated that Navigator 5 did not work with Windows mobile 5. That said I couldnt find a date on the comment so it may be out of date, you would think they would be stating that it does work no? |
Posted: Mon Nov 14, 2005 11:57 pm Post subject: |
It works - but the installer doesn't (Active Sync 4,0), this is easy to overcome by getting the CAB files (four of them - TTN, WZD, PIMAddin and GPS) on to the SD card and running each one to install the application - this is covered elsewhere on the forum in more detail - i.e. how to obtain the CAB files if required - hope this helps Mike |
Posted: Tue Nov 15, 2005 11:37 am Post subject: |
thanks for the info mikealder. i might consider upgrading to a WM5 device if its stable with TT5 |
Gmonkey Frequent Visitor
Joined: Oct 17, 2005 Posts: 390 Location: Washington DC
Posted: Wed Nov 16, 2005 8:29 pm Post subject: |
good to know, I'll let my friend at my old job that uses that know |
Posted: Wed Nov 23, 2005 6:44 pm Post subject: `how to obtain CAB files |
mikealder wrote: | It works - but the installer doesn't (Active Sync 4,0), this is easy to overcome by getting the CAB files (four of them - TTN, WZD, PIMAddin and GPS) on to the SD card and running each one to install the application - this is covered elsewhere on the forum in more detail - i.e. how to obtain the CAB files if required - hope this helps Mike |
Dear All
Ok so now I am just about to place the order for a Dell 51v running mobile 5, and Tom Tom Navigator 5, earlier Mike very kindly suggested a way to load Navigator 5 onto Windows Mobile 5. Sorry for being stupid but could someone give me the exact instrunctions on how to do this please?
thanks inadvance
Craig |
