Newsletter
Pocket GPS World :: View topic - Evoque GPX files not loading - corrupt.
petevick
PostPosted: Fri Aug 03, 2018 2:44 pm    Post subject: Evoque GPX files not loading - corrupt. Reply with quote
I subscribed to PocketGPSWorld database today to replace the speed camera files I was using, as some cameras were missing.
When I try to load the GPX files (consolidated by camera type) I get a message saying the GPX file is corrupt. I have tried different files, and tried 2 different USB drives but it makes no difference.
Anyone seen this before.
I am an IT Pro, so in theory I should know what I am doing.
Pete
PostPosted: Fri Aug 03, 2018 2:51 pm    Post subject: Reply with quote
Unfortunately not all GPX files are the same. The only common denominator is often the Topografix schema.
My CSV Converter uses Topografix but also uses the Garmin schema as my GPX files are aimed at Garmin devices.
I'll guess your vehicle is looking for GPX files to a specific standard.
Do you know that it can take the 1000,s of GPX lines for nationwide speed cameras or whether it's just expecting smaller POI type files ?
Satnav:
petevick
PostPosted: Fri Aug 03, 2018 2:58 pm    Post subject: Reply with quote
The 'old' files that loaded OK took one line for each camera (wpt record) whereas the PocketGPSWorld files take 12 lines for each camera
Maybe this is the problem Sad
petevick
PostPosted: Fri Aug 03, 2018 4:06 pm    Post subject: Reply with quote
Tried downloading Garmin - Other GPX and Other GPX - neither of them work
Not good!
PostPosted: Fri Aug 03, 2018 4:22 pm    Post subject: Reply with quote
Ah right.
Bit of a faff but as a test ... download the Garmin POIloader CSV fileset.
Then use my CSV Converter (in the Garmin section) because I write out my GPX files as single line wpt, as you require.
Then compare the output.
Satnav:
petevick
PostPosted: Fri Aug 03, 2018 5:00 pm    Post subject: Reply with quote
Thanks - tried it but same result
PostPosted: Mon Aug 06, 2018 12:05 pm    Post subject: Reply with quote
Ah, now you didn't mention this in your email...
If you send me a copy of the 'old' file you ave then I can add a new format to the download system that will match the 'old' one.
When you mentioned that the old ones worked I assumed you meant older versions of our database. Not some other files you were using.
petevick
PostPosted: Tue Aug 07, 2018 1:36 pm    Post subject: Reply with quote
Hi - files sent.
Appears to be a couple of problems
1) More than around 4,500 in a file fails
2) I think the @ signs confuse it.
The files that worked are a 'simple' one line format.
PostPosted: Wed Aug 08, 2018 9:28 am    Post subject: Reply with quote
Will take a look at these when I get chance.
petevick
PostPosted: Thu Aug 09, 2018 5:22 pm    Post subject: Reply with quote
Ok - More news.
I used the excellent HDTune to check the speed of my original USB disk just to check, and it was pretty slow reading - around 15mb/s.
I benchmarked an existing Toshiba TransMemory 32gb USB disk, which came in at 25mb/s. I then transferred the Other GPX format and copied them to the new disk.
Went to the car, tried the biggest (mobile) and got the same message. So tried gatso, and it loaded - same for redlight, specs and pmobile. Then tried mobile again and this time it loaded.
It would appear the Evoque is quite (very) temperamental.
My advice would be to use a fast USB disk and persevere if it doesn't work the first time as it obviously is a combination of file size and read speed.
HTH
PostPosted: Fri Aug 10, 2018 9:12 am    Post subject: Reply with quote
petevick wrote:
Ok - More news.
Was this using the GPX download from here or your modified 'one line' files?
I've not had chance to look yet - school holidays with special needs kids isn't conducive to working on code...!!
petevick
PostPosted: Fri Aug 10, 2018 9:14 am    Post subject: Reply with quote
This was using the GPX files from PocketGPSWorld. I just downloaded, and added the POI's
As I said, the Evoque does seem very temperamental Smile
punner08
PostPosted: Fri Aug 24, 2018 12:42 pm    Post subject: Reply with quote
WEll, that fixed my issues, thanks! Smile
DJI Mavic 1 Pro vs Mavic 2 Pro drone - camera comparison and more.
20.013 (19 Jan 22)
Terms & Privacy
