Pocket GPS World :: View topic - Voice alerts
Voice alerts
tuftyjack
PostPosted: Fri Apr 15, 2016 11:17 am    Post subject: Voice alerts Reply with quote
How do I replace the PGWS voice .wav files with the .wav files from PGWS Tom Tom download? It doesn't work in Explorer.
PostPosted: Fri Apr 15, 2016 12:10 pm    Post subject: Reply with quote
What exactly are you trying to do?
Presumably you have unzipped the downloads?
Which voices exactly are you trying to replace as your post seems to indicate that you are trying to replace one lot with the same lot.
tuftyjack
PostPosted: Fri Apr 15, 2016 2:49 pm    Post subject: Voice alerts. Reply with quote
I have TomTom voice alerts which I wish to use instead of the ones for my Nuvi 2599. They include a siren and "warning, Gatso ahead, speed limit......
I prefer them to the alerts for the Nuvi. If I try a simple "cut and paste" I get a warning telling me I can't do that. Hope you can help. (Win 10)
PostPosted: Fri Apr 15, 2016 3:18 pm    Post subject: Reply with quote
The Garmin voice alerts need to be WAV.
Have a look at the properties of the WAV files that are downloaded with the camera package from here and convert your TT ones to the same format. I would think Audacity will probably do the job.
I know Adobe Audition could probably do them all in one hit under batch mode but I've never used Audacity.
What you are trying to do sounds do-able to me but may require some work.
Satnav:
Garmin DS61 LMT-D (Indoor test rig)
Garmin 2599 LMT-D (Indoor test rig 2)
PostPosted: Fri Apr 15, 2016 4:02 pm    Post subject: Re: Voice alerts. Reply with quote
This sounds like a permissions problem somewhere, most likely on the destination device. Please tell us the exact error message that you are getting to enable 'us' to help further.
Don't they also have to have the correct filename?
PostPosted: Fri Apr 15, 2016 6:29 pm    Post subject: Reply with quote
Filename is indeed crucial to Garmin but I assume the OP is aware of this.
Satnav:
dales
PostPosted: Fri Apr 15, 2016 7:18 pm    Post subject: Reply with quote
Yes, Audacity can alter the bitrate of the wav files.
It has a batch processing ability - called Chains.
Dales.
21.114 (22 Nov 23)
