deuce Occasional Visitor
Posted: Thu Mar 05, 2015 11:05 am Post subject: Garmin Nuvi range |
Hi.
I have just bought a Garmin nuvi 2508 for my wife, who is a new driver.
The reasons for buying was traffic alerts, camera alerts and lane guidance.
We tried it out last night and weren't impressed. I have now found out that lane guidance is only available in certain places, but it didn't even show that there were 2 lanes. The pink direction line covered the both lanes. I realise that it won't always tell you which lane to be in, but it would be nice to see the layout properly.
She needed it for this morning, but it is not working. It keeps searching for satellites. If it doesn't start working I'll be taking it back.
Are there any others that have traffic and cameras, but show the proper layout?
Thanks. |
M8TJT The Other Tired Old Man
Posted: Thu Mar 05, 2015 11:21 am Post subject: Re: Garmin Nuvi range |
deuce wrote: | It keeps searching for satellites. If it doesn't start working I'll be taking it back. | Are you trying to get a sat lock whilst you are driving? If so, it will likely take a while. Let it get a lock before you start driving. Quote: | Are there any others that have traffic and cameras, but show the proper layout? | You asked the same question, which was answered, in your previous post on the subject so I can't see why you are asking it again. Are you expecting a more favourable answer?
The short answer is 'no'. The longer answer is that it depends on the map data and how the device manages this data. In the main, only large or busy junctions are covered by lane assist and not all junctions.
A good rule of thumb is that if the satnav tells you to turn left, then get into the left hand lane etc. |
Posted: Thu Mar 05, 2015 12:51 pm Post subject: |
Hi M8TJT.
I was sat in my house and it said the same thing for an hour. I turned it on and off a few times as well.
When I say "proper layout" I just mean that the thick direction line doesn't cover all lanes. It would be better if that disappeared when coming up to the junction. I'm not expecting the split screen with lane guidance on every junction. |
Kremmen Pocket GPS Verifier
Posted: Thu Mar 05, 2015 1:40 pm Post subject: |
I find that all my Garmins have only acquired a satellite fix indoors when the unit is near a window and preferably vertical, not just laid flat. If you're having issues in the car then check you haven't got one of these athermic windscreens or whatever they call them as they can block the signal. _________________ DashCam:
Viofo A119 V3 |
sussamb Pocket GPS Verifier
Joined: Mar 18, 2011 Posts: 4462 Location: West Sussex
Posted: Thu Mar 05, 2015 3:14 pm Post subject: |
I have one of those windscreens on my Focus and no issue with my GPS, or on my Mondeo before that.
You're unlikely to get a fix inside, and as already mentioned if you drive off before getting a fix it takes longer to acquire one as it's trying to shoot at a moving target.
I plug mine in when I get in the car. By the time I'm belted up etc it has obtained a fix. Note also that if you switch it on at a different location from when you switched it off that will also lengthen the time to acquire a fix.
As for the direction line, try switching the Map theme to Navigon, some folks find that better than the Garmin one (which is the default). It's under Settings, Map & Vehicle.
As for the lane to be in if the magenta line covers the road normal rules apply. Lane 1 if turning left. Lane 2 if turning right. Either if going straight on. If your wife is a new driver that should be fresh in her mind  _________________ Where there's a will ... there's a way. |
