burtonian Lifetime Member
Posted: Fri Apr 22, 2011 11:04 am Post subject: CamerAlert crashes (force close) |
Only started happening after last version update. Seems to happen when first camera warning occurs. Running on HTC Wildfire running Android FroYo 2.2.
Crash report :
1.2.8.451
java.lang.NullPointerException
--------- Stack trace ---------
com.pocketgpsworld.cameralert.CamerAlert.playQueue(CamerAlert.java:287)
com.pocketgpsworld.cameralert.CamerAlert$2.onCompletion(CamerAlert.java:299)
android.media.MediaPlayer$EventHandler.handleMessage(MediaPlayer.java:1383)
android.os.Handler.dispatchMessage(Handler.java:99)
android.os.Looper.loop(Looper.java:143)
android.app.ActivityThread.main(ActivityThread.java:4914)
java.lang.reflect.Method.invokeNative(Native Method)
java.lang.reflect.Method.invoke(Method.java:521)
com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:858)
com.android.internal.os.ZygoteInit.main(ZygoteInit.java:616)
dalvik.system.NativeStart.main(Native Method)
Darren Pocket GPS Staff
Posted: Fri Apr 22, 2011 11:18 am Post subject: |
We're aware of a bug affecting Wildfire handsets (see today's Newsletter here) and are testing a fix with our beta testers at this very moment.
Gotta love Android - not. _________________ Darren Griffin - Editor |
Posted: Fri Apr 22, 2011 11:50 am Post subject: |
Thanks Darren. FWIW, I love and count on both Android and CamerAlert - I hope I can keep them both
Might it be possible to 'downgrade' to the previous version of the app, which was giving no problems? Meantime, I've deleted the app data and re-installed database, just in case there was a corruption somewhere. |
Posted: Fri Apr 22, 2011 12:05 pm Post subject: |
Downgrading is not an option unless you have a backup of the older version. But the update will be released as soon as we are happy it is a fix. _________________ Darren Griffin - Editor |
Posted: Fri Apr 22, 2011 12:23 pm Post subject: |
Look forward to it, keep up the good work  |
Posted: Wed May 04, 2011 5:53 pm Post subject: |
Finally got around to updating to v1.2.8.457
Good news : app no longer crashes on sight of first (or subsequent) camera
Bad news : incomplete and confusing voice alerts e.g. fixed camera zone warning given but no speed limit quoted (it was regular 40mph); 'all clear' given before camera passed; speed limit number given subsequently with no other verbals. None of the several well-known cameras I passed on local roads resulted in a correct and complete verbal.
Anyone else experiencing these issues? I've re-installed an old version I'd backed up at start of April, I'll try this tomorrow to see if problem recurs. |
alanlakes Lifetime Member
Joined: Dec 28, 2005 Posts: 98 Location: Chevington, Suffolk
Posted: Thu May 05, 2011 6:50 am Post subject: |
My HTC Hero is given the Force Close "camer alert has stopped unexpectedly" notice as soon as I try to update cameras. Running v1.2.9.457. Have powered down phone etc. But no difference.
camer alert seems to run Ok otherwise.
Alan _________________ Tomtom Go 6200, Tomtom GO Android app, Garmin GPSMap 62stc, Garmin Oregon 450, Memory map V5 & V6, Moto G6, CamerAlert, Copilot Premium, MM Tracker. |
Posted: Thu May 05, 2011 3:14 pm Post subject: |
Well my old version gave a 'force close' so I re-installed v457 which again gave me mistimed and incomplete verbals. Last resort has been to completely uninstall app then re-install from scratch, including leaving it on phone rather than moving to SD card. Another try tomorrow .... |
Posted: Sat May 07, 2011 6:19 am Post subject: |
Re-install has fixed it.
Thanks Alan _________________ Tomtom Go 6200, Tomtom GO Android app, Garmin GPSMap 62stc, Garmin Oregon 450, Memory map V5 & V6, Moto G6, CamerAlert, Copilot Premium, MM Tracker. |
Posted: Sat May 07, 2011 1:30 pm Post subject: |
alanlakes wrote: | Re-install has fixed it.
Thanks Alan |
It may have fixed your issue but I'm still not sure if a re-install has fixed mine. Only one local camera passed so far and verbal warnings were still late, with long gaps in-between phrases - I'd gone past the camera position before the speed limit was given. |
peterc10 Frequent Visitor
Posted: Sat May 07, 2011 2:07 pm Post subject: |
burtonian wrote: | alanlakes wrote: | Re-install has fixed it.
Thanks Alan |
Burtonian - what are you running it on and are you running it in the background with another app? This is exactly what happened when I tried to run Cameralert in the background with Sygic MM10 (sat nav app) in the foreground on my Hero. It turns out that the phone was not powerful enough for them to run together. _________________ Peter
HTC Sensation
Copilot for USA
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 14888 Location: Bradford, West Yorkshire
Posted: Sat May 07, 2011 9:19 pm Post subject: |
Thanks Alan |
my hero did that if there was another ap running. it's terribly low spec comared to newer devices. but it was always the same symptoms: "fixed speed camera - gap - 30 - gap - miles per hour"
as a work around you could always turn on the shortened warnings (fixed - 30) and increase the warning distance?
MaFt |
tomthompson Frequent Visitor
Joined: 26/08/2003 15:43:37 Posts: 386 Location: Southampton, UK
Posted: Sat May 07, 2011 10:06 pm Post subject: |
My wildfire works perfectly with V457 and in fact it hasnt had a problem with any of the latest versions at all. Using Froyo 2.2 _________________ Asus Zenfone 2 twin sim, Garmin Zumo 550, 660 and pocketgps speed camera database
I keep on learning but they invent new things faster ,How do I keep up ? |
Posted: Sat May 07, 2011 10:08 pm Post subject: |
burtonian wrote: | including leaving it on phone rather than moving to SD card. Another try tomorrow .... |
That may be an issue too. Whilst the app can run from SD, the database cannot. _________________ Darren Griffin - Editor |
Posted: Sun May 08, 2011 4:49 pm Post subject: |
Thanks for the comments, guys.
I'm running Cameralert on a Wildfire with FroYo 2.2. The app ran perfectly well until first, the force close issue and, when that was fixed by the team, the slow vocals started. I have no other nav apps running and, apart from moving the app back to the phone memory, I don't believe anything is different (settings or other apps) from when it was working ok.
As a final offering to the Gods, I've also taken the phone battery out briefly. Hopefully all will be well when I try it tomorrow!
Tony |
