Andy_P Pocket GPS Moderator
Posted: Mon Apr 28, 2008 4:06 pm Post subject: |
As TT have got bigger and more successful, the rush to produce new models and ever more bells and whistles DOES seem to have produced kit that is nowhere near as straightforward and "bomb-proof".
It used to be that if you bought a Go300 and did NOTHING to it, it would carry on working forever. We are now getting to the stage where you need quite a bit of knowledge just to keep the more recent models running. |
simulatedsid Occasional Visitor
Posted: Wed May 07, 2008 9:47 pm Post subject: Tom Tom 730 T from Halfords |
Just purchased and am awaiting delivery for 730T from Halford(not advertised on the web site but found when you search for "730"). I hope this is not one units also posted earlier with issues due to being non UK.....
Will keep you posted
Not advertised on the Halfords web site |
hwangeruk Occasional Visitor
Posted: Sat May 10, 2008 10:17 am Post subject: battery life |
tomtoms have appalling battery life.
do the new x30 units have better battery life? |
Darren Frequent Visitor
Posted: Sat May 10, 2008 10:38 am Post subject: Re: battery life |
hwangeruk wrote: | tomtoms have appalling battery life.
What do you consider 'appalling'? These are after all units designed for in-car usage and so 3hrs + is perfectly reasonable for occasional use away from power.
I reviewed the 920 and was able to get over 4hrs from a full charge, more than enough in my opinion and as good as any other manufacturer. _________________ Darren Griffin |
gaj Occasional Visitor
Posted: Mon May 19, 2008 7:47 pm Post subject: Differences between tomtom x30's |
I just can't understand what the difference is between each of the x30's is other than maps, does the 530 have enhanced positioning?
Is it true you can update the software on the x20's to have the IQ and advanced lane? |
Posted: Mon May 19, 2008 8:16 pm Post subject: Re: Differences between tomtom x30's |
gaj wrote: | I just can't understand what the difference is between each of the x30's is other than maps, does the 530 have enhanced positioning? | Only the 930 has the EPT system fitted, the others just use standard GPS which, as you know doesn't work too well in tunnels.
gaj wrote: | Is it true you can update the software on the x20's to have the IQ and advanced lane? | This should be the case when/ if new maps and the Navcore 8 software is made available for the x20 series of devices - Mike |
DennisN Tired Old Man
Posted: Mon May 19, 2008 11:26 pm Post subject: Re: Differences between tomtom x30's |
mikealder wrote: | Only the 930 has the EPT system fitted, the others just use standard GPS which, as you know doesn't work too well in tunnels. |
The 920 also has EPT and I had it running alongside two 720s (without EPT) when I went along the Embankment and through the Limehouse Link tunnel to Canary Wharf. That's a pretty decent tunnel so it should be a reasonable test. All three devices lost signal in the tunnel. All three continued to show me moving through the tunnel, correct direction and location. It has curves and I had to turn off at the junction inside the tunnel. All three showed the junction correctly. When I came out, the 720s actually regained live map and signal before the 920T - only fractionally, but nevertheless. Maybe a much longer tunnel would be more of a test, but I won't hold my breath. _________________ Dennis
Two of them are obesiting!! |
Posted: Mon May 19, 2008 11:31 pm Post subject: |
Is the 930T really worth the cash then if all you get is EPT and more maps, does the 930 have an accelerometer? |
Anita Pocket GPS Moderator
Posted: Mon May 19, 2008 11:52 pm Post subject: Re: Differences between tomtom x30's |
DennisN wrote: | . . . but I won't hold my breath. |
That's the clever thing about tunnels, Dennis. You can go under the water without having to hold your breath!  _________________ Anita
TomTom VIA 135 - App 12.075
UK map 1130.12368
Samsung Galaxy S21 |
Posted: Mon May 19, 2008 11:53 pm Post subject: |
Being a technical dumbo, I've just spent a small age trying to find the relevant post, but couldn't.
I think it was MikeAlder who explained that the 930 has a solid state gyroscope. I have no idea what he was talking about and I may well have got the memory completely wrong. But it DOES have some magic thingy inside to work out where you are by sensing your speed and turns. Allegedly
The 930T is the current top of the range model. It has more memory, more bells and more whistles than all others.
If you're as daft as I am about "more", you want it!! If you want to get from A to B, you don't need such an expensive device. _________________ Dennis
Posted: Mon May 19, 2008 11:56 pm Post subject: Re: Differences between tomtom x30's |
Anita wrote: | DennisN wrote: | . . . but I won't hold my breath. |
That's the clever thing about tunnels, Dennis. You can go under the water without having to hold your breath!  |
Thanks Anita. After 500 miles today, the chuckle was worth coming home for. _________________ Dennis
Posted: Tue May 20, 2008 7:12 am Post subject: |
Dennis, Have another read of This Thread which is the one you were looking for - it was Darren that confirmed the type of gyro - Mike |
Gmonkey Frequent Visitor
Joined: Oct 17, 2005 Posts: 390 Location: Washington DC
Posted: Thu May 22, 2008 9:19 pm Post subject: |
gaj wrote: | Is the 930T really worth the cash then if all you get is EPT and more maps, does the 930 have an accelerometer? |
not really sure about gyroscopes and whatnot, but the 930 has the IQ routes and the advance lane guidance, which are both new features. |
Posted: Thu May 22, 2008 9:23 pm Post subject: |
Gmonkey wrote: | not really sure about gyroscopes and whatnot, but the 930 has the IQ routes and the advance lane guidance, which are both new features. |
As does the 530 and 730. EPT is the only feature the 930 has that the other models cannot offer. _________________ Darren Griffin |
Posted: Thu May 22, 2008 9:49 pm Post subject: |
ah, touche. i misunderstood the question. |
