Newsletter
Pocket GPS World :: View topic - Traffic Module for S series
Gee-Pee
PostPosted: Fri Mar 07, 2008 9:36 pm    Post subject: Traffic Module for S series Reply with quote
Could anyone tell me if the T1 traffic module is compatible with the S series (at least the ones that need it). I ask because, on the Navman Store site (S series) where the traffic modules are for sale, it lists the T1, the T2 and the B2.
I have a spare T1, so if I bought a S70, then I could use the one I have got. Idea
Gee-Pee
xtraseller
PostPosted: Sat Mar 08, 2008 11:33 am    Post subject: Traffic Reply with quote
The Navman store lists T1 Compatability
This unit adds traffic capability to iCN530, iCN720, iCN750, F20, F30, F40, F50,N20, N40i, and the N60i
navmanstores
Better off buying an S90i complete with traffic, so no additional units to carry or buy, and its only 172.99 at mynewcheap or 180 post free at Amazon
And see your T1 on ebay for the 20 difference in S70 to S90, and get the Text to Speech for FREE!
Gee-Pee
PostPosted: Sat Mar 08, 2008 1:06 pm    Post subject: Re: Traffic Reply with quote
navmanstores
Thanks Wink Sensible suggestion Idea
Gee-Pee
TheM
PostPosted: Sun Mar 09, 2008 8:21 pm    Post subject: Re: Traffic Module for S series Reply with quote
S-Series doesn't have that wide port on the bottom like iCN530, iCN7xx, F20+ and N-Series -- instead all S-Series devices and F10 have just USB port that serves both as power connector and expansion connector for new cradles.
Gee-Pee
PostPosted: Sun Mar 09, 2008 8:31 pm    Post subject: Re: Traffic Module for S series Reply with quote
Thanks a lot Laughing
Gee-Pee
PaulRS
PostPosted: Tue Mar 11, 2008 5:46 am    Post subject: Re: Traffic Module for S series Reply with quote
Gee-Pee
You're probably aware, but the traffic cradle for the S-series provides a slightly neater solution in that the TMC aerial cable plugs into the cradle. When the S70 etc is connected then this connects both power and TMC. On the S90i, which has built in TMC, the cradle provides power only and no cable retention for the antenna lead. The antenna then plugs into the headphone socket which is a bit fiddly if you're right handed with a right hand drive car and you can't see the socket
The manual is quite confusing about the TMC antenna in that the setting up diagrams at the front only show the antenna going into the cradle, and the section on TMC only mentions the traffic cradle. This also states that the traffic cradle "may not be supplied with all models".
You really have to dig around to find the bit on the diagrams when describing the headphone socket that tells you that depending on model "this may also be the connection socket for your traffic antenna". I mean, how many people read the description for a headphone socket? The name tends to give it away.
Gee-Pee
PostPosted: Tue Mar 11, 2008 9:05 am    Post subject: Re: Traffic Module for S series Reply with quote
PaulRS wrote:
Gee-Pee
Thanks for that information, Dave. Sounds like the S70 is very similar to the N range where the power and aerial is plugged into the T1 traffic module. Whereas the S90i having a built in traffic device is different.
Gee-Pee
DaveMatthews
PostPosted: Tue Mar 11, 2008 2:39 pm    Post subject: Re: Traffic Module for S series Reply with quote
Does anybody know why the S90i has a headphone socket?
Gee-Pee
PostPosted: Tue Mar 11, 2008 7:16 pm    Post subject: Re: Traffic Module for S series Reply with quote
Could it be so that you can listen to guidance through headphones and not wake you passenger? Both the Navmans I have owned have had headphone sockets and so has my ViaMichelin. ;-)
Gee-Pee
PostPosted: Tue Mar 11, 2008 7:24 pm    Post subject: Reply with quote
Is it actually legal to drive with headphones on, I would think this is a bad idea from a safety point of view, the socket is intended to be used for feeding the Aux input on the car stereo if anything or into an FM transmitter - Mike
Gee-Pee
PostPosted: Tue Mar 11, 2008 8:01 pm    Post subject: Reply with quote
Hi Mike, Firstly I agree that I would never use the headphone socket to use them whilst driving. Very dangerous!
However, this is what the Manual says
"Connection socket for headphones or earphones (not included). To access the socket, gently lift the rubber cover."
Graham
Gee-Pee
20.052 (11 May 22)
Terms & Privacy
