Pocket GPS World :: View topic - 310 deluxe wrong directions~?
gabbyevs
PostPosted: Fri Dec 14, 2007 3:02 pm    Post subject: 310 deluxe wrong directions~? Reply with quote
ive only had my garmin for a month
however on at least 3 different routes the woman has told me to turn the wrong direction completely different to wot they map is showing
the other day i was meant to turn right she said turn left-there was no confusing roads just a straight turn
why does this keep hapening?
luckily ssmeone was with me and said the map is showing right so i took it which was the right way but if i had been alone i would have followed her direction
i think these new navs were meant to be better
PostPosted: Fri Dec 14, 2007 3:57 pm    Post subject: Reply with quote
might be worth reinstalling the voice files... if you use webupdater to update the firmware wit will ask if you want to check for other updates it may have a newer set of voice files.
if not then phone garmin, freephone, and ask them what they plan on doing!
PaulB2005
PostPosted: Fri Dec 14, 2007 5:34 pm    Post subject: Reply with quote
Another tip is to rebuild the voice file. To do this change the voice to English US and then back to English UK. It'll take a while to do each change but it might work.
gabbyevs
thanks i'll try the updater first
Lester_Burnham
PostPosted: Fri Dec 14, 2007 5:45 pm    Post subject: Reply with quote
Is that the same, though, for units like the 310?
My i3 would behave as you suggest, but if I flip-flopped languages on my C510, I wouldn't get any of the processing (at least as far as the unit GUI informs me) that I would on my i3.
I'm not sure all the language handling is the same on the streetpilots as compared with the i3.
gabbyevs
PostPosted: Fri Dec 14, 2007 6:45 pm    Post subject: Reply with quote
updated just said normal update nothing about voice files
is there somewhere i can check for other updates?
PaulB2005
PostPosted: Fri Dec 14, 2007 7:33 pm    Post subject: Reply with quote
Probably not knowing my luck. Was just a SITD, really.
22.052 (08 May 24)
