gabbyevs Regular Visitor
Posted: Fri Dec 14, 2007 3:02 pm Post subject: 310 deluxe wrong directions~? |
ive only had my garmin for a month
however on at least 3 different routes the woman has told me to turn the wrong direction completely different to wot they map is showing
the other day i was meant to turn right she said turn left-there was no confusing roads just a straight turn
why does this keep hapening?
luckily ssmeone was with me and said the map is showing right so i took it which was the right way but if i had been alone i would have followed her direction
i think these new navs were meant to be better |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15144 Location: Bradford, West Yorkshire
Posted: Fri Dec 14, 2007 3:57 pm Post subject: |
might be worth reinstalling the voice files... if you use webupdater to update the firmware wit will ask if you want to check for other updates it may have a newer set of voice files.
if not then phone garmin, freephone, and ask them what they plan on doing!
MaFt |
Posted: Fri Dec 14, 2007 5:34 pm Post subject: |
Another tip is to rebuild the voice file. To do this change the voice to English US and then back to English UK. It'll take a while to do each change but it might work. |
thanks i'll try the updater first |
Lester_Burnham Frequent Visitor
Posted: Fri Dec 14, 2007 5:45 pm Post subject: |
PaulB2005 wrote: | Another tip is to rebuild the voice file. To do this change the voice to English US and then back to English UK. It'll take a while to do each change but it might work. |
Is that the same, though, for units like the 310?
My i3 would behave as you suggest, but if I flip-flopped languages on my C510, I wouldn't get any of the processing (at least as far as the unit GUI informs me) that I would on my i3.
I'm not sure all the language handling is the same on the streetpilots as compared with the i3. |
Posted: Fri Dec 14, 2007 6:45 pm Post subject: |
updated just said normal update nothing about voice files
is there somewhere i can check for other updates? |
Posted: Fri Dec 14, 2007 7:33 pm Post subject: |
Quote: | Is that the same, though, for units like the 310? |
Probably not knowing my luck. Was just a SITD, really. |
