Pocket GPS World :: View topic - I3 firmware 3.20
I3 firmware 3.20
Goto page Previous  1, 2, 3, 4 ... 12, 13, 14  Next
zogman
PostPosted: Wed Sep 20, 2006 4:56 pm    Post subject: Reply with quote
Anita wrote:
zogman wrote:
has anyone noticed that the custom poi's and favorites are still retained in memory when upgarding to v3.2...
They always have been when upgrading - well since March when I got my i3 anyway. It's only when downgrading to an earlier version that Favorites have been lost, but even then I found POIs were retained.
anita/lester ..whenever i've upgraded (not many times} i've not had any poi's loaded , only when i've down graded i've had poi's on ,which i lost...you think you know a bit then you find you dont....
Lester_Burnham
PostPosted: Wed Sep 20, 2006 5:36 pm    Post subject: Reply with quote
Well thinking about it, the POIs are stored on the transflash card - for those i3 owners that have i3s using a transflash card for mapping - as one file: poi.gpi (uncannily enough in a folder called poi). So it's no true suprise that custom loaded POIs survive firmware manipulation - either forwards or backwards.
As to where the favourites are stored, then clearly they must be on non-volatile memory, as I believe a hard reset nukes them.
swanson2
PostPosted: Wed Sep 20, 2006 6:04 pm    Post subject: All Working OK Reply with quote
Upgraded to Firmware Update3.2 yesterday on both our i3's and everything appears to work OK.
All favourites and custom points have been retained as I would have expected.
I will report back after a couple of weeks of testing, but for now it looks as though Garmin have got it about right for me.
Robert Swanson
:D
I have enjoyed the past, but my main interest is in the future, because I am going to spend the rest of my life there!
PostPosted: Wed Sep 20, 2006 6:27 pm    Post subject: Reply with quote
regarding the timings for final prompt before a turn i wonder if it'd be worth a few of us emailing garmin about it and recomending instead of the automatic distance being assumed from the max speed for that road (i.e. if the road is a 60 you get 0.3miles warning even if you're only doing 30mph) that it could be calc'd from the current speed? think that would solve most problems assuming the extra calculation didn't slow things down too much...
PostPosted: Wed Sep 20, 2006 8:32 pm    Post subject: Reply with quote
just been for adrive and i can't quite put my finger on it but the 3d map mode looks different... think it could be zooming out/in more nearjunctions etc.
no probs so far tho
PaulB2005
PostPosted: Wed Sep 20, 2006 8:39 pm    Post subject: Reply with quote
I wonder if it makes a difference if you have memory card or not?
I have a card that came with the i3 and have no problems.
dicko-1
PostPosted: Wed Sep 20, 2006 9:17 pm    Post subject: 3.20 firmware upgrade Reply with quote
have up graded firmware to 3.20 been using it all day I am a truck driver so done plenty of miles and had no problems yet i will let you know if i do
eeny meeny miney mo my i3 knows where to go ?
PaulB2005
PostPosted: Wed Sep 20, 2006 9:34 pm    Post subject: Reply with quote
Agreed. I feel the zoom in and out is "more appropriate" (sorry can't think of a better explanation than that!!!)
mussey1
PostPosted: Wed Sep 20, 2006 9:38 pm    Post subject: Reply with quote
Are you guys usin map view or navigation mode??
Thanks.
Mussey1.
PaulB2005
PostPosted: Wed Sep 20, 2006 10:28 pm    Post subject: Reply with quote
Map only auto zooms in Nav mode.
pathogen
PostPosted: Wed Sep 20, 2006 10:42 pm    Post subject: Reply with quote
I've done about 100 miles since 3.20 update, and everything seems fine so far. They were all regular journeys so only ran in (3D) Map mode. Screen updates seem much smoother, and have not yet seen a freeze or lock up, which was quite a regular thing with 3.10
I'm very pleased with the update, but i'll keep trying different settings to see if I can break it - I can usually find a way Smile
FYI: My unit has maps on a transflash card and 30,500 POI's and about 20 favorites loaded. I have never added any other language files. Audio V.2.00 and GPS mode: normal
mussey1
PostPosted: Wed Sep 20, 2006 11:31 pm    Post subject: Reply with quote
I have once again run two i3's back to back, my own unit with FW3.2 and all PW speed cams installled and a unit from work on FW2.7, again with all speed cams installed.
In 3d map mode my unit was taking approx 33 seconds to update the map. I got the wife to video it on my mobile, as garmin don't seem to be 'aware' of any problems.
Indeed many people on this forum seem not to be having any problems!!!
Is there any way to upload a file onto this forum so others can have a look?
Mussey1.[/img]
PostPosted: Wed Sep 20, 2006 11:34 pm    Post subject: Reply with quote
find somewhere that hosts images for free, somewherelike youtube? do a google for'free file hosting'
PaulB2005
PostPosted: Thu Sep 21, 2006 12:35 am    Post subject: Reply with quote
Just been for a quick drive. In Nav mode all has been fine for the last 2 days.
However 15 minutes in Map Mode and it's lagging like a fat kid on Sports Day. It only updated the last 1/2 mile once i got on my drive. Most of the time it was about 50 meters behind me. Weird thing is the Speedo updates ok but not the map (again).
More tests coming...
Anita
PostPosted: Thu Sep 21, 2006 1:15 am    Post subject: Reply with quote
MaFt wrote:
regarding the timings for final prompt before a turn i wonder if it'd be worth a few of us emailing garmin about it and recomending instead of the automatic distance being assumed from the max speed for that road (i.e. if the road is a 60 you get 0.3miles warning even if you're only doing 30mph) that it could be calc'd from the current speed? think that would solve most problems assuming the extra calculation didn't slow things down too much...MaFt
Good idea, MaFt. I've just sent an email to Garmin.
Anita
TomTom VIA 135 - App 12.075
UK map 1125.12264
Samsung Galaxy S21
Page 3 of 14
22.052 (08 May 24)
