Pocket GPS World :: View topic - tomtom go 910 stuck on the boot up screen
eastlondongary
PostPosted: Sun May 27, 2007 12:33 pm    Post subject: tomtom go 910 stuck on the boot up screen Reply with quote
my tomtom go910 when turned on gets stuck on the bootup screen and will not go any further have left it a while but it will not move
any help please
PostPosted: Sun May 27, 2007 12:38 pm    Post subject: Reply with quote
Have you tried the reset switch yet? - turn the unit over and locate the reset hole (its underneath adjacent to the main electrical connection strip) - use a pin or paper clip to depress the switch - Mike
eastlondongary
PostPosted: Sun May 27, 2007 12:46 pm    Post subject: Reply with quote
tried that mike but still no luck
i can connect it to my laptop but as soon as i take it out of the dock i tries to boot up and gets stuck
PostPosted: Sun May 27, 2007 2:40 pm    Post subject: Reply with quote
Are you 100% sure the reset switch has been depressed? - can you feel the switch click as you press it with a paperclip. The reason I ask is for two reasons, a paperclip with too larger diameter doesn't fit in the hole correctly preventing the actual switch from being pressed.
Secondly there have been reports (not many) of the reset switch breaking. Try holding the reset switch down for at least 30 seconds, then will it boot up? - Mike
eastlondongary
PostPosted: Sun May 27, 2007 2:59 pm    Post subject: Reply with quote
well when i put the paper clip in the screen goes off buti will try the 30 second version
brb to let you know how i get on
eastlondongary
PostPosted: Sun May 27, 2007 3:10 pm    Post subject: Reply with quote
no luck mike tried it for 30seconds still jammed
wa do i do now
PostPosted: Sun May 27, 2007 3:15 pm    Post subject: Reply with quote
How old is the device? and do you have a full back up made with Home (or preferably Windows Explorer) - Mike
eastlondongary
PostPosted: Sun May 27, 2007 6:47 pm    Post subject: Reply with quote
nah aint made a back up yet but can do if i connect it to my lap top
ys this
PostPosted: Sun May 27, 2007 6:52 pm    Post subject: Reply with quote
How old is the unit, if its a few days I would take it back and swap it to be honest, you need a back-up from a working device, its probably not a bad idea to make a back-up but you should have done this prior to the device going wrong - Mike
eastlondongary
PostPosted: Sun May 27, 2007 7:06 pm    Post subject: Reply with quote
if the unit is not fully charged would that make the unit perform like it is
PostPosted: Sun May 27, 2007 7:27 pm    Post subject: Reply with quote
charge state will have a bearing on the problem IF the battery cell is very low, give it a couple of hours on the mains charger then try again.
If its only a few days old (less that 14) take it back and get another one - Mike
madnlooney
PostPosted: Mon May 28, 2007 1:18 pm    Post subject: Reply with quote
mine did this, i had to press the reset switch for 30secs and connect to PC. while on pc i went and reset it to factory settings. when that was done i turned it off. took it out of the dock and turned it on. seemed to fix the problem
eastlondongary
PostPosted: Wed May 30, 2007 8:56 pm    Post subject: Reply with quote
mad
where bouts is the restore to factory settings option when the tomtom is plugged into the pc i cant find it
Oldboy
PostPosted: Wed May 30, 2007 9:17 pm    Post subject: Reply with quote
It's on Page 7 of 7 in Change Preferences.
eastlondongary
PostPosted: Wed May 30, 2007 9:34 pm    Post subject: Reply with quote
old boy thanks for the reply
but when i connect the tom tom to the pc and go into the option of my go910
i only get 3 pages in the change preferences option
and none of them are restore factory settings
any other ideas
23.092 (10 Sep 25)
