Pocket GPS World :: View topic - Garmin StreetPilot C310 - Max Memory Card?
ashleylewisms
PostPosted: Thu Apr 03, 2014 1:09 pm    Post subject: Garmin StreetPilot C310 - Max Memory Card? Reply with quote
Hi All,
I've got a Garmin StreetPilot C310 which has european maps from 2013 preinstalled.
However, I want to get the latest map update which is CN Europe 2014.40 but after doing some research it appears that it's over 3GB in size.
Officially the satnav states it only supports 2GB, however on Amazon there's a listing available for a 4GB SD card:
http://www.amazon.co.uk/Memory-Card-Garmin-Street-Pilot/dp/B006ONJKXU/ref=sr_1_1?ie=UTF8&qid=1396526424&sr=8-1&keywords=streetpilot+c310+4gb
Some third party websites also claim that it's maximum size is 4GB, however from other sites, some users can't get anything bigger than a 2GB working.
If it does support a 4GB card, should I get a class 4 or a class 10?
Thanks guys
Ash
P.S. currently running a 1GB card
PhilHornby
PostPosted: Wed Apr 23, 2014 1:57 pm    Post subject: Better late than never ;-) Reply with quote
See here:-
What is the largest size Secure Digital (SD) card that an automotive device can accept?
http://support.garmin.com/support/searchSupport/case.faces?caseId={18331ce0-4af6-11e3-f27b-000000000000}
(Last updated 15/4/14.)
PostPosted: Wed Apr 23, 2014 2:11 pm    Post subject: Reply with quote
All is not lost though. Run Express and you'll get the option to install the full map to your PC and a map that will fit onto your StreetPilot. You can then load the balance to another card should you need to then swap cards as necessary. So for example you could install UK to device and install parts of Europe onto a card. See here for details
https://support.garmin.com/support/searchSupport/case.faces?caseId={a209e880-9319-11e2-65d0-000000000000}
PhilHornby
PostPosted: Wed Apr 23, 2014 3:15 pm    Post subject: Reply with quote
This web page implies that you have to use Mapinstall to manipulate maps on older devices (I'm guessing it's because newer devices have a different file layout).
But in any case, I don't think the Streetpilot C310 is supported by Garmin Express at all - probably because it used ye olde 'Garmin GPS Mode', rather than Mass Storage or MTP.
(I tried an old StreetPilot C510, where you get a choice of 'Garmin GPS Mode', or Mass-storage. Express only sees the device, when it's using Mass-storage mode.)
PostPosted: Wed Apr 23, 2014 3:40 pm    Post subject: Reply with quote
Yes you do, that's what both our links (which are the same) are saying Wink
But I don't believe it's due to a different map layout, just that Express won't recognise the sd card like it will on newer devices.
PhilHornby
PostPosted: Wed Apr 23, 2014 3:50 pm    Post subject: Reply with quote
When I said "This Web Page", I meant "That Web Page" ...
PostPosted: Wed Apr 23, 2014 5:13 pm    Post subject: Reply with quote
Got you now Smile
