Pocket GPS World :: View topic - no maps found
no maps found
floydzon
PostPosted: Fri Mar 21, 2008 1:42 pm    Post subject: no maps found Reply with quote
A friend has asked me to help with his tom tom one he tried to update it seems he didnt backup first and you've guessed it his comp crashed mid update now his tom tom say's no map data found when he starts it up is there anyway to put my map data in where his has been deleted the folder is still showing on his card and the only thing in it is a file called CurrentMap.dat.
PostPosted: Fri Mar 21, 2008 3:29 pm    Post subject: Reply with quote
The File CurrentMap.dat should be in the Root of the Device.
Is that all that can be seen on the SD Card? If it starts up and says 'Maps not Found', there must be more Files than that. Confused
Have you tried a Reset? Can you identify the Map Folder?
You don't say which TT ONE it is, or which Map he was using.
If you could tell us a bit more then we can start from there. Smile
Although your Map will work on his Device, if the Activation is transferred to his, it will ruin your chances of Updating.
floydzon
PostPosted: Fri Mar 21, 2008 4:39 pm    Post subject: Reply with quote
I think it's a v2 and im not sure about the map as it wont start i can see the map folder if i put the sd card in my card reader,
I tried putting all my tom tom files on a new sd card and when i put it in it seemed to be working but then after it went through the start settings it said no maps found again!
PostPosted: Fri Mar 21, 2008 7:13 pm    Post subject: Reply with quote
Which Files can you see in the Map Folder? That's the crucial thing.
All the other Software Files are free, so are easily obtainable.
In the Map Folder there should be a .pna File. If it's there you can open it with Notepad and it will give you the Map details.
Using the Card Reader is quicker than turning the Device on and off. Wink
Just remember to Right Click the Drive and Select Reject, or use Safely Remove Hardware, in the Sys Tray.
floydzon
PostPosted: Fri Mar 21, 2008 9:12 pm    Post subject: Reply with quote
in the map folder the only thing in it is CurrentMap.dat there is nothing else and the size is only 2 kb but it still didnt work when i put my maps and files on it just came up with the same thing no map.
PostPosted: Sat Mar 22, 2008 7:33 am    Post subject: Reply with quote
That File shouldn't be in the Map Folder. Confused
Right, next thing to check.
What was the Update, that didn't complete? Map or Software?
Was it the original Map on the Card, or has the Map been Upgraded at some stage?
If it wasn't the original Map, there should be an Installation File of the newer Map somewhere on the PC.
floydzon
PostPosted: Sat Mar 22, 2008 11:05 am    Post subject: Reply with quote
After asking the friend he dosent really know as he isnt that computer literate but i think it was just a software update from what he has said and the computer crashed part way through the update and when he tried to start it didnt find any maps.
when it is started it goes to settings every time and the map folder is empty eccept for the one file i mentioned earlyer.
PostPosted: Sat Mar 22, 2008 4:40 pm    Post subject: Reply with quote
I think his only lifeline then, is to phone TT support and hope that they will be able to do something.
The point to make is that it corrupted the SD Card during an Update to the Software. I hope it's the original TT SD Card as they will want that back before they do anything.
0845 1610009 is the number for the UK.
Just goes to show the benefit of having a Full Explorer Backup. Wink
