Pocket GPS World :: View topic - Sound levels of Speed camera warnings
LeighB
PostPosted: Tue Feb 01, 2005 10:33 pm    Post subject: Sound levels of Speed camera warnings Reply with quote
I had my first real jouney using TTN3 today, it was great, my only minor problem is that although the direction instructions are clearly audible (delightful Dutch lady) the speed camera warnings were very quiet.
Excellent system though.
Is there any way to tweak the sound up for the speed warnings without the other directions being too loud?
Leigh
Pocketgps
PostPosted: Tue Feb 01, 2005 11:36 pm    Post subject: Reply with quote
Hello Leigh
You can try using windows sound recorder, move the files from your nav system to your main pc, then open them one at a time and on the Effects menu you can increase the volume in 25% steps, doing it a couple of times usually works OK, them just move them back to your nav system again.
You can also find some sound files on my web site, if you are using broadband you can click the link at the bottom of the page and listen to each sound file, it will work will dial-up, but may take several minutes to load.
http://www.sim98.freeserve.co.uk/AMN/sound.htm
LeighB
PostPosted: Tue Feb 01, 2005 11:52 pm    Post subject: Reply with quote
Thanks,
I will try that the levels just need increasing enough so that i can be sure of hearing them.
leigh
