Pocket GPS World :: View topic - POI coordinates
POI coordinates
cdelecole
PostPosted: Thu Jan 06, 2005 3:03 pm    Post subject: POI coordinates Reply with quote
Hi there !
I'm currently building a list of POI's using POI Edit.
I'm using different ov2 sources on the internet to mege them into 1 POI ov2 file.
When appending each individual POI file into my main ov2, I see some items with like this :
Item 1 : 4.33465 - 51.04169
4 20' 5" - 51 2' 30"
Item 2 : 4.33470 - 51.04160
In other words in the decimal format, the numbers are the same, and in degrees, there are different (This is probably due to the convertion).
Ehat happens If I'm using both 2 items in the same ov2 file ?
Will the 2 items be displayed on my road, with a slight distence between both ?
Will that create a bug ?
What happens when a POI is not located on the road itself, but with a slight difference ?
Will TOMTOM show it to me ?
Thanks !
Oldie
PostPosted: Thu Jan 06, 2005 5:30 pm    Post subject: Reply with quote
Converting 4 20' 5" - 51 2' 30" gives 4.33472 and 51.04167 so strictly both of the conversions given by you are incorrect.
Having 2 entries very close together will not cause a problem in TomTom, but you could use my POIManager program in the Downloads area to scan any file that you produce for duplicates within a specified radius. You will have the option to keep or delete a duplicate when a match is found.
Various TomToms, Garmin eTrex Legend, GPSMAP 60CSx, Oregon 550t, Forerunner 405
cdelecole
PostPosted: Sun Jan 09, 2005 11:38 am    Post subject: Reply with quote
Thanks for the reply !
I'll give a try to your POIU lanagement program.
The coordinates translations I gave in my first post were given by the POIEdit Program (freeware).
P.s. : Do you know about any way we could "see" the POI's I would have in an ov2 file on a MAP on PC ?
Thanks !
rkm_hm
PostPosted: Sun Jan 09, 2005 4:59 pm    Post subject: Reply with quote
A similar question has cropped up in another thread - either in this forum, or on Usenet - can't remember which.
I know of no way way of displaying TomTom's maps on a PC per se - they seem to be encrypted in some way.
However, if you've got AutoRoute, you can convert TomTom POI's to AutoRoute PushPins - and display these on an AutoRoute Map (virtually identical to a TomTom map) on a PC.
