Pocket GPS World :: View topic - Deleting Pre Installed POI's
VeloVenom
PostPosted: Wed Jan 05, 2005 5:30 pm    Post subject: Deleting Pre Installed POI's Reply with quote
I have found that by renaming the DAT file (blue notepad) named 'poi' located in the Great Britain map folder the pre installed POI's are prevented from loading. The unit appears to work normally after this. I would suggest you copy the SD card to disk before renaming the file. None of the pre installed poi's load but all the ones I have added work as normal. Rename back to 'poi' to revert to normal
Brad
rkm_hm
PostPosted: Wed Jan 05, 2005 8:39 pm    Post subject: Reply with quote
The Major Roads of Europe (MRE) maps supplied on CD don't have any POI's - but they do have a small (dummy?) POI file. You could probably copy that to the Great Britain directory?
Pity you can't save memory by getting rid of selected categories of Pre-Installed POIs
22.051 (01 May 24)
