Pocket GPS World :: View topic - silly problem, probably an easy fix available
sonypc100
PostPosted: Sun Dec 05, 2004 4:13 pm    Post subject: silly problem, probably an easy fix available Reply with quote
If you list your favourites on the TTG, then you get about 7 or 8 on the screen, however press the icon to get the keyboard then the keyboard appears and you get just 2 favourites at the top.
How do you change back???? How do you lose the on screen keyboard again?
Its driving me nuts!
cheers
rich
sgould
PostPosted: Sun Dec 05, 2004 4:36 pm    Post subject: Reply with quote
You can only go back two steps, Hit the "back" button and go back and select the Favourites again.
A slight improvement can be had. Go to "Change Preferences" Hit forward arrow 4 times. Select "Use smaller keyboard" in top left. Then you will see 3 lines above the keyboard instead of 2.
Why do you use the keyboard in favourites? You can only have 20 (I think) so you would only need to hit the scroll buttons, on the right of the full page list, 2 or 3 times to get through the lot.
sonypc100
PostPosted: Mon Dec 06, 2004 1:00 pm    Post subject: Reply with quote
Thanks!
it was a mistake I was supposed to be tapping the bottom favourite in the list and hit the keyboard icon by mistake, shame its not as easy to remove as it is to display!
cheers
rich
22.053 (15 May 24)
