Pocket GPS World :: View topic - Map coordinates confusion - UK Based
docramage
PostPosted: Tue Sep 11, 2018 6:41 pm    Post subject: Map coordinates confusion - UK Based Reply with quote
Researching different map co-ordinate systems suggests there are multiple ways of expressing Lat & Long in figures alone. There is no advice saying which format is default for Sat Navs (mine is Garmin - which offers 7 options).
Furthermore, if I enter a pair of numbers (in any of the formats) into Google Maps, or BaseCamp, and several others, the locations displayed are nowhere near where I expect - sometimes they are many miles off.
Can anyone advise me:
Which format is most likely to be default. So far I have tried h ddd* mm' ss.s", h ddd.ddddd*, h ddd* mm.mmm' (where * represents the character for Degrees. None works well
Should I expect a correct format to display within say 50 feet ?
Many thanks for anyone helping
Philip
PostPosted: Tue Sep 11, 2018 6:58 pm    Post subject: Reply with quote
The correct format will show the correct location. How close it is to the actual position will vary as some formats allow truncation of digits. There is no 'default' that everyone adheres to.
Your Garmin has no 'default'. Not only can you select a number of lat/long formats but many others as well, eg British National Grid
PostPosted: Wed Sep 12, 2018 12:58 pm    Post subject: Reply with quote
In some systems, it's not necessarily WHAT you enter, more HOW you enter it.
e.g. Ndd mm sss, Wdd mm sss. Those are just guesses because I use the decimal format. And in MY useage, I don't enter N or W, entering a plus figure gives a North location, minus would be southern hemisphere. Similarly, positive W is East of 0, so for example a lot of locations in UK (west of Greenwich) require a minus entry. As an ignoramus in these matters, I don't know what your h stands for (please don't explain, I won't understand).
Furthermore, in the systems I use, there must be no space between the two figures, only a comma.
If you are getting results nowhere near where you expect, you are entering the data wrongly.
Kritou
PostPosted: Wed Sep 12, 2018 2:15 pm    Post subject: Reply with quote
Because our Earth is not a perfect sphere different datums have been, and still are, used to best define the local area
For the Global Positioning System the WGS 84 (World Geodetic System 1984) datum is used. Many GPS receivers will offer a choice so it is important to ensure your device has the correct one selected in the settings menu
PostPosted: Wed Sep 12, 2018 2:23 pm    Post subject: Reply with quote
Choosing a certain lat/long format in your Garmin will select the correct datum of WGS-84
docramage
PostPosted: Thu Sep 13, 2018 5:15 pm    Post subject: Reply with quote
Many thanks
Philip
jad12
PostPosted: Wed Sep 26, 2018 4:16 am    Post subject: Reply with quote
Hi all
As for plot/input of a GPS lat/long not showing where you really are Kritou is dead right. Different regions have different datums based on different best fit spheroids. Many designed years and years ago.
GPS works on a WGS84 global best fit spheroid that clever guys at sums have worked out. In the UK we have OSGB on the Airy 1830 spheroid. Best fit for UK.
if you plot WGS84 lat/long on OSGB you will be out. It varies over the UK but around London it's about 100m different.
I would expect/hope that a GPS position input to your satnav would put you where (within accuracy specs) you really are. UK maps are likely originally based on Ordnance Survey maps so either some software in you satnav transforms or datum shifts WGS84 to OSGB or the OSGB map is shifted to match 84 and hence the likes of Google Earth and Maps. The sums are horrible. If this difference is not sorted somehow I would say your satnav map is a broken pencil......pointless.
As for input formats, yes everyone right. Most mapping stuff will take many ways of input.
However the h. Like DennisN, I'm lost. I've never seen it in 40 years of navigating. I may be missing something so would be grateful for an explanation.
Ladies/Gentlemen, this type of stuff has come up before. If there is interest I could come up with and post a short pdf to explain these things a bit more.
cheers
A school of dolphins A flock of birds A pride of lions A lost of navigators
