Pocket GPS World :: View topic - Camper 770LMT-D: Diacritical mark POI problem
Goto page Previous  1, 2, 3
PhilHornby
PostPosted: Mon Jan 08, 2018 4:39 pm    Post subject: A snippet from the Web Reply with quote
I found this in the official Garmin forum, which intrigued me...
Code:
Tried to import POIs from Alpenrouten.de however they are encoding to ISO-8859 but POI loader (on Mac) needs UTF-8 to properly handle Umlauts. Simply use this command line on a Mac to fix the files (in case the original is ISO-8859 - use "file <filename>" to see the encoding)
iconv -f iso-8859-1 -t utf-8 < Hochpunkt.csv > Hochpunkt.utf8.csv
I don't know what "iconv" is, but the post implies that Mac POI Loader does understand (and translate) UTF-8 encoded CSV files.
(To recap - on Windows, POI Loader just passes the text from CSV files through to the GPI file. If you try and tell POI Loader that the file is encoded using UTF-8 (by adding a BOM), it rejects the file completely. If you encode the file as UTF-8 and don't include a BOM, the UTF-8 data will end up on the Nüvi and will not display properly - it only understand Windows-1252/ANSI)
pcaouolte
PostPosted: Mon Jan 08, 2018 6:13 pm    Post subject: Reply with quote
iconv is a command-line program in unix and similar operating systems, used to convert between different character encodings. I don't know if it is available on the Mac but it seems likely that it is.
So in your example above it would convert the Hochpunkt.csv file from iso-8859-1 to utf-8 and write the output into a new file called Hochpunkt.utf8.csv
So you are correct that this implies that the MAC version of POI loader should understand UTF-8 encoded csv files.
Paul
PhilHornby
PostPosted: Mon Jan 08, 2018 7:02 pm    Post subject: Reply with quote
pcaouolte wrote:
iconv is a command-line program in unix and similar operating systems.
It's odd, what you find lying around Smile
Code:
 Directory of c:\Program Files\Git\usr\bin
04/11/2014  19:11            30,004 iconv.exe
               1 File(s)         30,004 bytes
PhilHornby
PostPosted: Tue Jan 09, 2018 3:05 am    Post subject: Reply with quote
Privateer wrote:
Would it be possible to try another test with several POIs within one file, each with a diacritical mark in the actual name?
(CORRECTED!) Link to a zip file: https://www.dropbox.com/s/uednkijdtao9pei/V4.zip?dl=0
Contains a pre-built .GPI file - copy to your Nüvi to see what it should look like when built 'properly' Wink
There's two files - a simplistic ANSI encoded CSV file and a UTF-8 encoded (with BOM) GPX file. Each entry has a special character in its name ... and I've filled every field I can think of (so you should see an attached JPEG) and if you were to simulate a drive past each POI, an alert should sound. Pair your phone and it should offer the ability to make a call too Cool
I think the GPX version has a reference to every field in Garmin's schema, that (Windows) POI Loader understands.
PostPosted: Tue Jan 09, 2018 9:39 am    Post subject: Reply with quote
Will you please give us a list of aforementioned fields?
PhilHornby
PostPosted: Tue Jan 09, 2018 1:16 pm    Post subject: Reply with quote
That would be quite a big job; but a bit of a summary :-
The .GPI format has lots of fields that POI Loader can't access (for example, think how Garmin-supplied speed camera alerts display, compared with ones you've built yourself). Equally there are elements in the schema that aren't relevant to Custom POIs (Route/Track info for instance).
Thinking about it, my test file doesn't demonstrate Speed-related alerts, nor per-POI custom icons, nor TourGuides (circular, rather than along-route proximity alerts, who's audio you can control).
There are other things that POI Loader understands, but ignores - such as the date/time that a POI was last edited.
Here's a sample POI (I had to mangle the brackets to get the forum to accept them) :-
Code:
     <wpt lat="53.000000" lon="-2.000000">
        <ele>0.00</ele>
        <time>2018-01-09T12:01:46Z</time>
        <name>Nüvi</name>
        <cmt> </cmt>
        <desc>This is the description field ¼½¾</desc>
        <link href="enhancements"/>
        <sym>Information</sym>
        <extensions>
            <gpxx:WaypointExtension>
                <gpxx:Proximity>402.0</gpxx:Proximity>
                <gpxx:DisplayMode>SymbolAndName</gpxx:DisplayMode>
                <gpxx:Address>
                    <gpxx:StreetAddress>Street Addr 1 ¼½¾</gpxx:StreetAddress>
                    <gpxx:StreetAddress>Street Addr 2 ¼½¾</gpxx:StreetAddress>
                    <gpxx:City>City ¼½¾</gpxx:City>
                    <gpxx:State>State ¼½¾</gpxx:State>
                    <gpxx:Country>UK</gpxx:Country>
                    <gpxx:PostalCode>PostCode ¼½¾</gpxx:PostalCode>
                </gpxx:Address>
                <gpxx:PhoneNumber Category="Phone">012345</gpxx:PhoneNumber>
                <gpxx:PhoneNumber Category="Phone2">67890</gpxx:PhoneNumber>
                <gpxx:PhoneNumber Category="Fax">1234</gpxx:PhoneNumber>
                <gpxx:PhoneNumber Category="Email">bill@microsoft.com</gpxx:PhoneNumber>
            </gpxx:WaypointExtension>
        </extensions>
    </wpt>
One thing I haven't mentioned, is that the Nüvi supports GML (Garmin Markup Language) - an HTML like syntax, that lets you specify text colour and such like. If you hunt around the Nüvi's file system, there should be some .GML files to use as examples.
PostPosted: Tue Jan 09, 2018 5:20 pm    Post subject: Reply with quote
I meant the easy ones like lat, lon, name etc. as in a .csv file.
Privateer
PostPosted: Thu Jan 11, 2018 2:46 pm    Post subject: Reply with quote
Hi Phil
V4.gpi gives us two POI categories, CSVfile a "simplistic" ANSI encoded CSV file and GPXFile a UTF-8 encoded (with BOM) GPX file. Both files have the same following individual POIs:
  1. Çomewhat confused
  2. Fenêtre
  3. £ > €
  4. moög
  5. Café
  6. Nüvi
Whilst the ANSI encoded CSV file looks good, the UTF-8 encoded (with BOM) GPX file is much better as it has more fields and even the attached JPEG image.
I haven't been able to simulate a drive by yet, so I haven't experienced the alert - which would be useful for my Jersey POIs.
Unfortunately, the big thing is that with both files is that you still have to use the correct diacritical marks to search. So if I'm searching for "Çomewhat confused" I have to use "Çomewhat" instead of the non diacritical marked "Comewhat". This is a Garmin issue as the search function isn't language independent.
Robert.
Garmin Camper 770 LMT-D
Page 3 of 3
22.052 (08 May 24)
