Pocket GPS World :: View topic - New DriveSmart 50LMT-D not starting up.
pcaouolte
PostPosted: Fri Jan 20, 2017 9:34 am    Post subject: New DriveSmart 50LMT-D not starting up. Reply with quote
I'm new to Garmin having got my first Garmin PND today a DriveSmart™ 50LMT-D
I have plugged the device into power (a desktop usb charging station) and it displays a startup screen with a battery symbol with a lightning bolt through it and the Garmin logo below that. Its been like this for 10 minutes now. If I disconnect it from the power it briefly shows a red battery almost empty symbol and then shuts down.
Is this normal?
Paul
Paul
PostPosted: Fri Jan 20, 2017 9:37 am    Post subject: Reply with quote
Sounds like it's out of battery.
USB can charge it but at the level you describe that's going to take a few hours.
Best is to plug it into the car, the car cable charges much faster.
Satnav:
Car Average MPG :
pcaouolte
PostPosted: Fri Jan 20, 2017 9:38 am    Post subject: Reply with quote
Thank you.
I will try that. It's cold out there Very Happy
Paul
Paul
PostPosted: Fri Jan 20, 2017 9:47 am    Post subject: Reply with quote
Yep, needs a good charge. If you can fastest way is to charge from the mains ... next the car ... Wink
pcaouolte
PostPosted: Fri Jan 20, 2017 10:04 am    Post subject: Reply with quote
Thank you both. When connected to the car charger it started up straight away to the Where To screen. Very Happy
Now that I have brought it back into the house it also starts up on the mains charger.
Next job, get a backup, before I mess anything up. Shocked
Paul
walkerx
PostPosted: Fri Jan 20, 2017 10:53 am    Post subject: Reply with quote
if you can you can also plug directly into a mains adaptor to charge it
pcaouolte
PostPosted: Fri Jan 20, 2017 11:01 am    Post subject: Reply with quote
Thank you. I have several mains USB adaptors here which I can try.
I have taken a backup following sussamb's excellent instructions here: http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=95950&highlight=backup.
The device is currently connected to Garmin Express and downloading lots of updates. The first one failed (I don't know what it was), the second was successful (device software I think) and its now updating maps. It says that this operation is going to take another 4 hours and 6 minutes. Rolling Eyes
Paul
PostPosted: Fri Jan 20, 2017 11:04 am    Post subject: Reply with quote
Well the time depends on many factors, but generally I find mine take under an hour ... I'm on Virgin broadband with a 70 Mbs pipe ...
I suspect that 4 hours will reduce considerably unless you have a really slow connection.
Well done on the backup, hopefully you'll never need it but always worth doing just in case ... Wink
pcaouolte
PostPosted: Fri Jan 20, 2017 11:08 am    Post subject: Reply with quote
My connection is nearer 7Mbs than 70Mbps Exclamation
The countdown is progressing in about real time so I suspect that the 4 hours may be real. I'm wondering if it will keep going when the computer goes into power saving mode, I may disable that to give it a better chance.
Thank you for the backup instructions, I could only see part of the file system on the device before I found the instructions.
Paul
PostPosted: Fri Jan 20, 2017 11:15 am    Post subject: Reply with quote
Don't let the power save mode kick in, I've always found even the screensaver cuts it off.
Wiggle the mouse every so often.
Also, regardless of your BB speed the download seems to come in at 3Mbps so keep an eye on it. 50% of the progressbar is the download and the other 50 is the building files and install.
Garmin minutes are much like Microsoft minutes.
Satnav:
Car Average MPG :
pcaouolte
PostPosted: Fri Jan 20, 2017 11:20 am    Post subject: Reply with quote
I've switched off the powersave mode and the screensaver. I cant wiggle the mouse for the next 4 hours as my wife wants me to take her out for lunch. Seems reasonable after she bought me a new Garmin Very Happy
Paul
walkerx
PostPosted: Fri Jan 20, 2017 11:21 am    Post subject: Reply with quote
and if you are running windows 10, it can be a bit picky with updating if windows is downloading its own updates in the background.
but it is best to disable the power saving options while performing the update - it is also faster at updating than the TomTom devices.
22.051 (01 May 24)
