Pocket GPS World :: View topic - 2017.30 available.
2017.30 available.
PostPosted: Thu Jan 05, 2017 3:33 pm    Post subject: Reply with quote
Nope that's not me
What with Basecamp and now this you're going through the wars
Satnav:
Car Average MPG :
PostPosted: Thu Jan 05, 2017 3:43 pm    Post subject: Reply with quote
Neither are real issues for a pro like me Wink
PostPosted: Thu Jan 05, 2017 4:19 pm    Post subject: Reply with quote
Very Happy
Unless I'm mistaken you can no longer change map regions ?
On both devices all I get is the option to upgrade the maps 'on the device'
I wanted to switch the 2599 to UK & I
Satnav:
Car Average MPG :
PostPosted: Thu Jan 05, 2017 4:41 pm    Post subject: Reply with quote
Yes if there's space you have no option but to accept the full map. You can fool Express though by placing other files there so that there isn't space for the full map, then you get to choose a region Wink
PostPosted: Thu Jan 05, 2017 4:52 pm    Post subject: Reply with quote
OK, no problem.
I'll stick with the full Europe this time round.
Satnav:
Car Average MPG :
PostPosted: Thu Jan 05, 2017 7:26 pm    Post subject: Reply with quote
This is now fixed. For those interested Garmin have now split the map into two, one part is placed by Express into the .system folder and the other into a folder named Map if there is sufficient room on the device. If not then the files are split on a sd card, between the Garmin and Map folder.
PostPosted: Fri Jan 06, 2017 5:30 am    Post subject: Reply with quote
So if like me you don't want to use a SD card how does it decide which of the 2 maps you get, do you get a choice?
For us the best option is to have the region with the UK on the device.
Also, not that I want to change, my 2597 is now stuck on UK&I because that is the installed map set.
Satnav:
Car Average MPG :
PostPosted: Fri Jan 06, 2017 7:47 am    Post subject: Reply with quote
Yes, if you don't want to use a card you get a choice of what you do want to install to the device, just like before.
Unsure what you mean by 'stuck with the UK&I map'. If your 2597 came with a larger map set you can reinstall that if you want to? Or am I misunderstanding your comment? See this FAQ
https://support.garmin.com/faqSearch/en-US/faq/content/dyYgXK9i6C3FkS9sU5xDcA
BAVC10
PostPosted: Fri Jan 06, 2017 9:59 am    Post subject: Reply with quote
Full Europe now shows (for me at least on a DriveLuxe 50) as 7.69 Gb rather than the 4.24 Gb it showed on GE yesterday - seems to have been fixed :-)
DriveLuxe 51 LMT D - Firmware 6.70
Previously owned: DriveLuxe 50 LMT-D, NuviCam LMT-D, Nuvi 3598 LMT-D, Nuvi 3490LMT, 3790T, 1690, 765, 760, 660, 610, 360, 310, 300 and Streetpilot i3
PostPosted: Fri Jan 06, 2017 10:11 am    Post subject: Reply with quote
I updated the 2597 yesterday and it gave me no option to change back to EU maps.
Possibly will do now I'm up to date.
Not fussed though, only need blighty
Satnav:
Car Average MPG :
PostPosted: Fri Jan 06, 2017 10:50 am    Post subject: Reply with quote
Yes, you have to be up to date first, then you get the option to change regions ...
BAVC10
PostPosted: Fri Jan 06, 2017 3:22 pm    Post subject: Reply with quote
Interestingly, having installed to the hard drive on my PC as well, 2017.20 was 6.90 Gb whereas 2017.30 is only 4.87 Gb so I wonder if Garmin haven't quite fixed the issue yet. Even allowing for compression that's quite a file size reduction.
PostPosted: Fri Jan 06, 2017 3:46 pm    Post subject: Reply with quote
Not sure what you're seeing but the previous map was under 4GB ... the current one just over.
Certainly the map update issue is fixed, I've updated my device and verified everything using JaVaWa's Device Manager and Garmin's BaseCamp.
dales
PostPosted: Fri Jan 06, 2017 8:19 pm    Post subject: Reply with quote
OK I've got the new maps of All Europe, albeit now in two pieces.
But my new JCV file is half its previous size, so I must be missing, say, all of South Europe's Junction Views.
And my new SID and SQLITE files are also only half their previous sizes, so I've been shortchanged here as well, it seems.
Dales.
PostPosted: Fri Jan 06, 2017 8:48 pm    Post subject: Reply with quote
You should have 2 jcv files ... One for each map
Page 2 of 4
22.051 (01 May 24)
