Pocket GPS World :: View topic - Route issue in France
Wizzardoz
PostPosted: Mon Aug 08, 2016 11:07 am    Post subject: Route issue in France Reply with quote
Last week I used my 2699 in France and it worked straight away. The problem I had was that it kept on using side roads (i.e. not using motorway) roads at times although I wanted it to use Motorway. Is this because it was trying to use a fuel efficient method?
Is there a way to force it to use Motorway? I see there is an option to avoid motorway but not force it to use it.
Also, can I get to get to a town? It kept on insisting on a road and number.
PostPosted: Mon Aug 08, 2016 11:43 am    Post subject: Reply with quote
Were they toll roads? If so is your device set to avoid tolls?
As for towns, just do a where to, towns ... if towns doesn't show click on Where to, personalise and add Towns
BigJohnD
PostPosted: Mon Aug 08, 2016 12:02 pm    Post subject: Reply with quote
As Sussamb said.
Some of us, sadly, have tolls as part of daily travel, and have Tolls enabled permanently. (Mersey Tunnel)
And when I had my money and wallet stolen in Spain, I can vouch for the fact that the Garmin is very good at keeping you off toll roads when Tolls is disabled!
PostPosted: Mon Aug 08, 2016 12:06 pm    Post subject: Reply with quote
Sorry you had to learn it that way Crying or Very sad
Wizzardoz
PostPosted: Mon Aug 08, 2016 5:12 pm    Post subject: Reply with quote
The toll roads was left on to accept toll roads.
I tried to put in town name but it still wanted a number and road. I ended up choosing random addresses!
PostPosted: Mon Aug 08, 2016 5:44 pm    Post subject: Reply with quote
It won't if you do a Where to, Towns instead of what you're doing which is Where to, Address Very Happy
Be careful, if you think avoidance is On that means it will avoid them. They need to be unchecked.
Wizzardoz
PostPosted: Mon Aug 08, 2016 6:15 pm    Post subject: Reply with quote
My error! It was unchecked.
PostPosted: Mon Aug 08, 2016 6:25 pm    Post subject: Reply with quote
If it was unchecked then I'm out of ideas. Can you give us the start and end points of your route so we can see what is happening?
Wizzardoz
PostPosted: Mon Aug 08, 2016 6:39 pm    Post subject: Reply with quote
I was returning from rue du Perigord Vert, 24270 Payzac to Junction 7 on N89 (near Bordeaux. Iexpected it to take me via A89 / N89. Strange thing is that going to 24270, I was taken via N89 / A89.
Also on a different day, travelling from Libourne to junction 7, it did the same thing.
PostPosted: Mon Aug 08, 2016 7:12 pm    Post subject: Reply with quote
Thanks. Will have a look later as about to attend a committee meeting Smile
PostPosted: Mon Aug 08, 2016 9:36 pm    Post subject: Reply with quote
Well it takes me along the A89/N89 both ways. The only way I can get it not to do so in part is if I select to avoid tolls.
Wizzardoz
PostPosted: Tue Aug 09, 2016 7:16 am    Post subject: Reply with quote
Setting is NOT to avoid tolls. Only thing I can think of is that Calculation mode is set to Shorter Distance (as opposed to Off road or Less Fuel). Perhaps Less Fuel may be the option.
PostPosted: Tue Aug 09, 2016 7:30 am    Post subject: Reply with quote
If it is set to shortest I'm still surprised it avoids the autoroute, I've just tried that setting on mine and the route barely alters, just takes the D705 between Perigeux and Payzac rather than following the D704 from/to the A89. Are you able to post a screenshot of the route just so I can compare it to what I'm seeing?
It's possible the 'do not avoid tolls' setting has stuck and you need to master reset your device.
Wizzardoz
PostPosted: Tue Aug 09, 2016 8:12 am    Post subject: Reply with quote
Strange! Tried the simulation back here in UK and it took the Motorways! Not sure what went wrong last week in France - just wish I can go back there to try it out again Very Happy
Thanks for your help.
PostPosted: Tue Aug 09, 2016 8:37 am    Post subject: Reply with quote
Laughing
Ah well, going to be one of those I guess Very Happy
22.051 (01 May 24)
