Pocket GPS World :: View topic - Directories on XL Live
h5djr
PostPosted: Mon May 30, 2016 12:03 pm    Post subject: Directories on XL Live Reply with quote
On my current XL Live device I have two directories that are very similar. One is called Western_Europe and the other Western and Central_Europe _ 2GB. These two directories seem to have many of the same files in each. Does anyone know if both of these are required. This does seem to create a problem with running out of space when I upgrade to the latest map. Many thanks
Dave R (h5djr)
TomTom XL + Audi A3 (with navigation)
justbrowsing
PostPosted: Mon May 30, 2016 12:14 pm    Post subject: Reply with quote
These are 2 totally separate map FOLDERS covering different countries.
Can you open then copy/paste the contects of the 2 *****.pna files (one in each map folder) so we can see which is newer?
h5djr
PostPosted: Mon May 30, 2016 12:35 pm    Post subject: Reply with quote
Only the Western_Europe directory has a .pna file in it. The contents of that file read:
ID=Western_Europe.pna
801299332955
build=6805
id=1974589
Both directories have all the same POI files for my chosen POIs and for the PGPSW camera files, both bmp and ov2 files. Am I right in thinking I can delete all the POI files from the directory that does NOT contain the Western_Europe.pna file
Dave R (h5djr)
AliOnHols
PostPosted: Mon May 30, 2016 10:01 pm    Post subject: Reply with quote
Which of the two maps are you using to navigate with?
I don't remember the sequence but tapping the Satellite meter bars in the main screen afew times brings up the map/system info. do that, make a note and then change maps , repeat and compare details. then make an informed decision about which one to use and which to archive.
I f both maps work, I would prefer to use the larger Western &Central Europe. unless of course you have no desire to go to central Europe. if so, cut and paste the whole folder to your computer.
Garmin Nuvi 2599
SatMap Active 10 & 20.
22.044 (24 Apr 24)
