Pocket GPS World :: View topic - Update for nuvis 2xx7 and 2xx8, and 35x7 and 35x8
Goto page Previous  1, 2
PostPosted: Sun Jan 10, 2016 10:16 am    Post subject: Reply with quote
I'd try a master reset first, rather than roll the firmware back.
Allan_whoops
PostPosted: Sun Jan 10, 2016 10:46 am    Post subject: Reply with quote
I did a master reset immediately after the upgrade so this is happening since then. I did all the obvious like checking the power cord etc.
PostPosted: Sun Jan 10, 2016 11:41 am    Post subject: Reply with quote
To roll back you need a copy of the previous .gcd file. If you don't have one pm me your email address and I'll send it to you with instructions.
As I said though mine is working fine Confused
Allan_whoops
PostPosted: Sun Jan 10, 2016 12:16 pm    Post subject: Reply with quote
Thanks for this. I took a backup in October. I have a GUPDATE.GCD in .System and lots of little ones in .System\RemoteSW such as 006B154600.gcd
PostPosted: Sun Jan 10, 2016 12:35 pm    Post subject: Reply with quote
To roll back replace the current gupdate.gcd with a previous one. When you start the nuvi you'll be warned that you're using an earlier version, just accept and it'll install the older firmware.
Allan_whoops
PostPosted: Sun Jan 10, 2016 12:47 pm    Post subject: Reply with quote
I really use the unit for the traffic so many thanks to say the least!
PostPosted: Sun Jan 10, 2016 1:02 pm    Post subject: Reply with quote
Hope it resolves it then Very Happy
PostPosted: Sun Jan 10, 2016 3:11 pm    Post subject: Reply with quote
Seems that there are others with the traffic power cable 'problem'. Mt 2569 is fine after the update. I wonder what's going on.
wibbley
PostPosted: Fri Mar 18, 2016 6:12 pm    Post subject: Reply with quote
just bricked my 3598.
Any ideas?
Started Garmin Express, which said there was an update & to connect sat-nav. I did this, GE said update would take 1 hour 39 minutes, however in just a few minutes the screen said to restart my nuvi 3598.
Followed these instructions, disconnected sat-nav from pc, pressed the power button, unit started with 'Garmin' splash screen then after a minute, screen goes blank.
Left it for ages, nothing happened. Tried turning on again, it needs the power button held in for quite a while, then upon releasing, will show the splash screen again, then go blank.
Thanks all.
PostPosted: Fri Mar 18, 2016 6:16 pm    Post subject: Reply with quote
That's a pain. Did you do a safe eject or just pull the plug?
What will possibly have happened is that the gupdate.gcd file will have corrupted, or maybe a different file depending on what the update was.
Try googling garmincure3 Wink
wibbley
PostPosted: Sat Mar 19, 2016 11:47 am    Post subject: Reply with quote
Held the power button in for 30 seconds, upon release the splash screen popped up.
It was connected to the pc, so it immediately went into tethered mode (or whatever it is called),
I ran garmin express. It found the sat-nav, did two sw updates then allowed me to update the map, grumbling that the sd card was too small, so loaded just UK map.
Ta all.
W.
Page 2 of 2
22.044 (24 Apr 24)
