eddieo Regular Visitor
Posted: Tue Dec 16, 2014 10:47 am Post subject: PC won't recognise 2547 for updates |
trying to add some more POI files and update maps but whatever I do PC wont recognise the Nuvi device?...help! |
sussamb Pocket GPS Verifier
Joined: Mar 18, 2011 Posts: 4456 Location: West Sussex
Posted: Tue Dec 16, 2014 10:54 am Post subject: |
Are you using the Garmin cable? Also connect directly to a USB port and not through a hub. _________________ Where there's a will ... there's a way. |
Posted: Tue Dec 16, 2014 11:32 am Post subject: |
No...have never had a garmin cable? have been doing this for years with various units without a problem.
if i need one so be it.......where can i get one |
Posted: Tue Dec 16, 2014 12:05 pm Post subject: |
It should have come with your nuvi? I know some 3rd party cables cause issues.
Other trick you might try is ensure your nuvi is in mass storage mode, it won't be and will be in mtp mode unless you've changed it. To switch it to mass storage mode:
1. Start NUVI by itself and go to Volume Screen.
2. Press the upper right hand corner of screen for 10 seconds.
3. The Developers Screen will pop up
4. Scroll down to MTP SETTINGS
5. Change from AUTO DETECT to MASS STORAGE
6. Shut down NUVI and connect to PC
7. It should now connect in mass storage mode.
As an alternative to step 1 above, you can bring up the Nuvi's "dashboard" screen, then press and hold the speedometer for about 10 seconds to access the developer screen. _________________ Where there's a will ... there's a way. |
Posted: Tue Dec 16, 2014 12:23 pm Post subject: |
it was already in mass storage mode (think you helped me with this before)
still no go..found the short lead that came with recent refurbished edge 800 and that don't work either
Also, when i unplug it it freezes and does not restart automatically. have to shut down and restart. |
Posted: Tue Dec 16, 2014 12:32 pm Post subject: |
how do i do a backup please...
forget that, found how to...
garmin express recognising unit |
Posted: Tue Dec 16, 2014 12:49 pm Post subject: |
Yes, if your PC won't see them you can't now back up , hence my comment 'hope you back up regularly'. Also if you use Basecamp your favourites will be there _________________ Where there's a will ... there's a way. |
Posted: Tue Dec 16, 2014 1:25 pm Post subject: |
sorted!
new POI's loaded.. now updating maps. the reset helped as unit was just hanging
Thanks |
Posted: Tue Dec 16, 2014 1:27 pm Post subject: |
Great _________________ Where there's a will ... there's a way. |
Kremmen Pocket GPS Verifier
Posted: Tue Dec 16, 2014 3:43 pm Post subject: |
Just spotted this.
I've never used the Garmin lead, just a normal mini USB that works fine. In fact the one I use is a Canon Ixus camera lead. _________________ Satnav:
Car Average MPG :
