Dabri Lifetime Member
Posted: Wed Jul 30, 2014 10:36 pm Post subject: |
OK gazza70, thank you anyway. _________________ Dabri.
Navman iCN530T; Garmin 760T v4.80; Garmin 765T v4.00; Garmin 2460LMT v3.60; Samsung S3;
Garmin 3598LMT-D v5.50; Samsung J6; Garmin DriveSmart76 LT-D v6.80; Samsung A52. |
Kremmen Pocket GPS Verifier
Posted: Thu Jul 31, 2014 5:19 am Post subject: |
I've placed an email enquiry with Garmin to see if the digital traffic units are the same as the FM traffic units in that the power lead is also the aerial so needs to be draped across the dash.
So far not had a reply (I'm on day 3 of the promised 3 day reply window today so wonder if they will reply).
One thing I don't like is an unsightly cable across the dash. Mine is neatly tucked away behind the dash so all you can see is about 4" of cable and only if you look behind the unit as I also have a fixed dash mount. _________________ Satnav:
Car Average MPG :
sussamb Pocket GPS Verifier
Joined: Mar 18, 2011 Posts: 4456 Location: West Sussex
Posted: Thu Jul 31, 2014 7:25 am Post subject: |
gazza70 wrote: | Sorry Dabri I finished up buying the GARMIN NUVI 2598 LMT-D EU SAT NAV as the 2599 was new , halfords only had a display model ,
To be honest the only difference I could see was the colour of the unit the old one is silver compared to the new one being black ,
As far as I can tell that's about it! It claims to have 'updated software' but that could mean anything
These models don't even appear on the UK Garmin website so I suspect these are simply Halfords/Currys etc 'specials'. |
BigJohnD Frequent Visitor
Joined: Aug 26, 2007 Posts: 396 Location: Glannau Mersi, Lloegr
Posted: Thu Jul 31, 2014 10:07 am Post subject: |
sussamb wrote: |
Think you're right. The same applies to my Nüvi 2548LMT-D which I suspect was a one-off batch for Halfords and now obsolete, being superseded by the 2598LMT-D.
It was good value, with a store discount, cashback via Quidco and free delivery. Didn't have to leave the house! |
gazza70 Regular Visitor
Posted: Thu Jul 31, 2014 5:04 pm Post subject: |
Kremmen halfords have the Garmin GTM 70 Digital Traffic Receiver for £99.99 it doesn't say if this is capatable with older models but to be honest for that price I would look at buying a new digital satnav |
Posted: Fri Aug 01, 2014 5:25 am Post subject: |
Ta
Still waiting for Garmin to reply. I suspect the cable is still the antenna in the digital traffic models so I'll have to stick with Smartlink to be able to hide the power cable. _________________ Satnav:
Car Average MPG :
jonial Regular Visitor
Joined: May 10, 2004 Posts: 160 Location: Garstang, Lancashire
Posted: Fri Aug 01, 2014 9:03 am Post subject: |
I have a digital receiver and use the small external antenna which allows me to hide the larger combined supply and antenna cable within the dashboard.
Just the Receiver and small antenna cable remaining visible. _________________ Jonial
Garmin Nuvi 2547LM
CamerAlert
PGPS Speed Cameras |
Posted: Fri Aug 01, 2014 9:38 am Post subject: |
Problem is many of the later nuvis have the receiver built into the GPS, so the only antenna is the power cable. Now logic says the antenna must be at the top so hiding the majority behind the dash shouldn't be an issue, but until you do it you can't be sure.
Garmins advice is not to coil, hide etc but that could just be them being over cautious.
Are you sure you have a digital receiver? The models ending in 8 and 9 are the digital ones, so did you buy your cable separately? |
Posted: Fri Aug 01, 2014 10:02 am Post subject: |
Yes I bought the receiver separately . It is a GTM70 and cost £49.99 from Amazon.
It works very well indeed and gives far more detail than the GTM36 it replaces.
I no longer regularl use the tomtom720 as having now got used to the Garmin I find it very easy to use. _________________ Jonial
Garmin Nuvi 2547LM
CamerAlert
alan_sh Lifetime Member
Posted: Mon Aug 04, 2014 6:52 pm Post subject: |
I've just bought the 2599 Halfords special. It's doing updates as I type.
I'll keep you posted how well it works (it's replacing a TomTom 730 as I wanted Digital traffic).
Alan |
Posted: Tue Aug 05, 2014 6:15 am Post subject: |
sussamb wrote: | Problem is many of the later nuvis have the receiver built into the GPS, so the only antenna is the power cable. Now logic says the antenna must be at the top so hiding the majority behind the dash shouldn't be an issue, but until you do it you can't be sure.
Expensive mistake if it doesn't work though. I'm comparing the setup to trying to run a radio with the aerial folded down. Again, the receiver is inside the radio but without an extended aerial ... _________________ Satnav:
Car Average MPG :
Posted: Tue Aug 05, 2014 7:32 am Post subject: |
Agreed, but whatever the device the antenna needs to be able to receive the signal
Have you thought (I'm sure you have) about running it along the top of the dash? If you did it where the dash meets the screen it would be fairly invisible? |
Posted: Tue Aug 05, 2014 8:11 am Post subject: |
That is exactly where I run my external antenna - it is not in the field of view at all _________________ Jonial
Garmin Nuvi 2547LM
CamerAlert
Posted: Tue Aug 05, 2014 9:04 am Post subject: |
Not on mine it wouldn't as the dash meets the screen in view.
I'll see what my map reload does with Smartlink before I make a decision. _________________ Satnav:
Car Average MPG :
Posted: Tue Aug 05, 2014 1:14 pm Post subject: |
So, I've had my 2599 for 24 hours now and been on one long trip (M60, M6, M5 and back - total of 288 miles). Here are my initial thoughts - mostly compared to my old TomTom 730.
I bought this because the analogue traffic on my 730 was very very intermittent and inaccurate. The advert for this said "FAST and ACCURATE".
And, yes, it appears to be true. It got a traffic signal within about 30 seconds of my entering the route and immediately told me of narrow lanes 81 miles away (but no delays). All the way there and back, the traffic delays it reported seemed to hold true - but there were no actual holdups so I can't comment on any re-routing opportunities.
I do love the fact that it alters the speed limit when it goes into an average speed camera area. I disabled the Garmin speed cameras and downloaded the ones from this site (and I've found one missing - I must remember to report it).
The display is fine. My 730 would display multiple traffic incidents AND all the other info - this one displays one traffic incident OR extra info - but I can live with that.
I like the fact that it says "turn left at the next traffic lights" and "Stay in the right two lanes" etc. Much easier than TT (maybe new TT does that as well).
It recalculates very very quickly.
So, so far - all is good.
Alan |
