| Author |
Darren Pocket GPS Staff
Joined: 11/07/2002 14:36:40 Posts: 23708 Location: Hampshire, UK
Posted: Wed May 09, 2012 11:18 am Post subject: Bigger is better - TomToms whopping 6-inch Start 60 |
If bigger is truly better then TomTom's Start 60 must be win with a chance of winning the crown.
Outfitted with a whopping 6-in screen, the 60 is the largest TomTom satnav to date and should give factory fit systems a run for their money.
The extra large display means bigger menus and buttons as well as the larger map display. It comes equipped with IQ Routes, Map Share, text to speech and a new dual mounting system that gives you a choice between windscreen or dash mounting options.
It's available now with a guide price of £169.99 with European mapping.
Source: TomTom
_________________ Darren Griffin - Editor
I ran the 2013 London Marathon in support of the National Autistic Society see here. |
| Back to top |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 12055 Location: Bradford, West Yorkshire
Posted: Wed May 09, 2012 11:44 am Post subject: |
So is everything just scaled up or are they making use of the extra screen real-estate?
MaFt _________________ 404 Error - Signature not found |
| Back to top |
spook51 Lifetime Member
Joined: Mar 26, 2004 Posts: 542 Location: East Midlands
Posted: Wed May 09, 2012 12:12 pm Post subject: |
| MaFt wrote: | So is everything just scaled up or are they making use of the extra screen real-estate?
MaFt |
I think there's a clue in this sentence:
"The extra large display means bigger menus and buttons as well as the larger map display." |
| Back to top |
Posted: Wed May 09, 2012 12:34 pm Post subject: |
for the menu yes, but the map screen could be larger map display as well as a slightly different layout or more info along the bottom area...
i suspect not though... _________________ 404 Error - Signature not found |
| Back to top |
newbeee Occasional Visitor
| Back to top |
dhn Frequent Visitor
Joined: Oct 08, 2007 Posts: 2315 Location: Toronto CANADA
Posted: Wed May 09, 2012 2:01 pm Post subject: |
| MaFt wrote: | for the menu yes, but the map screen could be larger map display as well as a slightly different layout or more info along the bottom area...
i suspect not though... |
You suspect right, unfortunately ...............  _________________ David
--TomTom 720 NA map 895 WCE map 840 NZ map 835
--540 WTE NA map 885 Europe_West 885 |
| Back to top |
M8TJT The Other Tired Old Man
Joined: Apr 04, 2006 Posts: 4870 Location: East Sussex, UK
Posted: Wed May 09, 2012 3:29 pm Post subject: |
But bigger means that you can see the same old stuff easier  |
| Back to top |
Wazza_G Lifetime Member
Joined: Jan 10, 2006 Posts: 539 Location: Guildford (Regrettibly)
Posted: Wed May 09, 2012 6:34 pm Post subject: |
6"... So what it's nothing without accurate mapping data.
That's why I dumped TomTom. That plus the stupid memory situation where not all of the EU fits in the units memory.  _________________ Be alert.. This country needs more lerts. |
| Back to top |
Joined: Jan 14, 2005 Posts: 19636 Location: Blackpool , Lancs
Posted: Wed May 09, 2012 7:29 pm Post subject: |
| My only thoughts are that should you need a 6" screen sat nav are your eyes good enough to be driving in the first place?? - Mike |
| Back to top |
Posted: Wed May 09, 2012 7:36 pm Post subject: |
Mike, I've used units with 3.5" screens, 4.3", 5.0 and now 6.0".
While I don't NEED the 6.0" screen, the info on it (especially in something like 2D night view) is easier on my eyes than any of the smaller sized screens.
p.s. You gonna come by TTF for a visit?  _________________ David
| Back to top |
MrT Frequent Visitor
Joined: Nov 14, 2003 Posts: 2125 Location: Surrounded by A1, M1 & M25
Posted: Thu May 10, 2012 9:24 am Post subject: |
| mikealder wrote: | | My only thoughts are that should you need a 6" screen sat nav are your eyes good enough to be driving in the first place?? - Mike |
Actually yes and a common cause of this is called presbyopia and everyone gets it progressively, usually past the age of 40.
As you get older (like me) the minimum distance you can focus at starts to increase as your eye lens hardens. So at age 20 you might be able to focus on something 6" from your eyes but by the time your are sixty, this can be around 3ft.
This does not affect your vision beyond this minimum distance which could still be near perfect in the range 3ft to infinity. However your TomTom is usually nearer than 3ft to you.
If you have presbyopia and wear glasses so you can focus on near objects, you then cannot focus on distant objects. Bifocal are a sort of solution to this but not much use for driving where the near distance objects you want to focus on are in or very near your driving line of vision. _________________ TT6 on PDA, Go940, Go530T |
| Back to top |
Kremmen Lifetime Member
Joined: Mar 03, 2006 Posts: 731 Location: West London
Posted: Thu May 10, 2012 9:56 am Post subject: |
All very well but ........... when you park it's not the size you can pop in your top pocket and take with you. _________________ Lets be careful out there ! |
| Back to top |
Posted: Thu May 10, 2012 10:18 am Post subject: |
| MrT wrote: | | Bifocal are a sort of solution to this but not much use for driving where the near distance objects you want to focus on are in or very near your driving line of vision. |
I wear varifocals when driving. They enable me to see the car's instruments, satnav etc. clearly and I'm also able to look through the top (non-prescription) part of the lens to focus on distant objects. |
| Back to top |
Posted: Thu May 10, 2012 10:28 am Post subject: |
| MrT wrote: | | Bifocal are a sort of solution to this but not much use for driving where the near distance objects you want to focus on are in or very near your driving line of vision. | What are they then, your windscreen wipers? I use bifocals, but the bottom bit is intermediate not reading, as my instruments etc. are too far away for my reading prescription. Unless you hang your sat nav in the middle of the windscreen, which is illegal anyway, there's no problem with bifocals as the cut off point is approximately at the bottom of the windscreen leaving the view through the window unaffected by the stronger inter prescription. |
| Back to top |
Posted: Thu May 10, 2012 11:38 am Post subject: |
My TomTom is on the dash and too high for bifocals.
The only part of the screen I cannot read on my 940 without glasses is the distance to incident figures on the traffic bar.
I have not heard of intermediate bifocals before but it makes sense and I might look into these. Reading bifocals make me feel slightly disorientated when looking up. _________________ TT6 on PDA, Go940, Go530T |
| Back to top |
| Back to top |
