Pocket GPS World :: View topic - CamerAlert 1.3.2.491 available in the Android Market
Post new topic   Reply to topic    Pocket GPS World Forum Index -> CamerAlert on Android
PostPosted: Fri Sep 30, 2011 7:42 pm    Post subject: CamerAlert 1.3.2.491 available in the Android Market Reply with quote
The latest version of CamerAlert (version 1.3.2.491) is now available from the Android Market.
This updates adds support for external Bluetooth GPS devices, and implements a fix to prevent the Android OS shutting it down when running in the background for 30 minutes. We have also added support for 140 and 160 KPH cameras that have been installed in Dubai.
To use CamerAlert with an external BT GPS device all you need to do is to install, configure and connect the BT GPS. You will need to configure Once this has been confirmed to be working you simply connect the BT GPS and then run CamerAlert.
The full list of Changes in version 491 are:
New functionality:
- Added the ability to use an external Bluetooth GPS device. Simply configure and connect to the BT GPS before running CamerAlert.
- Added a chimes warning sound.
- Implemented an additional warning for mobile cameras
- Added warnings for 140 and 160 KPH cameras
- Made the Samsung Spica GPS workaround optional configured in the preferences
- Vibrate the device if in call when camera comes into range
Fixes:
- added code to prevent the OS shutting down the app after 30 minutes in the background
- Corrected back button in main display
- Stabalised the overspeed duration setting
- Fixed the media player null pointer exception
- Keep reported speed consistent in the application
- Fixed multiple map issue
- numerous small fixes
Paladin
PostPosted: Mon Oct 03, 2011 7:00 pm    Post subject: Reply with quote
Many thanks, I go away for a couple of days and the ability to interface to external BT Rx appears Rolling Eyes Not to worry, I have an extended journey this week and will be able to give it a decent go Very Happy
M.
Jaz666
PostPosted: Mon Oct 03, 2011 10:09 pm    Post subject: Reply with quote
Well done, I've given it a good long test over the last few days, and not a single background shutdown when Waze is running in the foreground Cool
Post new topic   Reply to topic    Pocket GPS World Forum Index -> CamerAlert on Android All times are GMT + 1 Hour
22.053 (15 May 24)
