| Author |
Cirieno Occasional Visitor
Posted: Fri Jul 15, 2011 9:24 am Post subject: CamerAlert quits silently |
Please can you make it optional, rather than apparently default, that the app quits silently if no movement has been detected for a few minutes?
If I stop for petrol, or get stuck in a traffic jam, then it's far too easy to drive on forgetting that CamerAlert has closed itself. If I don't hear any alerts for a while I have to check on the taskbar to make sure the app is even running.
If this is not expected behaviour then please let me know. I suppose I should make the disclaimer that my device is jailbroken, but that shouldn't really affect the operation of CamerAlert and shouldn't immediately raise the "we don't support that" flag. FWIW I have jailbroken my iPhone so that I can have your database as POIs in TomTom (I'm working on a new set of icons but time is currently limited) rather than overloading it with themes etc.
Other than that, thankyou all for a very useful app! |
| Back to top |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 11973 Location: Bradford, West Yorkshire
Posted: Fri Jul 15, 2011 9:39 am Post subject: |
It should only close after 10 minutes of no movement if it is in the background. This is to save on battery use if the app is not closed. It's a pretty 'standard' thing to do and nearly all 'navigation' apps will do this.
MaFt _________________ 404 Error - Signature not found |
| Back to top |
Posted: Fri Jul 15, 2011 4:31 pm Post subject: |
| MaFt wrote: | It should only close after 10 minutes of no movement if it is in the background. This is to save on battery use if the app is not closed. It's a pretty 'standard' thing to do and nearly all 'navigation' apps will do this.
MaFt |
While I do understand the reasoning (battery life is what I suspected), would it please be possible to make it optional? It's just my opinion but it feels like it breaks the user experience expectation that an app can kill itself without warning to the user. It would be different if the option could be explicitly set as then the user is more likely to be aware of the behaviour...
Thankyou! |
| Back to top |
lbendlin Pocket GPS Staff
Joined: 02/11/2002 22:41:59 Posts: 11843 Location: Massachusetts, USA
Posted: Mon Jul 25, 2011 1:35 am Post subject: |
We thought about a popup to say "we'll close down now" but what good is that popup if it is shown to a screen in standby? So far we haven't found a good way around that. Ideas are welcome.
Maybe we should couple that with the "Prevent standby" switch? Meaning that if you set "Prevent standby" to on then we would also not auto quit? _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
| Back to top |
RavingDave Lifetime Member
Posted: Mon Jul 25, 2011 10:25 pm Post subject: |
Until reading this thread I wasn't aware that CamerAlert would close itself down after a period of non-movement. I can't see any mention of this in the manual, and having just tried it for myself it appears to close down after 5 minutes of non-movement.
So if I am stuck in a traffic jam for more than 5 minutes then CamerAlert will silently quit, and when I get to move again I will have no indication that it is no longer active? Surely if the device is not in standby then at the very least a pop up should appear to warn the user that it is about to quit from the background?
Presumably the same effect will occur if I make a stop at a service station for more than 5 minutes. My satnav will continue to run, but CamerAlert will have just quietly switched itself off!
Co-Pilot seems to give a warning if it about to close down when in standby. It briefly wakes up the screen with a popup, and if you don't see it, then the popup is still there next time you switch on out of standby.
I think there should definitley be a warning, so that at least if you are not in standby you will get to see it. Perhaps it could then wait for a more extended time, and if you have not responded in say 30 minutes then auto quit? |
| Back to top |
MalcolmLLoyd Occasional Visitor
Posted: Sat Aug 20, 2011 6:54 pm Post subject: |
Is it possible to not auto quit if the iPhone is connected to a charger that is on? _________________ Malcolm |
| Back to top |
AliOnHols Pocket GPS Verifier
Posted: Sun Aug 21, 2011 7:27 am Post subject: |
Would it be possible to implement a couple of warning beeps 30sec., or so, before auto-shutdown? _________________ TomTom GO 730, GO 930, GO 940 & Rider2.
SatMap Active 10.
Android with CamerAlert, OsmAnd+ maps, Waze & TT Europe. |
| Back to top |
alan_dr Lifetime Member
Joined: Oct 14, 2006 Posts: 314 Location: Portsmouth, UK
Posted: Thu Aug 25, 2011 8:36 am Post subject: |
Or just a setting 'Minutes before auto-close (0=never)'? _________________ Alan - iPhone 4 32GB, with TomTom Europe, Sygic Europe, Navmii UK, CoPilot UK & US, Ndrive Oz & HK. Whatever happened to Ndrive? |
| Back to top |
| Back to top |
