Pocket GPS World :: View topic - Satmap Active 10 Plus and Memory Map
QuisSeparabit
PostPosted: Sat Apr 02, 2011 9:07 pm    Post subject: Satmap Active 10 Plus and Memory Map Reply with quote
New to the forum and considering a move to a Satmap Active 10, at present I use a MIO P360 PDA with GPS and Memory Map V5 together with some historical maps (Linesman Trench Maps), am I able to use these with Satmap, or is Memory Map not compatible with this system? Look forward to any responses, most especially from anyone using this software already.
rothers
PostPosted: Sat Apr 02, 2011 10:09 pm    Post subject: Reply with quote
You can't use Memory Map mapping on the Satmap, you'll need to purchase the mapping from Satmap. You can however transfer routes & tracks back and forth between the two.
keithwaugh
PostPosted: Thu Apr 28, 2011 9:44 am    Post subject: Reply with quote
Until recently the Satmap Active 10 was quite expensive, but now that you can buy it for £320-£400 including the 1:50,000 GB OS Maps, it is very competitive. I also have Memory Map V5 and as the member above says, it is quite easy to transfer route/track Gpx files back and forth between MMV5 and SatMap10. A word of caution-see the Memory Map Forums before even considering the Memory Map Adventurer3500 GPS
mandyj
PostPosted: Sun May 08, 2011 3:49 pm    Post subject: Reply with quote
Believe me i have owned both units in the past.
I won,t get into a debate about which is best, but memorymap have just announced a big upgrade to their ad3500, this will put right most grumbles the forum have been debating, if you own memorymaps v5 maps, its really worth your while taking a second look.
mandyj
mandyj
PostPosted: Tue May 10, 2011 10:56 pm    Post subject: Reply with quote
Just recieved my update, a screenlock that works, 90% of the problems the unit suffered were down to a lack of screenlock....... not now.
other problems also eradicated.
