MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15148 Location: Bradford, West Yorkshire
Darren Frequent Visitor
Posted: Tue Dec 14, 2010 3:07 pm Post subject: |
Brodit Part #215256 seems like it would be perfect assuming it was the correct size.
I need a micrometer to measure the diameter accurately. _________________ Darren Griffin |
Posted: Tue Dec 14, 2010 3:28 pm Post subject: |
Ok, I stripped the TomTom adapter I have (that was intended for the TomTom iPhone CarKit) off my GO 1000 mount.
It fits the Arkon but is a tiny bit too small which means it can't be clamped down tight enough to stop movement.
It is about 16mm so that would suggest a 17mm ball might work OK. _________________ Darren Griffin |
Posted: Tue Dec 14, 2010 7:09 pm Post subject: |
For some dimensions of the two balls here is a snippet from another thread when messing around with the TomTom iPhone kit:
With the two parts seperated its time to measure the diameter of the ball which checks in at 15,90MM slightly less than the Garmin standard ball which is 17,12MM (Both are shown in this picture for comparison).
Mike |
Posted: Tue Dec 14, 2010 7:24 pm Post subject: |
Thanks Mike. All suggests that a Garmin ball mount would be the right size. I can't find the Garmin ball mount on the Brodit site though? _________________ Darren Griffin |
dandpclements Occasional Visitor
Joined: 14/08/2003 22:56:10 Posts: 16 Location: United Kingdom
Posted: Tue Dec 14, 2010 7:55 pm Post subject: |
Thanks for all your help on sizing this |
Posted: Tue Dec 14, 2010 8:07 pm Post subject: |
Darren wrote: | I can't find the Garmin ball mount on the Brodit site though? |
Have a look at item 215116 on the DSL Dev web site, it fits all Garmin units so gets loads of listings against the various models - Mike |
Posted: Tue Dec 14, 2010 8:10 pm Post subject: |
Ah yes, I've seen that one, just wasn't the one I was expecting. What was the 2nd one in your pics with the micrometer? _________________ Darren Griffin |
Posted: Tue Dec 14, 2010 8:26 pm Post subject: |
The second picture was 215116 supplied by DSL Dev - Mike |
Posted: Tue Dec 14, 2010 10:01 pm Post subject: |
mikealder wrote: | The second picture was 215116 supplied by DSL Dev - Mike |
Just looked different on the Brodit site. Thanks though. _________________ Darren Griffin |
MrGumby Regular Visitor
Joined: Jan 21, 2006 Posts: 114 Location: West Sussex
Posted: Wed Dec 22, 2010 12:36 am Post subject: |
I emailed Arkon and received an impressively prompt and helpful reply. Sadly, UK availability of the accessories mentioned seems poor. I might just be tempted to try and do something about that!
Thank you for the inquiry. The RWIPC has a 17mm Garmin ball pattern built into the back. You can use any of the Garmin solutions found on this page:
http://www.arkon.com/garmin_nuvi_mount.php
As for compatibility with the brodit ball / TomTom mount, I doubt it will work in that exact configuration. Fortunately, Arkon does have a similar combination of adapters that could still utilize the dash bracket portion:
https://www.arkon.com/shopsite_sc/store/html/index.html
AP032-VSM - Adapter Plate - Converts any 4 Hole AMPS pedestal to Arkon's Dual T-Slot Pattern
AP2T17MM - Adapter Plate - Converts any ARKON DUAL T-Tab Pattern Pedestal to the 17mm
Posted: Wed Dec 22, 2010 8:33 am Post subject: |
MrGumby wrote: | I emailed Arkon and received an impressively prompt and helpful reply. Sadly, UK availability of the accessories mentioned seems poor. |
Morpeth Mobiles stock all the Arkon mounts so they should have the accessories also.
Quote: | [color=blue]Thank you for the inquiry. The RWIPC has a 17mm Garmin ball pattern built into the back. |
Good to have our calculations confirmed.
Quote: | As for compatibility with the brodit ball / TomTom mount, I doubt it will work in that exact configuration. Fortunately, Arkon does have a similar combination of adapters that could still utilize the dash bracket portion: |
I see no reason why it wouldn't work fine with the Brodit Garmin Ball. The rest of their reply seems confused as this mount does not have the Arkon T-Tab/T-Slot fixing so cannot use any such adapters. _________________ Darren Griffin |
Posted: Wed Dec 22, 2010 10:08 am Post subject: |
Darren wrote: |
Morpeth Mobiles stock all the Arkon mounts so they should have the accessories also. |
Morpeth don't list many (any?) of those accessories but may indeed have them or be able to get them. |
zebsogo Regular Visitor
Posted: Sat Jan 29, 2011 9:24 am Post subject: Utility app required for GPS functionality |
I have done some research and discovered that a utility app is required to view the GPS side of things i also discovered that you need this app "RW GPS Car Kit Tool App" trouble is it is not on the App store or on any website that i an find .. Can anybody help _________________ --
Navigon 92 Premium Live,TomTom Go 6000,Garmin 2699 LTM-D and a TomTom Go 1005 Live ( For the wife )
Posted: Sat Jan 29, 2011 10:32 am Post subject: Re: Utility app required for GPS functionality |
zebsogo wrote: | I have done some research and discovered that a utility app is required to view the GPS side of things i also discovered that you need this app "RW GPS Car Kit Tool App" trouble is it is not on the App store or on any website that i an find .. Can anybody help |
You would only need an app to see the raw GPS data, not to use the cradle with a nav app?
The manual only mentions the app if you are troubleshooting a fault.
I can't find it either, drop the manufacturer an email and ask:
http://www.noeticinc.com/RW/contactsupport.html _________________ Darren Griffin |
