Newsletter
Pocket GPS World :: View topic - Video Tutorial: Installing the PGPS Speed Cameras on TomTom
Goto page Previous  1, 2, 3, 4
PostPosted: Sat Oct 09, 2010 8:56 pm    Post subject: Reply with quote
Menu at the top of this site - Speed Cameras | Installation Guides.
Darren Griffin - Editor
I ran the 2013 London Marathon in support of the National Autistic Society see here.
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger
TKTrooper
PostPosted: Sat Oct 09, 2010 9:05 pm    Post subject: Reply with quote
Thats what brought me to this thread, so is the video at the top of this thread the one i follow for POI's as well?
I have a TOMTOM ONE IQ routes edition UK & Ireland
I'm sorry to sound like a pain, but this is very confusing for me at the moment.
PostPosted: Sat Oct 09, 2010 9:09 pm    Post subject: Reply with quote
Your question originally was did the same procedure for installation apply to POIs as it does to Speed Cameras.
The answer as MikeA said is 'yes' but you would omit the part where you configure an alert unless you wanted to have your device bleep at you each time you approached one of your POIs.
So yes, the video at the start of this thread covers POIs installation. Whatever the type they install in the same way.
Does that make sense?
TKTrooper
PostPosted: Sat Oct 09, 2010 9:14 pm    Post subject: Reply with quote
Yes thanks, sorry if i was being a pain. Just that if you've never done this before it is very confusing.
PostPosted: Sun Oct 10, 2010 10:52 am    Post subject: Reply with quote
No apology necessary, we're here to answer questions and if we're not clear then that's our fault not yours Smile
If you have any problems just shout.
sp0rran
PostPosted: Tue Oct 11, 2011 9:24 pm    Post subject: Reply with quote
as a newbie, downloaded OV2 files for Tom Tom XL Live and opted for Female with Chime Prefix Voice Pack - however when setting up POI warnings on Tom Tom, the device would not progress beyond setting distance for alert - only option being to cancel out !? I've found a workaround by deleting the voice (.ogg) files, but wondered why issue & thought would inform/ask here.
PostPosted: Wed Oct 12, 2011 2:03 am    Post subject: Reply with quote
When you say "the device would not progress beyond setting distance for alert - only option being to cancel out !" what exactly happens after you have entered the distance and pressed "done"?
But if you'd rather not faff about trying to get this method working, just use "Method 2" described in the old text instructions, where you put the .ogg files in the "sounds" folder rather than the map folder. (This is actually TomTom's preferred method).
If you explore your TomTom device with a file manager (e.g. Windows Explorer, Mac Finder etc) you should find an empty folder called "sounds" (if not, then you can manually create one). Any .wav or .ogg format sound files you paste into this folder will appear on the same page as the usual Sound Effects such as "Bell1", "Cow" etc. and can be selected for use as warnings in the normal way.
You can also paste folders containing whole collections of sound files in this "sounds" folder and they will appear as clickable folders.
Ogg files are preferred as their file sizes are much smaller than wavs. If you need to convert .wav files to .ogg format you can use the free sound editor "Audacity" to achieve this. Note that .wav files can be 11025kHz or 16kHz sample rate but MUST be 16 bit. 8 bit samples will be displayed as options on the page but cannot be played.
All the TomTom format sound files available here are compatible with this installation method, you can place them in the sounds folder, select them and preview them in the same way you can the other built-in sound effects.
The only problem here is that the naming convention PGPSW use puts pocketgps_ at the beginning of the filename. This is necessary to support their normal installation method, which requires the sound files have identical file names to the database files. This results in the part of the name which identifies which speed and type of camera being at the end i.e. pocketgps_uk_gatso_30.
When you see the files on the sound effects page, only the first 10 or so characters of the name get shown, so they will all just show "PocketGPSWo...". So either use the 'preview' button to hear them first or rename the files before copying to the sounds folder to make them more easily located i.e. gatso30, specs70 etc
"Settling in nicely" ;-)
sp0rran
PostPosted: Wed Oct 12, 2011 9:13 am    Post subject: Reply with quote
Many thanks for suggestion - will try that. Meantime, to answer your request for clarification - having entered a distance & pressed 'OK', nothing happened - stayed on same screen - could alter to any distance but pressing 'OK' had no effect i.e you were stuck on the distance setting screen with only way out being to hit 'Cancel'
PostPosted: Wed Oct 12, 2011 9:19 am    Post subject: Reply with quote
What/who are you replying to?
Have you tried a reset and restart?
Page 4 of 4
11.062 (12 Jun 13)
