Darren Frequent Visitor
Posted: Tue Oct 05, 2010 6:10 pm Post subject: |
RavingDave wrote: | If the CamerAlert App is running in the background, is it still requesting map tiles to be downloaded across the data network, or do these requests only go out whilst it is in the foreground? |
It would only do that when in the foreground but if you are using it in the background, why not switch to list view only and dispense with the map? _________________ Darren Griffin |
RavingDave Lifetime Member
Posted: Tue Oct 05, 2010 8:00 pm Post subject: |
Darren wrote: | RavingDave wrote: | If the CamerAlert App is running in the background, is it still requesting map tiles to be downloaded across the data network, or do these requests only go out whilst it is in the foreground? |
It would only do that when in the foreground but if you are using it in the background, why not switch to list view only and dispense with the map? |
Thanks - just wanted to check that I don't explicitly have to switch it to showing no map data to stop it using up data allowance whilst sitting in the background. I sometimes use it in foreground (when I know where I am going) and then will use it in the background when using a SatNav, so not having to do anything is good for me.
I did try list mode coming home today, but found that whenever it approached a camera it automatically switched to the map, and did not switch back to the list. Is this by design, or would I also need to set the Show Map switch to 'never'? to keep it in List Mode? |
Posted: Tue Oct 05, 2010 8:23 pm Post subject: |
RavingDave wrote: | I did try list mode coming home today, but found that whenever it approached a camera it automatically switched to the map, and did not switch back to the list. Is this by design, or would I also need to set the Show Map switch to 'never'? to keep it in List Mode? |
You configure it in Settings / Map | Show - Never or Near cam. If set to Near cam it will revert to list after you have passed the camera. _________________ Darren Griffin |
twotonemark Regular Visitor
Posted: Tue Oct 05, 2010 8:46 pm Post subject: Great!! |
Just came across the update Launched the app and it verbally informed me there was a newer version of the database available....very nice!
Congratulations to the whole team!!!
Look forward to using it in anger behind CoPilot this week. _________________ iPhone 6 - TomTom WE- CamerAlert - Brodit Passive Adjustable mount.
Posted: Tue Oct 05, 2010 9:35 pm Post subject: |
Worked really well behind everything i was running today.
No voice breakup with iOPlay (Bluetooth) anymore....
Much clearer too... |
boltysan Lifetime Member
Posted: Tue Oct 05, 2010 10:05 pm Post subject: Power saving idea? |
In the last version I was surprised to see that the battery level on my 3GS was dropping (slowly) on a journey from Burnley to Whitby, I was using the 3GS in phone mode (didn't make many calls though) and running the iPod function as well as the Camera Alert.
I was running it in a Brodit holder plugged into the USB socket on my Sony MEX-BT3700U for audio and charging, it could be that the charge current from my Sony stereo is low and doesn't supply enough juice to keep the 3GS running and put a bit extra into the battery.
would it be possible to make the next version dim the backlight when there are no camera's in the area? this would surely save a bit of power or am I the only person that would benefit from this?
Also I agree with the comment earlier in this thread about the voice warnings being a bit long winded, apart from that keep up the good work! |
Posted: Tue Oct 05, 2010 10:11 pm Post subject: Re: Power saving idea? |
boltysan wrote: | In the last version I was surprised to see that the battery level on my 3GS was dropping (slowly) on a journey from Burnley to Whitby,
SNIP
would it be possible to make the next version dim the backlight when there are no camera's in the area? this would surely save a bit of power or am I the only person that would benefit from this? |
Dimming the display would not help.
The issue occurs because the iPhone uses more power than your charging method will support. You need at least 2A to support an iPhone when running GPS if you want to stop the battery discharging whilst running iPod and GPS.
The easiest solution would be to invest in a dedicated iPhone compatible charger that has a 2A output (few do). Griffin do one. _________________ Darren Griffin |
Posted: Tue Oct 05, 2010 10:42 pm Post subject: |
Yeah I thought as much but I'm surprised that the 3GS needs 2A to run the GPS, seems a heck of a lot (not that I'm doubting you!)
How much difference would dimming the display make to the power needed though? In my particular case the power level drops slowly and it could just make the difference between arriving with a flat battery, Having the display dimmed could be a safety feature though (or it could make it more likely to make the driver look down to see what it was that just lit up on the dash) just a thought... |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15145 Location: Bradford, West Yorkshire
Posted: Tue Oct 05, 2010 11:31 pm Post subject: |
we can't adjust the screen brightness (technically the backlight) through the SDK if we want it in the appstore. you would need to do this manually in the phones main settings.
MaFt |
Posted: Tue Oct 05, 2010 11:42 pm Post subject: |
MaFt wrote: | we can't adjust the screen brightness (technically the backlight) through the SDK if we want it in the appstore. you would need to do this manually in the phones main settings.
MaFt |
Feel free to not bother replying to this MaFt...
By dimming the screen I do mean cutting the backlight or reducing the amount of backlight in much the same way as how the screen darkens when listening to the ipod function.
I have only replied to this topic again just in case I didn't explain myself properly (which, to be fair, happens quite a lot!) |
Posted: Wed Oct 06, 2010 12:11 am Post subject: |
yes, i followed what you meant . but my point still stands that you cannot put an app in the appstore that does this. the backlight uses a 'private API' that only apple can use.
MaFt |
mrg2003 Regular Visitor
Joined: 12/03/2003 18:19:15 Posts: 136 Location: United Kingdom
Posted: Wed Oct 06, 2010 1:20 am Post subject: |
MaFt wrote: | yes, i followed what you meant . but my point still stands that you cannot put an app in the appstore that does this. the backlight uses a 'private API' that only apple can use.
MaFt |
host it on cydia instead ;) _________________ Mr.G
gstenson Frequent Visitor
Joined: 23/10/2002 09:53:59 Posts: 267 Location: Lincolnshire, UK
Posted: Wed Oct 06, 2010 11:20 am Post subject: |
I bought 1.2 last night and tried it on my commute to work this morning. On its own its fine and works well. However, I tried putting it into the background and running TomTom. Now TT continually drops its GPS signal. Turning off cameralert and TT is fine again.
Any thoughts?
Thanks _________________ Audi S4
HTC One M8 & CamerAlert |
Posted: Wed Oct 06, 2010 11:38 am Post subject: |
gstenson wrote: | I bought 1.2 last night and tried it on my commute to work this morning. On its own its fine and works well. However, I tried putting it into the background and running TomTom. Now TT continually drops its GPS signal. Turning off cameralert and TT is fine again. |
As has been discussed already, the 'poor gps reception' issue in TomTom 1.4 is a TomTom bug. It has been fixed in the release awaiting Apple approval.
I can't explain why you are only seeing it when CA is running but I can assure you it is a TT bug. You can verify this by running another nav app or our GPS Status app which will confirm full reception. _________________ Darren Griffin |
johngoodland Occasional Visitor
Posted: Wed Oct 06, 2010 11:50 am Post subject: |
Darren wrote: | gstenson wrote: | I bought 1.2 last night and tried it on my commute to work this morning. On its own its fine and works well. However, I tried putting it into the background and running TomTom. Now TT continually drops its GPS signal. Turning off cameralert and TT is fine again. |
I can't explain why you are only seeing it when CA is running but I can assure you it is a TT bug. You can verify this by running another nav app or our GPS Status app which will confirm full reception. |
To add to this..
I did do the the GPS Status on the way home lastnight and it dropped to Good Fix for 20% of journey the rest on excellent (or excelent as the status said).
I'm hoping the new TomTom update fixes the GPS reception issue as it really is 'annoying' as the tomtom app jumps from M6 to a field then local road then back on M6.
Until then sorry guys I cant recommend the camera app as running tomtom with traffic is more important to me (on m6 remember !) |
