Pocket GPS World :: View topic - Nissan Connect - problems downloading from site
billws
PostPosted: Fri Dec 18, 2009 2:03 pm    Post subject: Nissan Connect - problems downloading from site Reply with quote
New user trying to download cameras for Nissan Connect system.All i get when i try to download is page after page repeating over and over again,no sign of where or how to download.
Can anyone HELP.I'm starting to loose patience now.
Anita
PostPosted: Fri Dec 18, 2009 2:30 pm    Post subject: Reply with quote
Welcome to the forum, billws.
I've just successfully downloaded and unzipped all three versions of the "Other - CSV" database, by using the "Download Speed Cams" link under "Speed Cameras" at the top of the screen.
Can you tell us exactly what you're doing and which version you're trying to download.
Anita
TomTom VIA 135 - App 12.075
UK map 1125.12264
Samsung Galaxy S21
billws
PostPosted: Fri Dec 18, 2009 2:41 pm    Post subject: Nissan Connect Reply with quote
Hi Anita,
Have tried your suggestion but when i go to "Download" i keep getting the same page over again.
Have tried several times but,,,same page telling me to download.
Its really doing mt head in,wish i'd never started in the first place
Bill.
Anita
PostPosted: Fri Dec 18, 2009 2:42 pm    Post subject: Reply with quote
Looking at this more closely, I suspect you're not scrolling down the screen to the "Download Here" area, where you select your satnav system (or in your case "Other - CSV") from the drop-down box.
Come back and let us know if this doesn't solve your problem.
Anita
UK map 1125.12264
Samsung Galaxy S21
billws
PostPosted: Fri Dec 18, 2009 2:52 pm    Post subject: Reply with quote
When i try to get "other csv files" i keep getting ERROR ON PAGE message showing.
This happens every time i try.
Anita
PostPosted: Fri Dec 18, 2009 3:10 pm    Post subject: Reply with quote
I've just downloaded it again without any problems. Confused
Just to confirm where it's going wrong for you, you're on the Download Database screen. You scroll down to where it says "Download Here", and selecting "Other - CSV" from the drop-down box, and clicking "Continue". You should get a screen with another drop-down box for selecting which version of the database you wish to download - I believe for the Nissan Connect you have to select "Single file with all cameras". At which point are you getting "ERROR ON PAGE"?
Anita
UK map 1125.12264
Samsung Galaxy S21
billws
PostPosted: Fri Dec 18, 2009 3:28 pm    Post subject: Reply with quote
Hi again,
Somehow i've managed to do it!
Am i right in placing all of the files which are a mix of bitmap and csv into the my/poi folder and then the csv files into the sub-folder called POI warnings
PostPosted: Fri Dec 18, 2009 3:46 pm    Post subject: Reply with quote
The installation guide is here.
The files need to go into the x:\myPOIs\myPOIWarnings folder where 'x:' is the drive letter of your USB memory stick when inserted into your computer.
Anita
PostPosted: Fri Dec 18, 2009 3:53 pm    Post subject: Reply with quote
The instructions don't seem to tell you where to put the bmp file, Darren. I would have expected it to go into the x:\myPOIs\myPOIWarnings folder with the csv file.
Anita
UK map 1125.12264
Samsung Galaxy S21
PostPosted: Fri Dec 18, 2009 3:55 pm    Post subject: Reply with quote
As far as we can establish, the Nissan system only requires the .csv file and uses its own Icon image.
I've corrected the install guide to remove reference to the .bmp files.
billws
PostPosted: Fri Dec 18, 2009 3:57 pm    Post subject: Reply with quote
Thank you all, it just needs to be tried in the car.Will let you know if it works.
Again many thanks.
Billws
Anita
PostPosted: Fri Dec 18, 2009 3:59 pm    Post subject: Reply with quote
That explains it! Thanks, Darren.
Anita
UK map 1125.12264
Samsung Galaxy S21
Anita
PostPosted: Fri Dec 18, 2009 4:32 pm    Post subject: Reply with quote
Again many thanks.
Glad you got there in the end, Bill. Very Happy Let us know how it goes.
Anita
UK map 1125.12264
Samsung Galaxy S21
billws
PostPosted: Wed Dec 23, 2009 5:47 pm    Post subject: Nissan Connect Reply with quote
Many thanks to those who helped me to sucessfully download Safety Cameras and other POI's for my Nissan Connect system.
Special thanks to Anita who was so patient. Now that i know exactly how to do it, then i can now get more POI's as those pre-loaded onto the system are VERY limited.
Once again a big thanks to all involved.
billws.
Anita
PostPosted: Wed Dec 23, 2009 6:13 pm    Post subject: Reply with quote
You're welcome, Bill. Very Happy That's what the forum's for. We all help each other, and most problems are solved in the end.
You have found our free POIs here haven't you?
Anita
UK map 1125.12264
Samsung Galaxy S21
