Pocket GPS World :: View topic - TyTn II data connection
carl_the_cobbler
PostPosted: Fri Feb 13, 2009 11:55 pm    Post subject: TyTn II data connection Reply with quote
Hello,
Tried to pair this wonderful phone with my TT 920, hands free worked great, but data connection didn't. Having read around I see that there is a.cab file available to enable this. Does anyone know if there is a pointer to it, or could anyone help in any other way.
Carl
dhn
PostPosted: Sat Feb 14, 2009 12:10 am    Post subject: Reply with quote
Perhaps you are thinking of this link
carl_the_cobbler
PostPosted: Sat Feb 14, 2009 10:48 am    Post subject: Reply with quote
Thank you very much for the link
Carl
Added: Still doesn't work any other advice available gratefully received
PostPosted: Sat Feb 14, 2009 11:34 am    Post subject: Reply with quote
It should work, after you installed the cab file by tapping it while using File Explorer on the PDA phone press and hold the power on/ off button until the device puts a warning up about losing data when turing off, just OK this message to reset the phone - you won't lose anything but it does make sure the new DUN Profile is stored correctly.
Is your Tytn-II Orange branded per chance?? - Mike
carl_the_cobbler
PostPosted: Sat Feb 14, 2009 11:40 am    Post subject: Reply with quote
Got it from 3, Mike.
It sticks at 40% and only finds the hands free facility on the TyTn II
PostPosted: Sat Feb 14, 2009 12:00 pm    Post subject: Reply with quote
As long as the DUN Profile is on the phone (which is what the CAB file has added) then it should work, this could be an issue with the software on the 920, you could try running Navcore 8,301 or even 8,320 on your device and see if that offers better results.
My only other suggestions are to delete the Phone from the TomTom and delete the TomTom from the phone, now try setting it up from scratch, failing this you could flash the phone with a different ROM, but this is a rather drastic move and will void any warranty you have on the handset.
I have had similar in the past when using HTC phones with the TomTom for data connections, a software update can sometimes remove the capability to use the phone to the same leval as was previously possible - Mike
carl_the_cobbler
PostPosted: Sat Feb 14, 2009 12:27 pm    Post subject: Reply with quote
Once installed is there anything I need to switch on or should it just happen?
PostPosted: Sat Feb 14, 2009 12:51 pm    Post subject: Reply with quote
No there is nothing to switch it simply adds the DUN Bluetooth profile to the device which is what the TomTom needs for a data communication via your mobile phone - Mike
carl_the_cobbler
PostPosted: Sun Feb 15, 2009 6:47 pm    Post subject: Reply with quote
Well I can' get it to work. 3 have given up on me. I have trawled the web looking for any kind of ideas and nothing. Cheers for the help fellas.
Carl
carl_the_cobbler
PostPosted: Sun Feb 15, 2009 6:49 pm    Post subject: Reply with quote
Oops
perussell
PostPosted: Mon Feb 16, 2009 11:10 am    Post subject: Reply with quote
I know this may not be of much help but just to confirm that after Mike had sent me the link to the .cab file earlier last year I followed the instructions, (it did take a couple of attempts) and since that time have had no issues with my HTC TyTn II (a.k.a. Vodafone V 1615). At the time of installation I was using a pre-v8.3 Navcore but it was still working fine after the v8.3 "downgrade" Crying or Very sad - I had a subscription to GPRS traffic and all was OK (as far as that was concerned) - as for Kate - enuff said!
My HTC also works absolutely fine with my 540 LIVE although I am not using GPRS traffic anymore
carl_the_cobbler
PostPosted: Mon Feb 16, 2009 2:26 pm    Post subject: Reply with quote
When you say followed the instructions, doesn't the .cab file just install what is required?
Does anyone have any idea what it does install so I can see if they are there and in the right place?
Carl
perussell
PostPosted: Mon Feb 16, 2009 2:31 pm    Post subject: Reply with quote
I mean that Mike Alder sent it to me and told me to how to unzip, where to put it etc. I can still see the file using the Programs/File Explorer option where it sits as a 60.6k file entitled WM6_BT_DUN
carl_the_cobbler
PostPosted: Mon Feb 16, 2009 2:37 pm    Post subject: Reply with quote
yep that's the one I have.
Carl
MrT
PostPosted: Mon Feb 16, 2009 2:59 pm    Post subject: Reply with quote
The reason that HTC do not install the DUN is that they provide an alternative in Internet Connection Sharing where the device appears as a Network Access Point and you connect to that service by USB or Bluetooth and it then connects to the GPRS service. I think that TomTom devices do not understand the Network Access Point service.
Drivelux
22.044 (24 Apr 24)
