Pocket GPS World :: View topic - 8000 POIs on a spreadsheet but how do I get them on my 720?
Nigel42
PostPosted: Fri Dec 19, 2008 7:40 pm    Post subject: 8000 POIs on a spreadsheet but how do I get them on my 720? Reply with quote
I have a spreadsheet with 8000 London POI on it.
It shows name, address, postcode, and type (of POI.
Is there anyway of putting them on to TT as a POI even it means bundlling
them all into one category.
I was hoping there was some sort of cut and paste way of doing it!
PS Im using a MAC
Cheers Confused
PostPosted: Fri Dec 19, 2008 7:43 pm    Post subject: Reply with quote
You're going to have to convert the addresses into Lat/Lon before you can do anything with them?
PostPosted: Fri Dec 19, 2008 7:48 pm    Post subject: Reply with quote
The OV2 format that is normally used requires 3 fields for each location.
Longitude,Latitude,"Name Text"
I only know of Windows programs that do the conversion, of which I would use the XLS Converter from our very own Oldie.
Nigel42
PostPosted: Fri Dec 19, 2008 8:26 pm    Post subject: Reply with quote
The XLS Converter didnt work on my MAC.
Any other suggestions?
PostPosted: Fri Dec 19, 2008 8:51 pm    Post subject: Reply with quote
The .xls converter still requires your data has Lat/Lon information before it can work.
Until you have that, there is no simple conversion utility that will read an address and convert to Lat/Lon or a standard POI format.
Nigel42
PostPosted: Fri Dec 19, 2008 10:54 pm    Post subject: Reply with quote
OK
Daggers
PostPosted: Sat Dec 20, 2008 11:41 am    Post subject: Reply with quote
If you can import the data into a copy of MS AutoRoute, it can then be exported into a format that can be read by POIEdit (& possibly XLS Converter). This will use the postcodes to create latitude/longitude information, so won't be absolutely precise, but will get most of them on the correct street, within 100 yards or so of the correct location.
PostPosted: Sat Dec 20, 2008 11:52 am    Post subject: Reply with quote
Unfortunately AutoRoute 2007, the latest version, doesn't handle the Channel Isles Postcodes. Sad
It doesn't like some of the addresses much either.
CliveBrown
PostPosted: Tue Jan 06, 2009 7:00 pm    Post subject: Reply with quote
Just been using the xls convereter, it's brilliant, so thanks to Oldboy for the link and thanks to Oldie for making the converter available. I had around 9000 poi's which were sorted in seconds
22.052 (08 May 24)
