Pocket GPS World :: View topic - Modified Mounts review
PostPosted: Fri Dec 28, 2007 5:43 pm    Post subject: Modified Mounts review Reply with quote
We are reviewing a lot of different gear, and each of them comes with their own mounting solution (or sometimes with nothing, requiring a solution). Give the increased theft rates related to windscreen mounts (and also legislation in some US states that forbids windscreen mounts) you have to decide in each case if you want to take the risk or rather invest in a dashboard mount.
The problem is that there are too many, seemingly incompatible solutions on the market. I have found myself tinkering with a few custom adapters lately and wanted to share my learnings.
http://www.pocketgpsworld.com/modifiedmounts.php
andygrunt
PostPosted: Sat Dec 29, 2007 4:35 pm    Post subject: Reply with quote
After failing to find a 'proper' mount for use with my TomTom One in my Hyundai Coupe, I decided to try making my own.
I still think it's better than any 'pro' mount I could buy - it's easy to clip on and take off, doesn't leave any marks, can easily be transferred to another car and only cost around £10.
Photos here
Why don't the Pro's make mounts this flexible and cheap? Very Happy
TomTom One 1st Edition
Firmware: V7.163
Map: United_Kingdom_and_Republic_of_Ireland' v720.1802
'Home' (Latest Version)
culzean
PostPosted: Sat Dec 29, 2007 5:41 pm    Post subject: Why mount your gps on windscreen? Reply with quote
Since I bought my Garmin C510 abouy 18 months ago I have always attached the sucker mount to the side window of my car, it is easy to see (and hear) and is just about in line with the door mirror. It is unobtrusive as it is hard for anyone outside the car to see it. I have never had a problem with using it this way.
PostPosted: Sat Dec 29, 2007 5:54 pm    Post subject: Reply with quote
@andygrunt - one important aspect is safety. I don't want you to test this but would you think your mount would survive a crash when a car strucks you from behind? Or would your device including mount become airbound and possibly hurt someone?
andygrunt
PostPosted: Sat Dec 29, 2007 6:16 pm    Post subject: Reply with quote
Fair point but I'm very confident that isn't a problem. The bulldog clips I used are particularly strong and combined with the way they wrap around the air vent this leads to a very solid attachment.
The kind of force from the rear I imagine would be needed to dislodge it would render any damage done from the mount flying around to be the least of the problems. Also, I would expect the actual TomTom One to become detached from the mount before the mount became detached from the vent (I use the mount that came with the TT1 to attach it to my vent-mount) meaning it wouldn't be any more dangerous than if I used the window suction mount that came with it.
Firmware: V7.163
Kar98
PostPosted: Sat Dec 29, 2007 9:02 pm    Post subject: Reply with quote
Below the bottom of the windshield/no telltale sucker ring on the windshield.
In easy view of the driver, next to the speedometer and tach.
Within easy reach of both the driver's hand and less than half a foot from the ciggie lighter.
And no mangling of the vent grills:
robertn
PostPosted: Mon Dec 31, 2007 9:35 pm    Post subject: Reply with quote
The early Navman units came with a base that would screw to the dash, and clamp the iCN mount. Not many people used them - something about lack of flat spots on modern dash boards and puting holes in the dash to screw it down.
I do wonder with any perminant mount, and the main reason I still use the windsheild mount, you cannot hide the fact theres something fancy in the car. Taking the Nav device with you just means the thief is disappointed, but you still have a broken window.
onecall
PostPosted: Wed Jan 09, 2008 4:13 pm    Post subject: Reply with quote
This might help drivers of the new Volswagen Passat. There are 2 small pop out drawers on the dash. I have stuck 2 strips of velcro on the face of the right hand drawer and 2 on the back of my Navman. Pop the drawer open and stick on the gps when in use. Works a treat.
sidverber
PostPosted: Fri Jan 11, 2008 9:42 am    Post subject: Reply with quote
After getting fed up with my TomTom windscreen mount not sticking/falling off in cold weather I hit on the perfect solution. I used Sticky Velcro pads. Three pads stuck to the dashboard and bottom of the TomTom gave a secure mounting while allowing ease of removal. Low-tech rules OK.
PostPosted: Fri Jan 11, 2008 5:16 pm    Post subject: Reply with quote
Just make sure you size the Velcro generously. The device should not come loose in a rear crash.
22.051 (01 May 24)
