Pocket GPS World :: View topic - Holox bt-321 antenna help
drownedrat
PostPosted: Mon Nov 19, 2007 10:40 pm    Post subject: Holox bt-321 antenna help Reply with quote
having real problems with TTFF on my setup. I'm using a Holox BT-321 linked to a HTC TYTN running TOMTOM 6. I can now do a 30 mile trip before getting a fix and if I do get one I'm having trouble keeping it. Recently got a Vauxhall Astra which some searching suggests has a treated screen and think this is the cause of the problems. I can get a fix outside the car and it was fine until recently.
I don't own the car (company) so can't modify it but was planning to try an external antenna. I think the connection is MMCX but would be grateful if anyone could confirm this? If so is ebay the best bet for antenna? Seem to be about a tenner all in rather than thirty elsewhere. Do you get what you pay for?
thanks
A.
philpugh
PostPosted: Thu Nov 22, 2007 3:36 pm    Post subject: Reply with quote
It is an MMCX.
Yes - you tend to get what you pay for - but most antennae are OK.
Yes the windscreen will be causing problems with TTFF. One solution is to place the GPS receiver on the rear parcel shelf - this glass is not treated and you should get a good signal level.
Moving increases the TTFF; part of the process for getting a fix requires the GPS receiver to "guess" where it is located based on information received. It then refines this to get a fix. If you keep moving - it takes longer.
Phil
drownedrat
PostPosted: Thu Nov 22, 2007 11:34 pm    Post subject: Reply with quote
thanks.
Will order a cheap one & see how I get on.
I knew moving makes for longer TTFF but have waited 15 min without success. Will try parcel shelf until antenna appears but have an estate so is a vertical opening.
drownedrat
PostPosted: Tue Nov 27, 2007 11:20 pm    Post subject: Reply with quote
cheap antenna from ebay (£8 with postage) arrived. get 6 -8 bars full in a few seconds and TTFF a second or so after. Very happy.
drownedrat
PostPosted: Thu Dec 13, 2007 10:14 pm    Post subject: Reply with quote
or at least it all worked really well until the SMT socket snapped off the board. Damn it.
22.051 (01 May 24)
