| Author |
Reffolds Occasional Visitor
Posted: Mon Nov 26, 2007 1:46 am Post subject: |
| The safety camera database isn't working for me. I tried it on Saturday. Some cameras OK others missing. I note that some of the cameras which didn't alert are shown as POIs in the vicinity. I also had one fixed camera alert me in the wrong direction. So, does anyone have any ideas. I copied the different camera dbs across as individual files. Jruthen, did you rename your single file to safetycamera as was the case for Copilot 6? Pls can MaFt say the reason the cameras are in individual files. Is there anyway to verify the cameras have loaded correctly? Should they show up on the map as POIs? In my case they show up on a poi seach in the vicinity of the current location but not as POIs on the map. Could be problems with Copilot 7 or the PGPS db loading or my PDA memory availability perhaps (Del X50V). I have a gut feeling that I am still operating on the Copilot speed cameras and the PGPS db has gone in as POIs. Is this possible? |
| Back to top |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 11990 Location: Bradford, West Yorkshire
Posted: Mon Nov 26, 2007 11:09 am Post subject: |
| Reffolds wrote: | | Pls can MaFt say the reason the cameras are in individual files. |
cos that's how I was asked to do them unfortunately my copy of CP7 was stolen by royal mail* so i don't have anything to test on here...
*i suppose legally i should put 'allegedly' but it was sent and it never arrived so where else is it?! _________________ 404 Error - Signature not found |
| Back to top |
mike65 Occasional Visitor
Posted: Mon Nov 26, 2007 6:00 pm Post subject: safety cameras |
| As far as I can tell, the only icon used by CP7 is the standard one. The cameras will not appear unless all the separate files are combined into one called safetycam.csv. The BMP file must be called safetycam.bmp, otherwise it won't appear. |
| Back to top |
fruit Occasional Visitor
Joined: Feb 28, 2006 Posts: 55 Location: Brandon, Suffolk, UK
Posted: Mon Nov 26, 2007 6:13 pm Post subject: |
I'd agree that the only icon used is the standard one, all the others disappear somewhere. I've not found them yet.
The pgpsw DB loaded fine for me as is without combining files or renaming |
| Back to top |
Posted: Mon Nov 26, 2007 7:30 pm Post subject: |
| Hi fruit: I was not able to get any alerts for any of the mobile, pmobile, redlight, specs etc. files until they were combined into one and renamed. I did not try to load the gatso files without renaming, so can't comment on that. Looking at the original files on the sd card supplied, you can see that the ALK system uses safetycam.bmp and safetycam.csv as filenames, so I suggest renaming our files to that to ensure all the cameras are loaded. Mine have been and are working fine. |
| Back to top |
Posted: Mon Nov 26, 2007 7:43 pm Post subject: |
That's interesting.
After receiving my CP7 I tried loading pgpsw DB entries modified as per the original files but without success. Even tried variations and some short files - same result for quite a few attempts.
I was quite relieved when the pgpsw CP7 files loaded successfully.
Perhaps there is something more to this than we are seeing at the moment. Can't tell my CP7 version ATM as I don't have it with me. |
| Back to top |
thetrevone Occasional Visitor
Posted: Wed Nov 28, 2007 5:50 pm Post subject: |
Does anybody know what the difference is between the free monthly safety camera update for Copilot 7 as supplied by ALK and the one from Pocket GPS world.
Regards
Doug |
| Back to top |
Posted: Wed Nov 28, 2007 6:11 pm Post subject: |
The Pocket GPS world version is more up to date.
The ALK version is in CP7 native format but CP7 will convert csv files of the correct format. |
| Back to top |
Posted: Wed Nov 28, 2007 8:22 pm Post subject: |
| fruit wrote: | The Pocket GPS world version is more up to date.
Thanks for the speedy reply fruit
Regards
Doug |
| Back to top |
Mikbol Occasional Visitor
Posted: Fri Dec 07, 2007 5:39 pm Post subject: Speed Cameras in Copilot 7 |
Hi all,
I have downloaded the PGPSW speed cameras as suggested. They appear as Custom POI's and I can set up the POI warnings to tell me about them but they do not appear on the map. This is not very convenient.
Is it possible to use them in the safety cameras warning system instead, perhaps by combining them and calling the resultant file safetycam.csv, or doesn't this work?
Be grateful for any advice
Many thanks |
| Back to top |
Posted: Fri Dec 07, 2007 10:27 pm Post subject: Re: Speed Cameras in Copilot 7 |
| Mikbol wrote: | Hi all,
you need to set it up so that POI's are shown on the map
MaFt _________________ 404 Error - Signature not found |
| Back to top |
ccarmock Occasional Visitor
Posted: Fri Dec 07, 2007 11:57 pm Post subject: |
I assume from what I have read here then that teh PGPSW speed camera updates appear as custom POIs on CoPilot 7 as opposed to using the safetcamera freatures of V7?
Would there be a way to get it to fully integrate int he safety camera system as opposed to Custom POI?
Regards
Clive |
| Back to top |
nivek22 Lifetime Member
Joined: Mar 09, 2006 Posts: 191 Location: Barnsley, South Yorkshire.
Posted: Sun Dec 09, 2007 5:16 pm Post subject: |
| ccarmock wrote: | | I assume from what I have read here then that teh PGPSW speed camera updates appear as custom POIs on CoPilot 7 as opposed to using the safetcamera freatures of V7? |
The PGPSW speed cameras do integrate with the safety camera feature. It's just that you have to enable alerts under settings | POIs to make the icons visible. _________________ Nokia lumia 8000
wp7.5
CoPilot 8.2.0.407 |
| Back to top |
Posted: Sun Dec 09, 2007 6:28 pm Post subject: |
I obviously don't understand the system of Safety Cameras in CoPilot 7. If the PGPSW cameras integrete with the safety camera feature why do they appear as Custom POI's and you need to enable POI alerts?
If I combine and rename the PGPSW files safetycam.csv will they the work differently??
PS. I do have POI's set to be visible |
| Back to top |
alix776 Pocket GPS Moderator
Joined: 03/05/2003 14:45:49 Posts: 3967 Location: leyland lancs ENGLAND
Posted: Sun Dec 09, 2007 6:37 pm Post subject: |
all that is needed is thhat you enable the safteycamera alerts you dont need to set them up as custom poi alerts _________________ currently using copilot truck COME ON O2 UK GET SOME 2ND GEN WINDOWS PHONES ON YOUR PRODUCT LIST
www.truckerplace.eu |
| Back to top |
| Back to top |
