Pocket GPS World :: View topic - DESTINATOR IN SONY NV-U50
pitirigos
PostPosted: Mon Apr 02, 2007 10:22 am    Post subject: DESTINATOR IN SONY NV-U50 Reply with quote
How can get Destinator to work on Sony NV-U50? I've installed it but I cannot get a GPS signal. Any ideas on how I can get Destinator to read the Sony GPS signals? Cheers
bbkoz
PostPosted: Wed Apr 04, 2007 12:45 am    Post subject: Re: DESTINATOR IN SONY NV-U50 Reply with quote
Which version of destinator did you installed?You must have destinator 6 version for pna like the one for tibo.I hope that your device have gps in nmea protocol.If so,i think that i can help you.Find in the destinator folder the file with name destinator.ini.Open it to your pc.You will see in some point these lines:
PORT=1
BAUD_RATE=38400
PROTOCOL=2
these are the gps port,baudrate of gps and nmea protocol.Open sony navigation software and look if you can find the port and baudrate of the gps antenna.If not you must put possible values.
At the beginning try 2/4800/2 and open destinator to see if recognizes gps antenna.If not you must try other values.
from com1 until com 9 are the ports. and the baudrate is 4800/9600/19200/38400/57600/115200
pitirigos
PostPosted: Wed Apr 04, 2007 9:06 am    Post subject: Reply with quote
Thank you for your reply bbkoz,
I do have Destinator 6 installed, I checked prefs.ini in the NAV-U folder and is:
[gps]
comport = 5
receiver = 2
baudrate = 9600
receiver_status = 1
ExtTmcPort = 7
Then I changed destinator.ini settings to:
PORT=5
BAUD_RATE=9600
PROTOCOL=2
Still nothing.
When I am in map I get Waiting for GPS signal.
When I go to Settings/GPS signal I get a number of satellites but no Lat,Lon, Speed or Alt.
Then in Set I do a Search GPS and I get GPS Antenna connected in COM5,
9600,NMEA.
It should work but it doesn't, something else is missing maybe a .dll or something?
bbkoz
PostPosted: Wed Apr 04, 2007 2:23 pm    Post subject: Reply with quote
This is ok.There is nothing else you can do.The first time you open destinator,you must be in clear sky and wait a lot of time to download the newspaper satellite.
pitirigos
PostPosted: Thu Apr 05, 2007 12:18 pm    Post subject: Reply with quote
I,ve waited for about 30 mins but still nothing.
It must be something else
bbkoz
PostPosted: Thu Apr 05, 2007 6:04 pm    Post subject: Reply with quote
which version do you use?Pda version have option for searching gps antenna and your machine is pna.Install tibo version from elasyn.gr.Or try another software like tom-tom or i-go
pitirigos
PostPosted: Fri Apr 13, 2007 1:23 pm    Post subject: Reply with quote
I'm not sure which version I use. Is it possible to get a PDA version to work on a PNA?
bbkoz
PostPosted: Tue Apr 17, 2007 11:05 pm    Post subject: Reply with quote
yes it is possible
abidpioneer
PostPosted: Tue Jun 05, 2007 1:02 pm    Post subject: Reply with quote
I have the same problem of signal..destinator is working for me but...no GPS signal
gryzor
PostPosted: Mon Jul 02, 2007 4:56 pm    Post subject: Reply with quote
Hello guys!
So glad I found this forum... The supplied NV-Uxx software sucks so bad!
Is there a guide as to how to install the Destinator software/maps? I've found a TomTom one elsewhere on this forum, but I don't have a TomTom package...
Gryzor
gryzor
PostPosted: Tue Jul 03, 2007 7:44 pm    Post subject: Reply with quote
Hello!
Anyone who still reads this?
I am failing even at the first step - I copy regedit to the startup folder, but Navteq's software just loads up like nothing has changed... Sad
Gryzor
Minotavrs
PostPosted: Mon Oct 13, 2008 7:29 pm    Post subject: Reply with quote
Solution....
1st open sony nav prog to find Gps signal
2nd open destinator
GPS Signal Works now...
Don't open/close the device from ON OFF at the bottom (u need do all this again for gps signal works)
Silverlegend
PostPosted: Wed Jul 22, 2009 9:46 am    Post subject: Reply with quote
There is no need to start the sony software.
AYou can replace the gpstmc.dll on the destinator folder with the sony's original gpstmcdll. You will not able to see gps details satelaits etc but it will work...
Is there somebody tha can give e the original gpstmc.dll i ve deleted it and now isn't worjing im waitng. Plz help!!!
22.051 (01 May 24)
