Newsletter
Luxury Villa at Watersong Davenport, Orlando, Florida for rent
Pocket GPS World :: View topic - New way to do custom POI warnings in TomTom 5 & 6
Goto page 1, 2, 3 ... 33, 34, 35  Next
PostPosted: Fri Oct 13, 2006 6:08 pm    Post subject: New way to do custom POI warnings in TomTom 5 & 6 Reply with quote
TomTom have made us aware of a new way to use custom POI warnings in both TomTom 5 & 6 versions. This will remove the need for manipulating the data.chk file, and is much more flexible.
Here's what you need to do:
For each of your OV2 files, create a warning sound in OGG format with exactly the same name. So if you have a BP.ov2 file, create a BP.ogg fileand place it in the same map folder. (We recommend 22050 Hz sampling rate but it should not matter)
When you restart TomTom, the new sound will automatically be used. Cool, ah? (you may have to re-set the warning distance for each POI category you changed)
A good source for ogg files is http://tomtomsatnav.info/realvoice.html . But you can of course also use your own creations.
martin998877
PostPosted: Fri Oct 13, 2006 7:01 pm    Post subject: Reply with quote
This sounds great and I'm about to try it. I'm sure lots of you are too... so remember to BACKUP first!!!
Martin
Martin Fiddler
TT Go 500 6.52 + cameras +oggs + Nokia 6280
TT Go 300 6.52 + oggs
korndog
PostPosted: Fri Oct 13, 2006 7:28 pm    Post subject: Reply with quote
Woo Hoo! It works!! I've put the original data.chk file back in so now I can use the bells and stuff for other important things like Tesco's Cafe.
Think I might the wife to do a sexy voice, something like "Warning Red Light district ahead".
Yes, there is a POI for it!! Laughing
Paul
520IQ app8.450 with UK and R of I v840.2562
wibbly
PostPosted: Fri Oct 13, 2006 8:15 pm    Post subject: Reply with quote
So (before I try this) what happens if you've already defined a POI warning sound from those included in the standard software. Does the similarly named ogg file override it (so the section of sound file via the UI is ignored? Or does it work some other way? Are the proximity settings still obeyed?
wibbly
PostPosted: Fri Oct 13, 2006 8:36 pm    Post subject: Reply with quote
Ok - found the answer - the prompt for a custom sound is suppressed by the software. Cute. I winder if my orginal choce will be restored if I delete the ogg the file? Too late now and life's too short to try until I need to! ;-)
chapman9
PostPosted: Fri Oct 13, 2006 11:44 pm    Post subject: Reply with quote
This is great, Works on x10 series as well, follow instructions, I then removed warning and then re-added it (It then doesn't give you choice of sound for that poi) Hey presto!
Noony
PostPosted: Sat Oct 14, 2006 12:01 pm    Post subject: Reply with quote
Brilliant.
This is so easy to do and it works really well.
Thanks :D
sdesign
PostPosted: Sat Oct 14, 2006 12:08 pm    Post subject: Reply with quote
Nice one!! :D
Will try this out later with Liz Whitaker from Rays site Smile
I hope his server can handle the demand this will generate this weekend Laughing
furryfred
PostPosted: Sat Oct 14, 2006 5:11 pm    Post subject: Reply with quote
Excellent - even complete genius(?) like me could manage it!
Much nicer sound than the old PGPS voice! :D
Only problem how can we set additional sounds to take care of the various "specs" which, at present, are only covered by one message
Furry Fred
(a very very nice, handsome and generous gentleman who is really rather modest, shy and retiring!)
They didn't make many like him - and now they've lost the mould!
PostPosted: Sat Oct 14, 2006 5:14 pm    Post subject: Reply with quote
Have a read through the OP by Lutz within that is a link to another site where you can get plenty of ogg file format voices that work great. The warnings as ogg files are at the bottom of the page in the link, try the Liz Whitt for a starter - Mike
markmcrobie
PostPosted: Sat Oct 14, 2006 10:04 pm    Post subject: Reply with quote
Arrghh! doesn't work for me. Downloaded some ogg files, renamed them to the same as the corresponding .ov2 file in my TomTom directory, and put then in there. However when approaching a speed cam my TomTom (6.010) still sounds an alarm sound (as it did before), not the new voice ogg file
Help!
PostPosted: Sat Oct 14, 2006 10:11 pm    Post subject: Reply with quote
When you say you have put them in the TomTom directory can you please clarify this?
The .ov2 & .bmp and the .ogg files MUST all be the same name (just the file extension differs) all three files MUST be placed in to the current (probably GB) map folder for this to work - Mike
markmcrobie
PostPosted: Sat Oct 14, 2006 11:57 pm    Post subject: Reply with quote
Yes, they are all name the same (.bmp, .ov2 and .ogg, eg gatso_20.bmp, gatso_20.ogg, gatso_20.ov2) and they are all in my Great_Britain folder.
eillo7
PostPosted: Sun Oct 15, 2006 12:01 am    Post subject: Reply with quote
Next you need to reset your 'warn when near POI' settings for each POI.
However, this time it won't ask which sound you want to use as it will see that you already have your .ogg sound file for that POI. All it will ask is the distance you want the warning and whether you want it only if on route. Smile
markmcrobie
PostPosted: Sun Oct 15, 2006 12:37 am    Post subject: Reply with quote
Ok, thanks
I have a curiousity question - Why would you choose anything other than "only warn if on route"? Why would you want to be warned of something not on your route?
Page 1 of 35
11.053 (15 May 13)
