Pocket GPS World :: View topic - Change TT5 menu possible
Goto page Previous  1, 2, 3 ... 11, 12, 13
MotoBorg
PostPosted: Tue Jan 10, 2006 11:16 am    Post subject: Reply with quote
Thought you might, but do you know how to?
lupos0_1
PostPosted: Tue Jan 10, 2006 11:50 pm    Post subject: Reply with quote
I believe that on the menubuilder website, there is an option for the other saubmenue directly below the main menu. I think it is called preferences menu.
Nokia N95
McGuider V7
Latest Maps
(Internal GPS)
MotoBorg
PostPosted: Thu Jan 12, 2006 12:39 pm    Post subject: Reply with quote
I have looked at the Menu builder site and only allow to edit the top level menu pages + the preference page. Does any on know how to edit the Navigation sub menu?
Mullet
PostPosted: Thu Jan 12, 2006 12:56 pm    Post subject: Reply with quote
Out of curiosity, what would you want to change in there?
MotoBorg
PostPosted: Thu Jan 12, 2006 3:40 pm    Post subject: Reply with quote
I would like to change the Navigate menu so that it reads:
Page 1
Address Favourite
POI Postcode
Point on map Next Page
Page 2
Home Recent destination
City centre GPS Position
POI in city Next page
That is I want to brin postcode and point on map forward as these are frequently used.
Thank you for your help.
aubergine
PostPosted: Wed Jan 25, 2006 10:08 am    Post subject: Reply with quote
the menu editing is available at tomtom pro, check this documentation
http://www.tt1.nl/guests/PRO/TTN5-SDK_documentation.zip
here is an overview of menu items:
2.5. Overview menu items
For more information on TomTom Navigator menu items, please refer to the TomTom Navigator manual.
Blocks
There are two blocks that can currently be defined in a menu file:
BLOCK_MAIN , Main Menu Block
BLOCK_PREF, Preferences Menu Block
BTM_options
At block-level, the following items can be defined to be shown at the bottom of the screen. Each menu-page of that block will show the BTM_options defined for that block.
BTM_GPS_POSITION , GPS Information
BTM_DONE , Done Button
TRAFFIC_INFO , Traffic Information
Menu Items
The following menu items can be used in the customized menu file.
Special Tasks
TASK_EMPTY, no task and this option will be shown as a blanc spot in the 6-option menu
TASK_NONE, no task and no placeholder for it in the menu
TASK_PAGEn, (n is in the range 1-20) a number identifying the custom menu page
TASK_SDKn, (n is in the range 1-50) a command to be sent to a client application, as defined in a capability file
Navigation
TASK_AVOID_ROUTE_LINE, Choose part of the route to avoid
TASK_CONFIRM_DELETE_ROUTE , Clear Route with asking the user confirmation first
TASK_DELETE_ROUTE, Clear Route immediately
TASK_ITINERARY , Itinerary planning
TASK_NAVIGATE_TO , Navigate to
TASK_MENU_FIND_ALTERNATIVES , Go to "Find alternative" menu
TASK_MENU_PLAN_ATOB , Advanced planning
TASK_MENU_RECALC_BLOCK, Go to "Avoid roadblock" menu
TASK_MENU_ROUTE_INSTRUCTIONS, Show the menu with options for vieuwing route
TASK_PLAN_VIA, Calculate a route that goes via specified address
TASK_SET_TOLL, Set the preferences for toll roads
TASK_SET_PLANTYPE, Set the preferences for route planning
TASK_SET_CRADLE, Set cradle preferences
TASK_SHOW_ROUTE_DEMO, Demonstrate planned route
TASK_SHOW_ROUTE_INSTRUCTIONS, Show the list with route instructions
TASK_STEP_ROUTE_INSTRUCTIONS, Browse through the route instructions as images
TASK_SWITCH_2D3D, Switch between 2D and 3D navigation view
Downloads
TASK_MENU_DOWNLOAD , Download extras
TASK_MENU_TRAFFIC , TomTom Traffic
TASK_SHOW_WEATHER , TomTom Weather
Manage Maps
TASK_DELETE_MAP, Delete a map
TASK_SET_MAP, Choose a current map
TASK_SET_HIDEMAP, Specifies whether the map should be replaced with a simpler view under certain conditions
TASK_SHOW_MAP , Browse map
Favourites
TASK_ADD_FAVORITE , Add favourite
TASK_MAINTAIN_FAVORITES, Maintain the list of favorites
Preferences
TASK_CHANGE_HOME_LOCATION, Specify new home location
TASK_LEFTHANDED, Switch between lefthanded and righthanded UI
TASK_MENU_PREFERENCES , Change Preferences
TASK_RESET_SETTINGS, Restore original application settings
TASK_ROTATE_DISPLAY, rotate display by 180 degrees
TASK_SET_BRIGHTNESS, Adjust the brightness level for the device
TASK_SET_BACKLIGHT, Adjust the backlight settings for the device
TASK_SET_CLOCK_TYPE, Set clock type
TASK_SET_COLOR_SCHEMES, Choose day and night color schemes
TASK_SET_COMPASS, Specify how to show the compass in the navigation view
TASK_SET_DAY_COLOR_SCHEME, Choose day color scheme
TASK_SET_DIST_UNITS, Choose distance units
TASK_SET_KEYBOARDSIZE, Set the size for the onscreen keyboard
TASK_SET_KEYBOARDTYPE, Set the type for the onscreen keyboard
TASK_SET_LANGUAGE, Choose application language
TASK_SET_NIGHT_COLOR_SCHEME, Choose night color scheme
TASK_SET_PROMPT, Specify the additional settings for voice promtps
TASK_SET_STATUS, Specify the information to show at the bottom of navigation view
TASK_SET_VOICE, Choose the voice for reading instructions
TASK_SET_VOLUME, Adjust the voice volume
TASK_SHOW_GPS_STATUS , Configure GPS
TASK_SHOW_STATUS, Show route status
TASK_SWITCH_ASN, Switch accelerometer on/off
TASK_SWITCH_BLUETOOTH, Enable/disable bluetooth connectivity
TASK_SWITCH_NIGHTVIEW, Switch to night view mode
TASK_SWITCH_SOUND, Enable/disable sound
TASK_SWITCH_TIPS, Enable/disable tips
POI
TASK_CONFIGURE_POI, Choose which types of POI to show
TASK_MAINTAIN_POI, Go to POI maintenance menu
TASK_SWITCH_POI, shows/hides POI
Traffic
TASK_MENU_TRAFFIC, go to traffic menu
TASK_TRAFFIC_ENABLE, enable traffic support
TASK_TRAFFIC_EXPLAIN, help for traffic
TASK_TRAFFIC_REPLAN, replan current route
TASK_TRAFFIC_SETTINGS, specify traffic settings
TASK_TRAFFIC_UPDATE, update traffic information
TASK_TRAFFIC_VIEW, go to traffic incidents view
Miscellanious tasks
TASK_ABOUT, show Navigator information screen
TASK_EXIT_APP, exit the application
TASK_SET_NAME_DISPLAY, specify naming preferences for map/navigation views
Downloads
TASK_DOWNLOAD_MAP, Download map
TASK_DOWNLOAD_POI, Download POI
TASK_DOWNLOAD_VOICE, Download voice
TASK_DOWNLOAD_SCHEME, Download color scheme
TASK_DOWNLOAD_VERSIONNUMBER, Upgrade the Navigator application
TASK_MANAGE_MAPS, Go to "Manage maps" menu
TASK_MENU_DOWNLOAD, Go to "Downloads" menu
TASK_SERVICE_LOGIN, Perform login to the TomTom Plus services
TASK_SHOW_WEATHER, Get the current weather information
Help
TASK_HELP_GENERAL, General help
TASK_HELP_ITINERARY, Help for itinerary
TASK_HELP_MAINMENU, Help for the main menu
TASK_HELP_MAPBROWSER, Help for the map view
TASK_HELP_PLANNING, Help for route planning
TASK_HELP_TRAFFIC, Help for traffic
TASK_HELP_ZOOMING, Help for zooming
TASK_TUTORIAL , Guided tour
Phone
TASK_DIAL_POI, Dial the POI
TASK_MENU_PHONE , Mobile phone
TASK_PAIR_WITH_PHONE, Connect to the phone via Bluetooth
Courierman
PostPosted: Sat Feb 18, 2006 9:02 pm    Post subject: Reply with quote
hi ya i wont to change the navigate to menu i wont postcode and home on the 1st page and favourite on the 2nd page do you know how to do it please
WhichWay
PostPosted: Sun Feb 19, 2006 7:33 pm    Post subject: Reply with quote
I used the Windows app at http://www.gregoryduncan.com/ttmd/index.htm to design my menus. It's very easy to use but doesn't have instructions on where to put the resulting mnu file on a PPC. However, lbendlin told me to put it in \TomTom\SdkRegistry and it works fine.
As has been said here though, TomTom does not allow you to change the submenus Crying or Very sad but it's great having my own menus now :D
spile
PostPosted: Fri Apr 21, 2006 1:02 pm    Post subject: Rotate Screen Reply with quote
Why is the rotate screen by 90 degrees option not available from the menu builder when it is accessible via the preferences submenu?
lupos0_1
PostPosted: Fri Apr 21, 2006 3:53 pm    Post subject: Reply with quote
I don't know why but nobody has been able to fix this issue.
Nokia N95
McGuider V7
Latest Maps
(Internal GPS)
MotoBorg
PostPosted: Mon Apr 24, 2006 9:59 pm    Post subject: Reply with quote
I am having problems trying to get POI Warner in the menus. All SDK commands keep displaying in TomTom as Mobile phone and when pressed nothing appears to happen. Any one any ideas how to rectify. My current menu file is listed below:
Code:
MENUBLOCK|BLOCK_MAIN|BTM_GPS_POSITION|
MENUPAGE|TASK_PAGE1|Page 1|
MENUITEM|TASK_NAVIGATE_TO|
MENUITEM|TASK_MENU_FIND_ALTERNATIVES|
MENUITEM|TASK_PLAN_VIA|
MENUITEM|TASK_AVOID_ROUTE_LINE|
MENUITEM|TASK_ITINERARY|
MENUITEM|TASK_PAGE2|
MENUPAGE|TASK_PAGE2|Page 2|
MENUITEM|TASK_MENU_PLAN_ATOB|
MENUITEM|TASK_CONFIRM_DELETE_ROUTE|
MENUITEM|TASK_SDK1|
MENUITEM|TASK_SDK2|
MENUITEM|TASK_SHOW_MAP|
MENUITEM|TASK_PAGE3|
MENUPAGE|TASK_PAGE3|Page 3|
MENUITEM|TASK_MENU_ROUTE_INSTRUCTIONS|
MENUITEM|TASK_SHOW_ROUTE_DEMO|
MENUITEM|TASK_SHOW_ROUTE_INSTRUCTIONS|
MENUITEM|TASK_STEP_ROUTE_INSTRUCTIONS|
MENUITEM|TASK_SHOW_STATUS|
MENUITEM|TASK_PAGE4|
MENUPAGE|TASK_PAGE4|Page 4|
MENUITEM|TASK_SWITCH_NIGHTVIEW|
MENUITEM|TASK_SWITCH_2D3D|
MENUITEM|TASK_SET_HIDEMAP|
MENUITEM|TASK_MENU_PREFERENCES|
MENUITEM|TASK_EXIT_APP|
MENUITEM|TASK_PAGE1|
MENUBLOCK|BLOCK_PREF|BTM_GPS_POSITION|
MENUPAGE|TASK_PAGE5|Preferences Page 1|
MENUITEM|TASK_ADD_FAVORITE|
MENUITEM|TASK_MAINTAIN_FAVORITES|
MENUITEM|TASK_MAINTAIN_POI|
MENUITEM|TASK_SWITCH_POI|
MENUITEM|TASK_CONFIGURE_POI|
MENUITEM|TASK_PAGE6|
MENUPAGE|TASK_PAGE6|Preferences Page 2|
MENUITEM|TASK_SET_PLANTYPE|
MENUITEM|TASK_SET_DIST_UNITS|
MENUITEM|TASK_SWITCH_SOUND|
MENUITEM|TASK_SET_VOLUME|
MENUITEM|TASK_CHANGE_HOME_LOCATION|
MENUITEM|TASK_PAGE7|
MENUPAGE|TASK_PAGE7|Preferences Page 3|
MENUITEM|TASK_SET_COLOR_SCHEMES|
MENUITEM|TASK_SHOW_GPS_STATUS|
MENUITEM|TASK_SET_STATUS|
MENUITEM|TASK_SET_COMPASS|
MENUITEM|TASK_ABOUT|
MENUITEM|TASK_PAGE8|
MENUPAGE|TASK_PAGE8|Preferences Page 4|
MENUITEM|TASK_SET_VOICE|
MENUITEM|TASK_SET_PROMPT|
MENUITEM|TASK_SET_TOLL|
MENUITEM|TASK_MANAGE_MAPS|
MENUITEM|TASK_SET_KEYBOARD_SIZE|
MENUITEM|TASK_PAGE5|
lupos0_1
PostPosted: Tue Apr 25, 2006 9:29 am    Post subject: Reply with quote
I believe you have to put in a number for the SDK applications. I'm afraid it is just trial and error on that one.
Start at 1 and work your way up.
Nokia N95
McGuider V7
Latest Maps
(Internal GPS)
Giangi
PostPosted: Thu May 11, 2006 12:29 pm    Post subject: Reply with quote
For those, like me, who tried to have custom menu on their Palm and wasn't able to get anything... It's not our fault! There is a bug in the latest TT5 for Palm platform... Sad
I've got an asnwer from TomTom directly:
Inviato: giovedě 11 maggio 2006 9.18
A: Calzolari Gian Maria
Oggetto: RE: 20060510193434SDK for TT5 for Palm platform
Dear Gian,
The reason that you don't find anything about Palm in the SDK
documentation is that it is not possible to run multiple applications at
the same time on Palm OS. Therefore is the Palm OS not supported by the
SDK.
The customization options don't need a second application and they
supposed to work. Unfortunately there is a bug in path string which
makes it impossible for our app to find the customization files. We will
try to get this fixed in a future update
Ciao,
Giangi
Page 13 of 13
