Pocket GPS World :: View topic - rechargeable battery's
Goto page Previous  1, 2
bighassan
PostPosted: Sat Feb 04, 2006 2:15 pm    Post subject: Reply with quote
These batteries being sold on eBay are superb - better than Duracell throwaways! I have bought about a dozen and am delighted with them. :D
portman
PostPosted: Tue Feb 07, 2006 12:15 pm    Post subject: Reply with quote
Have found 4 AA batteries(2300mAh) and charger for £6.99 at play.com.
http://www.play.com/play247.asp?page=title&r=ELEC&title=872968&p=248&g=328&pa=genbrw
Play.com (UK) : Encore Classic Charger With 4 x 2300 mAh NiMH Batteries : Electronics - Free Delivery
Aitch2
PostPosted: Tue Feb 07, 2006 1:16 pm    Post subject: Reply with quote
Yeah - you can actually find AA's up to around 2600mAh capacity now...
Aitch
Find Somewhere Else 090407: www.marillion.com
PaulB2005
PostPosted: Tue Feb 07, 2006 2:56 pm    Post subject: Reply with quote
I have been using some 800mAh rechargables and they have been fine for me.
I have the unit connected to the cars supply when in use so the batteries are only for the switch off countdown and a little bit of time when I am loading POI's etc.
I am finding I have to charge them every couple of weeks which is fine by me.
So you're not actually using the batteries at all then?
So you run the unit of the ciggy lighter when in the car?
Can you explain this? Do you mean when you switch of the ignition and it switches to batteries you get the 30 seconds count down? What's the point?
Your PCs USB bus should power the i3 when you plug it in so your not using the batteries there either.
north_country_boy
PostPosted: Tue Feb 07, 2006 3:39 pm    Post subject: Reply with quote
I saw these on Ebay but when I emailed the seller he said they take about 22 hours to charge up. I ended up with a Uniross 300, which takes 9 for £8.50 delivered.
portman
PostPosted: Tue Feb 07, 2006 6:08 pm    Post subject: Reply with quote
i posted the price because it seemed a good price for rechargeables with the charger. If you want a faster charger(30mins) the duracell offer in boots recently was good for £10, or if you want higher capacity batteries, ebay has 2800mAh on offer.
http://forums.moneysavingexpert.com/showthread.html?t=129291&page=1&pp=10&highlight=duracell
MoneySavingExpert.com Forums - Duracell charger was £44.99 now £9.99
http://cgi.ebay.co.uk/16-x-AA-Rechargeable-Batteries-2800-MAX-VAPEXTECH_W0QQitemZ5664017394QQcategoryZ14951QQtcZphotoQQcmdZViewItem
eBay.co.uk: 16 x AA Rechargeable Batteries 2800 MAX VAPEXTECH (item 5664017394 end time 15-Feb-06 22:29:48 GMT)
Nickwolf
PostPosted: Wed Feb 08, 2006 5:24 pm    Post subject: Reply with quote
PaulB2005,
My general point was that for, what I would consider, pretty normal use as I described there is no real need to be spending extra money on 2.5 - 3Ah batteries since run of the mill rechargables available from Tesco will do a perfectly adequate job.
Nick.
PaulB2005
PostPosted: Wed Feb 08, 2006 7:03 pm    Post subject: Reply with quote
Nickwolf
Cheers. Plus i found out that keeping batteries in when it's off means it doesn't take as long to acquire the satellite's, so there is another benefit.
I didn't mean to come across as being aggressive - i just couldn't see how the batteries where being used.
Paul
Page 2 of 2
