Pocket GPS World :: View topic - Postcode Checker, Map Data
d4funky1
PostPosted: Tue Dec 27, 2005 4:25 am    Post subject: Postcode Checker, Map Data Reply with quote
I have checked around and still cannot find on my I3 where I can input a postcode for a route.
If I choose where to? I get the choices of:
Country
City
House Number
Street
Thats it.
I'm getting the feeling now i've got a copied card here, how can I tell?
Also, I have done a master reset (I think, held down left and middle then switched on).
On the restart I am now presented with a different opening message:
To use this unit, map data must be installed. Installation instructions are located in the enclosed setup guide. Warning: Do NOT connect this unit to your PC until instructed to do so as explained in the setup guide.
Firstly, I don't have a set-up guide. I only got a quick start booklet and a product information sheet.
Secondly, Where do I get this map data from?
Thirdly, If I press and hold the scroll now I get through to the main page which still has the maps loaded onto it, I thought the reset would delete these?
If anyone can please help and ease my mind before I go back to the seller and blow my top with them it would be greatly appreciated.
Many Thanks
RODTROTTER
PostPosted: Tue Dec 27, 2005 11:26 pm    Post subject: Reply with quote
when you press where to you should get
go home
address
food hotels and more
recent finds
my favorites
intersections
cities
you have got a copied card it will never work so you will need to speek to the seller also inform ebay and lets hope you payed with paypal tell them and they will help you
if you have any problems get back to me i may to abile to help i use ebay alot and have had problems wich i have sorted out
RODTROTTER
PostPosted: Wed Dec 28, 2005 4:21 pm    Post subject: Reply with quote
try tacking out the trans flash card and puting it back in a m8 asked me to update hes i3 when i turned it on it did the same as yours i took out the card and put it back in all was fine with a bit of luck it may work for you
