MikeB Frequent Visitor
Joined: 20/08/2002 11:51:57 Posts: 3859 Location: Essex, UK
Posted: Tue Nov 29, 2005 12:26 pm Post subject: Globalsat SD-502 Compatibility |
Please post your success/failures with getting the SD-502 to work with your PDA, and software.
Mine works fine with my XDAII and Memory-map. _________________ Mike Barrett |
Mehanik Occasional Visitor
Joined: Jun 09, 2004 Posts: 26 Location: Moscow, Russia
Posted: Tue Nov 29, 2005 3:37 pm Post subject: |
Work with iPAQ h2210 and hx4700. _________________ Mikhail E. Veselov
http://www.globalsat.su
GlobalSat Russia |
RW Occasional Visitor
Posted: Thu Dec 01, 2005 1:26 am Post subject: |
Working fine with IPAQ 5550 and TomTom v.5.21.
Need to perform a soft reset after inserting SDIO card, then Settings, System, Memory, Storage Card and select GPSDisk Card. Map(s) can the be installed on the card using Active Sync (not card reader).
Specify GPS hardware settings on TomTom to: Other NMEA GPS, 4800 baud, COM4.
Appears to work well; good battery life, in excess of 3 hours. |
EasyD2 Regular Visitor
hacksawbob Occasional Visitor
Posted: Sun Dec 18, 2005 8:53 pm Post subject: |
Cant seem to get this working with Tmobile MDA compact. Tried several com ports at 4800 baud and cant get it responding with the GPSinfo application, also cant see the storage card anywhere if I try to browse for it. Maybe got a faulty card? |
xda Lifetime Member
Posted: Mon Dec 19, 2005 12:38 pm Post subject: |
hacksawbob wrote: | Cant seem to get this working with Tmobile MDA compact. Tried several com ports at 4800 baud and cant get it responding with the GPSinfo application, also cant see the storage card anywhere if I try to browse for it. Maybe got a faulty card? |
The storage card should show up as "GPSDisk Card". Assuming the MDA is the same as an XDA 2 in GPSinfo I had to set mine to Comm 7 GPSUart at 4800. You don't say which navigation software you are using, I'm still with TomTom V3 but to get it to work with that version you need to delete/Uninstall the TT GPS driver and install the V2.06 driver which is on this site. The TT GPS V3.07 won't let you enable Comm port 7.
If you use Active sync you will need to set it to update the PC files from the PPC to update the TomTom files stored on the PC otherwise it will put the old TomTom config files back on the PPC.
Other than that it works fine with TomTom and Memory Map _________________ Graham.
Map: Europe V910.4892
Nokia 925 Windows 8 |
Posted: Mon Dec 19, 2005 3:11 pm Post subject: |
Hi thanks for the quick response, I have tried it with the 1.32 driver, and I have also updated my phone ROM just to make sure. Tha manual wasn't clear whether I needed to run GPSinfo on the PPC and the PC at the same time. However I get COM1 and COM2 returning NO DEVICE on the PC. On the PPC I have the following ports
COM1: Serial,
COM2: Serial_CMD
COM3: IRCOMM
COM4: BTIBserial
COM5: BTOBserial
COM9: Serial_Data
I have tried them all at 4800 baud unpluging my card between each attempt to "start GPS". I read in the manual something about bluetooth ports running at 38400 so I have tried this on com4 and 5
XDA thanks for that, I want to run TT5 but I haven't even got that far just trying to get it working with the GPSinfo application. Memory doesn't show up in the system settings memory. i dont suppose any 'round the Bolton area in the UK has a phone I could plug it into to see if its the card? |
xda Lifetime Member
Posted: Tue Dec 20, 2005 6:10 am Post subject: |
hacksawbob wrote: | Hi thanks for the quick response, I have tried it with the 1.32 driver, and I have also updated my phone ROM just to make sure. Tha manual wasn't clear whether I needed to run GPSinfo on the PPC and the PC at the same time. However I get COM1 and COM2 returning NO DEVICE on the PC. On the PPC I have the following ports
COM1: Serial,
COM2: Serial_CMD
COM3: IRCOMM
COM4: BTIBserial
COM5: BTOBserial
COM9: Serial_Data
I have tried them all at 4800 baud unplugging my card between each attempt to "start GPS". I read in the manual something about bluetooth ports running at 38400 so I have tried this on COM4 and 5
XDA thanks for that, I want to run TT5 but I haven't even got that far just trying to get it working with the GPSinfo application. Memory doesn't show up in the system settings memory. i don't suppose any 'round the Bolton area in the UK has a phone I could plug it into to see if its the card? |
What you are getting is the same as I initially got when I first installed the SD-502 driver.
When you first install the SD-502 it's green led should be on continuously, then after about 5 minutes should start flashing. This means it has now got a satellite fix.
The problem I had was that the XDA wasn't making the comm 7 available, because I already had TomTom installed with the V3.07 GPS driver that was stopping me from selecting comm 7 which the SD-502 was using.
It was also setup to use my original TomTom wired GPS.
Once I had removed the V3.07 GPS driver I still got what you are seeing ie no comm 7. Installing the V2.06 GPS driver allowed me to set comm 7 in GPSinfo and I had 6 Sats showing.
I would suggest that you install your TomTom V5, this should then make the additional comm ports available that GPSinfo hasn't got yet, once you have installed TomTom and TomTom GPS you can access the TomTom GPS from the Program menu and then select the com port that the SD-502 is using. _________________ Graham.
Posted: Tue Dec 20, 2005 1:09 pm Post subject: |
No joy I'm affraid, did a hard reset, removed the existing SD card so completely clean install of PPC. Installed GPSinfo and then installed driver GPSDisk.v132.armv4.cab ran it , then soft reset, then pluged in GPSdevice still not registering. No memory card showing and NO DEVICE listed in GPSinfo on the PC
GPSinfo on the PPC only shows the same ports
COM1: Serial,
COM2: Serial_CMD
COM3: IRCOMM
COM4: BTIBserial
COM5: BTOBserial
COM9: Serial_Data
I suppose it could be the phone but without another one to test it in All I can do is return it and hope another one works. |
Wonderbadger Occasional Visitor
Posted: Thu Dec 29, 2005 7:54 pm Post subject: |
Got my SD502 this morning and installed it on my Medion PPC200, worked first time with GPS info and nav software so that can be added to the list of compatable devices :D (which is good as I would be rather annoyed otherwise ) |
Posted: Thu Dec 29, 2005 9:32 pm Post subject: |
DOH... above should read PPC250 not 200 |
teb Occasional Visitor
Posted: Thu Dec 29, 2005 10:57 pm Post subject: |
Hacksaw you arent the only one with this problem! i have a qteks110 which is essentially the same as the mda compact and i cannot activate com port 7. it appears to be gettin a satellite fix but the pda isnt detecting the sd card. i have pmed xda so hopefully he will get back to me luckily for me doesnt live to far cos i`m useless with pc`s and software. |
xda Lifetime Member
Posted: Fri Dec 30, 2005 7:51 am Post subject: |
teb wrote: | Hacksaw you arent the only one with this problem! i have a qteks110 which is essentially the same as the mda compact and i cannot activate com port 7. it appears to be gettin a satellite fix but the pda isnt detecting the sd card. i have pmed xda so hopefully he will get back to me luckily for me doesnt live to far cos i`m useless with pc`s and software. |
There is no guarantee that your unit is using Comm 7, Mine is but GPSinfo is reluctant to show that port.
I am still running TomTom V3 and there has always been an issue with the TomTom V3 GPS driver restricting the available ports, hence my need to use TomTom V2.06 GPS driver, which doen't have that problem.
I see from you other posts that you are using TomTom V5 and I think you will find you need to set it up to use as a wired GPS NMEA 4800 from within. Programs, GPS, untick the box top left, to enable you to select the top options box. _________________ Graham.
corky Occasional Visitor
Posted: Sat Dec 31, 2005 1:10 pm Post subject: Mine not working well at all.... |
Oh well i got my SD-502 yesterday morning, i had already installed 1.32 driver prior to getting it, my pda is a medion pcc250. Anyway plugged it in and after a few mins it started working, so i installed tomtom 5 to the memory card and took it for a test and it worked fine, even with lots of snow coming down.
But later on in the day when i tested it again i noticed the live map was not updating very quickly as you drive about, so if i went over a roundabout and carried on down the road it was only just mapping the roundabout ! and the signal was not too good either.
So i restarted it all again, and took the 502 out and put it in again and then i got much better signal even though i had not moved, started driving home and then the map locked up solid, i could'nt even turn the pda off !
When i got home to my suprise there was nothing on the 502 memory card, it had somehow cleared everything that i had installed !
So i formatted it and tried to start again but part way through the map install there was no memory card again ?
In the end i got it all installed again, but i'm not really sure if you plug this 502 in while the pda is on, or off. Because i get "no map found" sometimes when i go to run tomtom, but if i unplug the 502 and put it in again then it works, but i am still getting this delayed map update !
So i'm not having much luck anyway |
